Structure containing the radiation module parameters.
More...
#include <cs_rad_transfer.h>
◆ angsol
Weight of the solid angle.
◆ atmo_df_id
Atmospheric radiation model: id of the Diffuse Solar band or -1 if not activated (automatically computed)
◆ atmo_dr_id
Atmospheric radiation model: id of the Direct Solar band or -1 if not activated (automatically computed)
◆ atmo_ir_id
Atmospheric radiation model: id of the InfraRed band or -1 if not activated (automatically computed)
◆ atmo_model
- Direct Solar the first bit
- diFfuse Solar for the second bit
- InfraRed for the third bit
◆ dispersion
add dispersion (through diffusion)
◆ dispersion_coeff
dispersion coefficient. The dispersion coefficient leading to the best precision may depend on the chosen quadrature, and has been observed to be 3 for 128 directions (T4) and 5 for 32 directions (T2) on a (cube with point source) test case; the default value of 1 already improves precision in both cases.
◆ i_quadrature
Index of the quadrature and number of directions for a single octant.
Sn quadrature (n(n+2) directions)
- 1: S4 (24 directions)
- 2: S6 (48 directions)
- 3: S8 (80 directions)
Tn quadrature (8n^2 directions)
- 4: T2 (32 directions)
- 5: T4 (128 directions)
- 6: Tn (8*ndirec^2 directions)
- 7: 120 directions (LC11)
- 8: 48 directions (DCT020-2468)
◆ idiver
Indicates the method used to calculate the radiative source term:
- 0: semi-analytic calculation (compulsory with transparent media)
- 1: conservative calculation
- 2: semi-analytic calculation corrected in order to be globally conservative
◆ ifgrno
◆ ifinfe
Modeling of an infinite extrusion for open boundaries.
◆ ifrefl
◆ iimpar
Verbosity level in the log concerning the calculation of the wall temperatures:
- 0: no display
- 1: standard
- 2: complete
◆ imfsck
FSCK model:
- 0 no FSCK model
- 1 FSCK model activated
◆ imoadf
ADF model:
- 0 no ADF model
- 1 ADF model with 8 intervals of wave length
- 2 ADF model with 50 intervals of wave length
◆ imodak
When gas or coal combustion is activated, imodak indicates whether the absorption coefficient shall be calculated "automatically" (=1) or read from the data file (=0).
◆ ipgrno
◆ iprefl
◆ itpimp
◆ itpt1d
See CS_BOUNDARY_RAD_WALL_GRAY_1D_T
◆ iwrp1t
P1 model transparency warnings counter.
◆ ndirec
Number of directions for the angular discretisation of the radiation propagation with the DOM model.
No other possible value, because of the way the directions are calculated.
The calculation with 32 directions may break the symmetry of physically axi-symmetric cases (but the cost in CPU time is much lower than with 128 directions).
Useful if and only if the radiation module is activated with the DOM method.
◆ ndirs
For the Tn quadrature, ndirec squared
◆ nrphas
Phase which radiates (bulk by default, but may be coal class or fuel droplets phase).
◆ nwsgg
Spectral radiation models (ADF and FSCK).
Number of ETRs to solve.
◆ nzfrad
◆ restart
Indicates whether the radiation variables should be initialized or read from a restart file.
◆ time_control
Determines at which time steps the variables are updated Also, in order to have proper initialization of the variables, the radiation module should always be called at the first time step of a calculation (restart or not).
◆ type
model activation and type
◆ vect_s
Direction vectors of angular values of the quadrature sx, sy, sz.
◆ verbosity
Verbosity level in the log concerning the calculation of the radiative transfer equation:
- 0: no display
- 1: standard
- 2: complete
◆ wq
Weights of the Gaussian quadrature
◆ xnp1mx
