#include <cs_lagr.h>
Data Fields | |
int | ltsdyn |
int | ltsmas |
int | ltsthe |
int | itsli |
int | itske |
int | itste |
int | itsti |
int | itsmas |
int * | itsmv1 |
int * | itsmv2 |
int | itsco |
int | itsfp4 |
int | nstits |
int | npts |
int | ntxerr |
cs_real_t | vmax |
cs_real_t | tmamax |
cs_real_t * | st_val |
2-way coupling and source term information.
int itsco |
source term for the carbon released during heterogeneous combustion
int itsfp4 |
variance of the air scalar
int itske |
int itsli |
implicit source term for the continuous phase velocity and for the turbulent energy if the model is used
int itsmas |
mass source term
int* itsmv1 |
int* itsmv2 |
int itste |
explicit thermal source term for the thermal scalar of the continuous phase
int itsti |
implicit thermal source term for the thermal scalar of the continuous phase
int ltsdyn |
int ltsmas |
activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING, physical_model = 1 and impvar = 1
int ltsthe |
int npts |
number of time steps for source terms accumulations
int nstits |
number of absolute time steps (including the restarts) after which a time-average of the two-way coupling source terms is calculated. Indeed, if the flow is steady (isttio=1), the average quantities that appear in the two-way coupling source terms can be calculated over different time steps, in order to get a better precision. if the number of absolute time steps is strictly inferior to nstits, the code considers that the flow has not yet reached its steady state (transition period) and the averages appearing in the source terms are reinitialized at each time step, as it is the case for unsteady flows (isttio=0). Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and isttio=1
int ntxerr |
number of cells, whose vulumetric rate DODO (concentration ?)is greather than 0.8
cs_real_t* st_val |
source term values
cs_real_t tmamax |
maximum massic concentration reached
cs_real_t vmax |
maximum volumetric concentration reached
