7.1
rotation.f90 File Reference
Module for rotating zones (rotors) More...
Data Types
interface  rotation_define
 Define a global rotation. More...
interface  rotation_update_coords
 Update coordinates based on a global rotation and time. More...
interface  angular_velocity
 Return angular velocity associated with a rotation. More...
interface  rotation_velocity
 Compute rotation velocity at given point coordinates
\[ \vect{v}=\vect{\Omega}\wedge\vect{x},\quad \text{with }\vect{\Omega}\textnormal{ the rotation vector and } \vect{x}\text{ the point location.} \]
. More...
interface  add_coriolis_v
 Add a Coriolis term to a local vector
\[ \vect{w}=\vect{w}+C\vect{\Omega}\wedge\vect{u},\quad \text{with }C\text{ a multiplicative coefficient, } \vect{\Omega}\text{ the rotation vector and } \vect{u}\text{ the velocity.} \]
. More...
interface  coriolis_v
 Compute a Coriolis term for a vector
\[ \vect{w}=C\vect{\Omega}\wedge\vect{u},\quad \text{with }C\text{ a multiplicative coefficient, } \vect{\Omega}\text{ the rotation vector and } \vect{u}\text{ the velocity.} \]
. More...
interface  add_coriolis_t
 Add the dual tensor of a rotation vector to a tensor
\[ T_{ij}=T_{ij}+\epsilon_{imj}\Omega_m,\quad \text{for }\Omega_m\text{ the rotation vector components and } \epsilon_{imj}\text{ the permutation tensor components.} \]
. More...
interface  coriolis_t
 Compute the dual tensor of a rotation vector
\[ T_{ij}=\epsilon_{imj}\Omega_m,\quad \text{for }\Omega_m\text{ the rotation vector components and } \epsilon_{imj}\text{ the permutation tensor components.} \]
. More...
interface  rotation_to_array
 Copy rotation structure values to an array. More...
Modules
module  rotation
integer nrotmx
 Maximum number of rotors. More...
double precision, dimension(3, nrotmx), save rotax
 Rotation axis. More...
double precision, dimension(3, nrotmx), save rotcen
 Rotation origin coordinates. More...
