This subroutine performs the velocity prediction step of the Navier Stokes equations for incompressible or slightly compressible flows for the coupled velocity components solver. More...
Functions/Subroutines | |
| subroutine | predvv (iappel, nvar, nscal, iterns, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, vel, vela, velk, da_uu, tslagr, coefav, coefbv, cofafv, cofbfv, ckupdc, smacel, frcxt, trava, dfrcxt, tpucou, trav, viscf, viscb, viscfi, viscbi, secvif, secvib, w1) |
Please refer to the predvv section of the theory guide for more informations.
| subroutine predvv | ( | integer | iappel, |
| integer | nvar, | ||
| integer | nscal, | ||
| integer | iterns, | ||
| integer | ncepdp, | ||
| integer | ncesmp, | ||
| integer, dimension(ncepdp) | icepdc, | ||
| integer, dimension(ncesmp) | icetsm, | ||
| integer, dimension(ncesmp,nvar) | itypsm, | ||
| double precision, dimension(ncelet) | dt, | ||
| double precision, dimension (3, ncelet) | vel, | ||
| double precision, dimension (3, ncelet) | vela, | ||
| double precision, dimension (3, ncelet) | velk, | ||
| double precision, dimension (6, ncelet) | da_uu, | ||
| double precision, dimension(ncelet,*) | tslagr, | ||
| double precision, dimension(3 ,nfabor) | coefav, | ||
| double precision, dimension(3,3,nfabor) | coefbv, | ||
| double precision, dimension(3 ,nfabor) | cofafv, | ||
| double precision, dimension(3,3,nfabor) | cofbfv, | ||
| double precision, dimension(6,ncepdp) | ckupdc, | ||
| double precision, dimension(ncesmp,nvar) | smacel, | ||
| double precision, dimension(3,ncelet) | frcxt, | ||
| double precision, dimension(ndim,ncelet) | trava, | ||
| double precision, dimension(3,ncelet) | dfrcxt, | ||
| double precision, dimension(6, ncelet) | tpucou, | ||
| double precision, dimension(3,ncelet) | trav, | ||
| double precision, dimension(*) | viscf, | ||
| double precision, dimension(nfabor) | viscb, | ||
| double precision, dimension(*) | viscfi, | ||
| double precision, dimension(nfabor) | viscbi, | ||
| double precision, dimension(nfac) | secvif, | ||
| double precision, dimension(nfabor) | secvib, | ||
| double precision, dimension(ncelet) | w1 | ||
| [in] | iappel | call number (1 or 2) |
| [in] | nscal | total number of scalars |
| [in] | iterns | index of the iteration on Navier-Stokes |
| [in] | ncepdp | number of cells with head loss |
| [in] | icepdc | index of cells with head loss |
| [in] | itypsm | type of mass source term for the variables |
| [in] | vel | velocity |
| [in] | vela | velocity at the previous time step |
| [in] | velk | velocity at the previous sub iteration (or vela) |
| [in,out] | da_uu | velocity matrix |
| [in] | tslagr | coupling term for the Lagrangian module |
| [in] | coefav | boundary condition array for the variable (explicit part) |
| [in] | coefbv | boundary condition array for the variable (implicit part) |
| [in] | cofafv | boundary condition array for the diffusion of the variable (explicit part) |
| [in] | cofbfv | boundary condition array for the diffusion of the variable (implicit part) |
| [in] | ckupdc | work array for the head loss |
| [in] | smacel | variable value associated to the mass source term (for ivar=ipr, smacel is the mass flux ) |
| [in] | frcxt | external forces making hydrostatic pressure |
| [in] | trava | working array for the velocity-pressure coupling |
| [out] | dfrcxt | variation of the external forces |
| [in] | tpucou | non scalar time step in case of velocity pressure coupling |
| [in] | trav | right hand side for the normalizing the residual |
| [in] | viscf | visc*surface/dist aux faces internes |
| [in] | viscb | visc*surface/dist aux faces de bord |
| [in] | viscfi | same as viscf for increments |
| [in] | viscbi | same as viscb for increments |
| [in] | secvif | secondary viscosity at interior faces |
| [in] | secvib | secondary viscosity at boundary faces |
| [in] | w1 | working array |
