7.1
predfl.f90 File Reference
Update the convective mass flux before the Navier Stokes equations (prediction and correction steps). More...
Functions/Subroutines
subroutine predfl (nvar, ncesmp, icetsm, dt, smacel)
This function computes a potential $ \varia $ solving the equation:
\[ D \left( \Delta t, \varia \right) = \divs \left( \rho \vect{u}^n\right) - \Gamma^n + \dfrac{\rho^n - \rho^{n-1}}{\Delta t} \]
This potential is then used to update the mass flux as follows:
\[ \dot{m}^{n+\frac{1}{2}}_\ij = \dot{m}^{n}_\ij - \Delta t \grad_\fij \varia \cdot \vect{S}_\ij \]
◆ predfl()
subroutine predfl ( integer  nvar,
integer  ncesmp,
integer, dimension(ncesmp)  icetsm,
double precision, dimension(ncelet)  dt,
double precision, dimension(ncesmp,nvar)  smacel
[in]nvartotal number of variables
[in]ncesmpnumber of cells with mass source term
[in]icetsmindex of cells with mass source term
[in]dttime step (per cell)
[in]smacelvariable value associated to the mass source term (for ivar=ipr, smacel is the mass flux $ \Gamma^n $)
