Functions/Subroutines | |
elemental pure integer function | ifacel (iside, ifac) |
elemental pure integer function | ifabor (ifac) |
elemental pure integer function | ipnfac (ifac) |
elemental pure integer function | nodfac (ipn) |
elemental pure integer function | ipnfbr (ifac) |
elemental pure integer function | nodfbr (ipn) |
elemental pure integer function | isolid (iporos, iel) |
integer | ndim |
integer, save | ncelet |
integer, save | ncel |
integer, save | nfac |
integer, save | nfabor |
integer, save | nnod |
integer, save | lndfac |
integer, save | lndfbr |
integer, dimension(:,:), pointer | ifacel_0 |
integer, dimension(:), pointer | ifabor_0 |
integer, dimension(:), pointer | ipnfac_0 |
integer, dimension(:), pointer | nodfac_0 |
integer, dimension(:), pointer | ipnfbr_0 |
integer, dimension(:), pointer | nodfbr_0 |
integer, dimension(:), pointer | ifmfbr |
integer, dimension(:), pointer | ifmcel |
integer, dimension(:), pointer | isympa |
double precision, dimension(:,:), pointer | xyzcen |
double precision, dimension(:,:), pointer | surfac |
double precision, dimension(:,:), pointer | surfbo |
double precision, dimension(:,:), pointer | suffac |
double precision, dimension(:,:), pointer | suffbo |
integer, dimension(:), pointer | isolid_0 |
double precision, dimension(:,:), pointer | cdgfac |
double precision, dimension(:,:), pointer | cdgfbo |
double precision, dimension(:,:), pointer | xyznod |
double precision, dimension(:), pointer | volume |
double precision, dimension(:), pointer | cell_f_vol |
double precision, dimension(:), pointer | surfan |
double precision, dimension(:), pointer | surfbn |
double precision, dimension(:), pointer | suffan |
double precision, dimension(:), pointer | suffbn |
double precision, dimension(:), pointer | dist |
double precision, dimension(:), pointer | distb |
double precision, dimension(:), pointer | pond |
double precision, dimension(:,:), pointer | dijpf |
double precision, dimension(:,:), pointer | diipb |
double precision, dimension(:,:), pointer | dofij |
elemental pure integer function mesh::ifabor | ( | integer, intent(in) | ifac | ) |
elemental pure integer function mesh::ifacel | ( | integer, intent(in) | iside, |
integer, intent(in) | ifac | ||
elemental pure integer function mesh::ipnfac | ( | integer, intent(in) | ifac | ) |
position of the first node of the each internal face in the array returned by nodfac (see Note 3: faces-vertices connectivity)
elemental pure integer function mesh::ipnfbr | ( | integer, intent(in) | ifac | ) |
position of the first node of the each boundary face in the array returned by nodfbr (see Note 3: faces-vertices connectivity)
elemental pure integer function mesh::isolid | ( | integer, intent(in) | iporos, |
integer, intent(in) | iel | ||
elemental pure integer function mesh::nodfac | ( | integer, intent(in) | ipn | ) |
indexed-numbers of the nodes of each internal face (see Note 3: faces-vertices connectivity)
elemental pure integer function mesh::nodfbr | ( | integer, intent(in) | ipn | ) |
indexed-numbers of the nodes of each boundary face (see Note 3: faces-vertices connectivity)
double precision, dimension(:,:), pointer diipb |
double precision, dimension(:,:), pointer dijpf |
double precision, dimension(:), pointer dist |
double precision, dimension(:), pointer distb |
double precision, dimension(:,:), pointer dofij |
integer, dimension(:), pointer ifabor_0 |
integer, dimension(:,:), pointer ifacel_0 |
integer, dimension(:), pointer ifmcel |
family number of the elements. See Note 1: ghost cells - (halos)
integer, dimension(:), pointer ifmfbr |
family number of the boundary faces. See Note 1: ghost cells - (halos)
integer, dimension(:), pointer ipnfac_0 |
integer, dimension(:), pointer ipnfbr_0 |
integer, dimension(:), pointer isolid_0 |
integer, dimension(:), pointer isympa |
integer, save lndfac |
size of the array nodfac
of internal faces - nodes connectivity (see Note 3: faces-vertices connectivity)
integer, save lndfbr |
size of the array nodfbr
of boundary faces - nodes connectivity (see Note 3: faces-vertices connectivity)
integer, save ncelet |
number of extended (real + ghost of the 'halo') cells. See Note 1: ghost cells - (halos)
integer, save nfabor |
number of boundary faces (see Note 2: internal faces)
integer, save nfac |
number of internal faces (see Note 2: internal faces)
integer, dimension(:), pointer nodfac_0 |
integer, dimension(:), pointer nodfbr_0 |
double precision, dimension(:), pointer pond |
double precision, dimension(:,:), pointer suffac |
double precision, dimension(:), pointer suffan |
double precision, dimension(:,:), pointer suffbo |
double precision, dimension(:,:), pointer surfac |
double precision, dimension(:,:), pointer surfbo |
