integer, dimension(ncharm), save | if1m |
| mean value of the tracer 1 representing the light volatiles released by the coal icha More...
integer, dimension(ncharm), save | if2m |
| mean value of the tracer 2 representing the heavy volatiles released by the coal icha More...
integer, save | if3m |
| mean value of the tracer 3 representing the carbon released as CO during coke burnout More...
integer, save | if4m |
| transported variable of countinuous phase (gas mixture) More...
integer, save | if5m |
integer, save | if6m |
integer, save | if7m |
integer, save | if8m |
integer, save | if9m |
integer, save | if4p2m |
| the variance associated with the tracer 4 representing the air (the mean value of this tracer is not transported, it can be deduced directly from the three others) More...
integer, save | ifvp2m |
| f1f2 variance More...
integer, dimension(nclcpm), save | ixck |
| coke mass fraction related to the class icla More...
integer, dimension(nclcpm), save | ixch |
| reactive coal mass fraction related to the class icla More...
integer, dimension(nclcpm), save | inp |
| number of particles of the class icla per kg of air-coal mixture More...
integer, dimension(nclcpm), save | ih2 |
| mass enthalpy of the coal of class icla , if we are in permeatic conditions More...
integer, dimension(nclcpm), save | ixwt |
| transported variable of dispersed phase (particle class) More...
integer, dimension(nclcpm), save | inagecp |
| Pointer to Np*age(particles) More...
integer, save | iage |
| Pointer to age of bulk. More...
integer, dimension(nclcpm), save | iv_p_x |
integer, dimension(nclcpm), save | iv_p_y |
integer, dimension(nclcpm), save | iv_p_z |
integer, dimension(ngazem), save | iym1 |
| mass fractions: More...
integer, save | irom1 |
| State variables of continuous phase (gas mixture) More...
integer, save | immel |
| molar mass of the gas mixture More...
integer, dimension(nclcpm), save | itemp2 |
| temperature of the particles of the class icla More...
integer, dimension(nclcpm), save | irom2 |
| density of the particles of the class icla More...
integer, dimension(nclcpm), save | idiam2 |
| diameter of the particles of the class icla More...
integer, dimension(nclcpm), save | ix2 |
| solid mass fraction of the class icla More...
integer, dimension(nclcpm), save | igmdch |
| disappearance rate of the reactive coal of the class icla More...
integer, dimension(nclcpm), save | igmhet |
| coke disappearance rate of the coke burnout of the class icla More...
integer, dimension(nclcpm), save | igmtr |
| Implicite part of the exchanges to the gas by molecular distribution. More...
integer, dimension(nclcpm), save | ighco2 |
| State variables of dispersed phase (particles class) More...
integer, dimension(nclcpm), save | igmdv1 |
| mass transfer caused by the release of light volatiles of the class icla More...
integer, dimension(nclcpm), save | igmdv2 |
| mass transfer caused by the release of heavy volatiles of the class icla More...
integer, dimension(nclcpm), save | igmsec |
integer, save | ibcarbone |
| Used for bulk balance of Carbon. More...
integer, save | iboxygen |
| Used for bulk balance of Oxygen. More...
integer, save | ibhydrogen |
| Used for bulk balance of Hydrogen. More...
