| double precision, dimension(:), pointer | tmmet |
| | time (in sec) of the meteo profile More...
| double precision, dimension(:), allocatable | zdmet |
| | altitudes of the dynamic profiles (read in the input meteo file) More...
| double precision, dimension(:), allocatable | dpdt_met |
| | Pressure drop integrated over a time step (used for automatic open boundaries) More...
| double precision, dimension(:,:), allocatable | mom_met |
| | Momentum for each level (used for automatic open boundaries) More...
| double precision, dimension(:,:), allocatable | mom |
| double precision, dimension(:), pointer | ztmet |
| | altitudes of the temperature profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | umet |
| | meteo u profiles (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | vmet |
| | meteo v profiles (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | wmet |
| | meteo w profiles - unused More...
| double precision, dimension(:,:), allocatable | ekmet |
| | meteo turbulent kinetic energy profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | epmet |
| | meteo turbulent dissipation profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | ttmet |
| | meteo temperature (Celsius) profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | qvmet |
| | meteo specific humidity profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | ncmet |
| | meteo specific droplet number profile (read in the input meteo file) More...
| double precision, dimension(:), allocatable | pmer |
| | Sea level pressure (read in the input meteo file) More...
| double precision, dimension(:), allocatable | xmet |
| | X axis coordinates of the meteo profile (read in the input meteo file) More...
| double precision, dimension(:), allocatable | ymet |
| | Y axis coordinates of the meteo profile (read in the input meteo file) More...
| double precision, dimension(:,:), allocatable | rmet |
| | density profile More...
| double precision, dimension(:,:), allocatable | tpmet |
| | potential temperature profile More...
| double precision, dimension(:,:), pointer | phmet |
| | hydrostatic pressure from Laplace integration More...
| integer, save | iymw |
| | total water content (for humid atmosphere) More...
| integer, save | intdrp = -1 |
| | intdrp—> total number of droplets (for humid atmosphere) More...
| integer, save | itempc |
| | temperature (in Celsius) More...
| integer, save | iliqwt |
| | liquid water content More...
| integer, save | imomst |
| | momentum source term field id (useful when iatmst > 0) More...
| integer(c_int), pointer, save | imeteo |
| | flag for reading the meteo input file More...
| integer(c_int), pointer, save | nbmetd |
| | numbers of altitudes for the dynamics More...
| integer(c_int), pointer, save | nbmett |
| | numbers of altitudes for the temperature and specific humidity More...
| integer(c_int), pointer, save | nbmetm |
| | numbers of time steps for the meteo profiles More...
| integer, dimension(nozppm), save | iprofm |
| | read zone boundary conditions from profile More...
| integer, dimension(:), allocatable, target | iautom |
| | automatic inlet/outlet boundary condition flag (0: not auto (default); 1,2: auto) When meteo momentum source terms are activated (iatmst > 0), iautom = 1 corresponds to a Dirichlet on the pressure and a Neumann on the velocity, whereas iautom = 2 imposes a Dirichlet on both pressure and velocity More...
| integer, save | initmeteo |
| | use meteo profile for variables initialization (0: not used; 1: used (default)) More...
| integer(c_int), pointer, save | iatmst |
| | add a momentum source term based on the meteo profile for automatic open boundaries More...
| integer, save | theo_interp |
| | flag for meteo velocity field interpolation More...
| real(c_double), pointer, save | ps |
| | reference pressure (to compute potential temp: 1.0d+5) More...
| integer(c_int), pointer, save | syear |
| | starting year More...
| integer(c_int), pointer, save | squant |
| | starting quantile More...
| integer(c_int), pointer, save | shour |
| | starting hour More...
| integer(c_int), pointer, save | smin |
| | starting min More...
| real(c_double), pointer, save | ssec |
| | starting second More...
| real(c_double), pointer, save | xlon |
| | longitude of the domain origin More...
| real(c_double), pointer, save | xlat |
| | latitude of the domain origin More...
| real(c_double), pointer, save | xl93 |
| | x coordinate of the domain origin in Lambert-93 More...
| real(c_double), pointer, save | yl93 |
| | y coordinate of the domain origin in Lambert-93 More...
| integer(c_int), pointer, save | nbmaxt |
| | Number of vertical levels (cf. 1D radiative scheme. More...
| integer, save | ihpm |
| | flag to compute the hydrostastic pressure by Laplace integration in the meteo profiles = 0 : bottom to top Laplace integration, based on P(sea level) (default) = 1 : top to bottom Laplace integration based on P computed for the standard atmosphere at z(nbmaxt) More...
| integer, save | ivert |
| | flag for the definition of the vertical grid More...
| integer, save | nvert |
| | number of vertical arrays More...
| integer, save | kvert |
| | number of levels (up to the top of the domain) More...
| integer, save | kmx |
| | Number of levels (up to 11000 m if ray1d used) (automatically computed) More...
| real(c_double), pointer, save | meteo_zi |
| | Height of the boundary layer. More...
| integer, save | iatra1 |
| | flag for the use of the 1d atmo radiative model More...
| integer, save | nfatr1 |
| | 1d radiative model pass frequency More...
| integer, save | iqv0 |
| | flag for the standard atmo humidity profile More...
| integer, save | idrayi |
| | pointer for 1D infrared profile More...
| integer, save | idrayst |
| | pointer for 1D solar profile More...
| integer, save | igrid |
| | grid formed by 1D profiles More...
| integer, save | irdu |
| | Flag for the computation of downward and upward infrared radiative fluxes 0: disabled 1: enabled. More...
| double precision, dimension(:,:), allocatable | xyvert |
| | horizontal coordinates of the vertical grid More...
| double precision, dimension(:), allocatable | zvert |
| | vertical grid for 1D radiative scheme initialize in cs_user_atmospheric_model.f90 More...
| double precision, dimension(:), allocatable | acinfe |
| | absorption for CO2 + 03 More...
| double precision, dimension(:), allocatable | dacinfe |
| | differential absorption for CO2 + 03 More...
| double precision, dimension(:,:), allocatable | aco2 |
| | absorption for CO2 only More...
| double precision, dimension(:,:), allocatable | aco2s |
| double precision, dimension(:,:), allocatable | daco2 |
| | differential absorption for CO2 only More...
| double precision, dimension(:,:), allocatable | daco2s |
| double precision, dimension(:), allocatable | acsup |
| | idem acinfe, flux descendant More...
| double precision, dimension(:), allocatable | acsups |
| double precision, dimension(:), allocatable | dacsup |
| | internal variable for 1D radiative model More...
| double precision, dimension(:), allocatable | dacsups |
| double precision, dimension(:), allocatable | tauzq |
| double precision, dimension(:), allocatable | tauz |
| double precision, dimension(:), allocatable | zq |
| double precision, save | tausup |
| double precision, dimension(:), allocatable | zray |
| double precision, dimension(:,:), allocatable | rayi |
| double precision, dimension(:,:), allocatable | rayst |
| double precision, dimension(:,:), allocatable | iru |
| | Upward and downward radiative fluxes (infrared, solar) along each vertical. More...
| double precision, dimension(:,:), allocatable | ird |
| double precision, dimension(:,:), allocatable | solu |
| double precision, dimension(:,:), allocatable | sold |
| integer, save | iatsoil |
| | iatsoil –> flag to use the ground model More...
| double precision, save | w1ini |
| | Water content of the first ground reservoir. More...
| double precision, save | w2ini |
| | Water content of the second ground reservoir. More...
| logical(c_bool), pointer, save | compute_z_ground |
| | Do we compute z ground every where? More...
| integer(c_int), pointer, save | modsub |
| | Option for subgrid models. More...
| integer(c_int), pointer, save | moddis |
| | Option for liquid water content distribution models. More...
| integer(c_int), pointer, save | modnuc |
| | Option for nucleation. More...
| integer(c_int), pointer, save | modsedi |
| | sedimentation flag More...
| integer(c_int), pointer, save | moddep |
| | deposition flag More...
| double precision, save | sigc |
| | adimensional : sigc=0.53 other referenced values are 0.28, 0.15 More...
| integer, save | init_at_chem |
| | force initilization in case of restart (this option is automatically set in lecamp) More...
| integer, save | kopint |
| | key id for optimal interpolation More...
| double precision, save | aod_o3_tot |
| | Aerosol optical properties. More...
| double precision, save | aod_h2o_tot |
| | adimensional : aod_h2o_tot=0.10 other referenced values are 0.06, 0.08 More...
| double precision, save | gaero_o3 |
| | Asymmetry factor for O3 (non-dimensional) climatic value gaero_o3=0.66. More...
| double precision, save | gaero_h2o |
| | Asymmetry factor for H2O (non-dimensional) climatic value gaero_h2o=0.64. More...
| double precision, save | piaero_o3 |
| | Single scattering albedo for O3 (non-dimensional) climatic value piaero_o3=0.84, other referenced values are 0.963. More...
| double precision, save | piaero_h2o |
| | Single scattering albedo for H2O (non-dimensional) climatic value piaero_h2o=0.84, other referenced values are 0.964. More...
| double precision, save | black_carbon_frac |
| | Fraction of Black carbon (non-dimensional): black_carbon_frac=1.d-8 for no BC. More...
| double precision, save | zaero |
| | Maximal height for aerosol distribution on the vertical important should be <= zqq(kmray-1); in meters : referenced value: zaero=6000. More...
