7.1
fldvar.f90 File Reference
Variables definition initialization, according to calculation type selected by the user. More...
Functions/Subroutines
subroutine fldvar (nmodpp)
subroutine add_variable_field (name, label, dim, ivar)
 add field defining a general solved variable, with default options More...
subroutine add_cdo_variable_field (name, label, dim, location_id, has_previous, ivar)
 Add a field defining a general solved variable, with default options This variable is solved with a CDO scheme. More...
subroutine add_user_scalar_fields
 add fields defining user solved scalar variables, with default options More...
subroutine add_model_scalar_field (name, label, iscal)
 add field defining a non-user solved scalar variable, with default options More...
subroutine add_model_field (name, label, dim, iscal)
 add field defining a non-user solved variable, with default options More...
subroutine add_model_field_indexes (f_id, iscal)
 add field indexes associated with a new non-user solved scalar variable, with default options More...
subroutine fldvar_check_nvar
 Check nvarmx is sufficient for the required number of variables. More...
subroutine init_var_cal_opt (id)
 Initialize the given variable calculation option structure with legacy values (iniini) allowing to later test user modification. More...
subroutine fldvar_check_nscapp
 Check nscamx is sufficient for the required number of model scalars. More...
integer(c_int) function cs_c_add_model_field_indexes (f_id)
 add field indexes associated with a new non-user solved variable, with default options More...
◆ add_cdo_variable_field()
subroutine add_cdo_variable_field ( character(len=*), intent(in)  name,
character(len=*), intent(in)  label,
integer, intent(in)  dim,
integer, intent(in)  location_id,
integer, intent(in)  has_previous,
integer, intent(out)  ivar
It is recommended not to define variable names of more than 16 characters, to get a clear execution log (some advanced writing levels take into account only the first 16 characters).
[in]namefield name
[in]labelfield default label, or empty
[in]dimfield dimension
[in]location_idid of the mesh location where the field is defined
[in]has_previousif greater than 0 then stores previous state
[out]ivarvariable number for defined field
◆ add_model_field()
subroutine add_model_field ( character(len=*), intent(in)  name,
integer, intent(out)  iscal
[in]namefield name
[out]iscalvariable number for defined field
◆ add_model_field_indexes()
subroutine add_model_field_indexes ( integer, intent(in)  f_id,
[in]f_idfield id
◆ add_model_scalar_field()
subroutine add_model_scalar_field ( character(len=*), intent(in)  name,
[in]namefield name
[out]iscalscalar number for defined field
◆ add_user_scalar_fields()
subroutine add_user_scalar_fields ( )
◆ add_variable_field()
subroutine add_variable_field ( character(len=*), intent(in)  name,
[in]namefield name
◆ cs_c_add_model_field_indexes()
integer(c_int) function cs_c_add_model_field_indexes ( integer(c_int), value  f_id)
[in]f_idfield id
◆ fldvar()
subroutine fldvar ( integer  nmodpp)
[out]nmodppnumber of activated particle physic models
◆ fldvar_check_nscapp()
subroutine fldvar_check_nscapp ( )
◆ fldvar_check_nvar()
subroutine fldvar_check_nvar ( )
◆ init_var_cal_opt()
subroutine init_var_cal_opt ( integer  id)
