integer, save | nfecra |
| standard output More...
character(len=13), save | ficdat |
| name of file, see usvort module. More...
integer, save | ntsuit |
| saving period of the restart files More...
integer, save | keylbl = -1 |
| field key for output label (label field keyword). More...
integer, save | keylog = -1 |
| field key for logging (Output log field keyword). More...
integer, save | keyvis = -1 |
| field key for postprocessing output (post_vis field keyword). More...
character(len=32), save | ficfpp |
| name of the thermochemical data file for combustion. More...
integer, save | impfpp |
| logical unit of the thermochemical data file. Useful in case of gas or pulverized coal combustion or electric arcs; More...
integer, save | indjon |
| use Janaf (=1) or not (=0) More...
character(len=80), save | emphis |
| directory in which the potential chronological record files generated by the Kernel will be written (path related to the execution directory) More...
character(len=80), save | prehis |
| prefix of history files More...
integer, dimension(2), save | impsth |
| mobile structure variables output unit More...
integer, save | tplfmt |
| time plot format (1: .dat, 2: .csv, 3: both) More...
integer, save | nthist |
| output period of the chronological record files: More...
double precision, save | frhist |
| frhist : output frequency in seconds More...
integer, save | ihistr |
| write indicator (O or 1) for history of internal mobile structures More...
integer | nusrmx |
| maximal number of user files More...
integer, dimension(nusrmx), save | impusr |
| unit numbers for potential user specified files. Useful if and only if the user needs files (therefore always useful, by security) More...
integer(c_int), pointer, save | ntlist |
| writing period in the execution report file. More...
integer, dimension(5), save | ipstdv |
| indicates the data to post-process on the boundary mesh (the boundary mesh must be associated with an active writer). ipstdv(key) indicates which fields should be created and output on the boundary, with key in ipstfo, ipstyp, ipsttp, ipstft, ipstnu. More...
integer | ipstfo |
| post-processed property: Efforts (0: none 1: all; 2: tangent; 4: normal) More...
integer | ipstyp |
| post-processed property: at the boundary More...
integer | ipsttp |
| post-processed property : at the boundary More...
integer | ipstft |
| post-processed property: thermal flux at the boundary (in ), More...
integer | ipstnu |
| post-processed property: Nusselt More...
