7.1
cs_user_source_terms.f90 File Reference
User subroutines for additional right-hand side source terms. More...
Functions/Subroutines
subroutine ustsnv (nvar, nscal, ncepdp, ncesmp, ivar, icepdc, icetsm, itypsm, dt, ckupdc, smacel, crvexp, crvimp)
 Additional right-hand side source terms for velocity components equation (Navier-Stokes) More...
subroutine ustssc (nvar, nscal, ncepdp, ncesmp, iscal, icepdc, icetsm, itypsm, dt, ckupdc, smacel, crvexp, crvimp)
 User subroutine. More...
subroutine ustsvv (nvar, nscal, ncepdp, ncesmp, iscal, icepdc, icetsm, itypsm, dt, ckupdc, smacel, crvexp, crvimp)
 Additional right-hand side source terms for vectorial equations (user vectors and specific physics vectors). More...
subroutine cs_user_turbulence_source_terms2 (nvar, nscal, ncepdp, ncesmp, f_id, icepdc, icetsm, itypsm, ckupdc, smacel, crvexp, crvimp)
 Additional right-hand side source terms for turbulence models and irijco =1. More...
See cs_user_source_terms and Examples of data settings for source terms with scalar in a channel for examples.
◆ cs_user_turbulence_source_terms2()
subroutine cs_user_turbulence_source_terms2 ( integer  nvar,
integer  nscal,
integer  ncepdp,
integer  ncesmp,
integer  f_id,
integer, dimension(ncepdp)  icepdc,
integer, dimension(ncesmp)  icetsm,
integer, dimension(ncesmp,nvar)  itypsm,
double precision, dimension(6,ncepdp)  ckupdc,
double precision, dimension(ncesmp,nvar)  smacel,
double precision, dimension(6,ncelet)  crvexp,
double precision, dimension(6,6,ncelet)  crvimp
Deprecated:
Use cs_user_source_terms instead.
Usage
The additional source term is decomposed into an explicit part (crvexp) and an implicit part (crvimp) that must be provided here. The resulting equations solved by the code are:
\[ \rho \norm{\vol{\celli}} \DP{\varia} + .... = \tens{crvimp} \varia + \vect{crvexp} \]
where $ \varia $ is the turbulence field of index f_id
Note that crvexp, crvimp are defined after the Finite Volume integration over the cells, so they include the "volume" term. More precisely:
  • crvexp is expressed in kg.m2/s2
  • crvimp is expressed in kg/s
The crvexp, crvimp arrays are already initialized to 0 before entering the routine. It is not needed to do it in the routine (waste of CPU time).
For stability reasons, Code_Saturne will not add -crvimp directly to the diagonal of the matrix, but Max(-crvimp,0). This way, the crvimp term is treated implicitely only if it strengthens the diagonal of the matrix. However, when using the second-order in time scheme, this limitation cannot be done anymore and -crvimp is added directly. The user should therefore test the negativity of crvimp by himself.
When using the second-order in time scheme, one should supply:
  • crvexp at time n
  • crvimp at time n+1/2
The selection of cells where to apply the source terms is based on a getcel command. For more info on the syntax of the getcel command, refer to the user manual or to the comments on the similar command getfbr in the routine cs_user_boundary_conditions.
[in]nvartotal number of variables
[in]nscaltotal number of scalars
[in]ncepdpnumber of cells with head loss terms
[in]ncesmpnumber of cells with mass source terms
[in]f_idfield index of the current turbulent variable
[in]icepdcindex number of cells with head loss terms
[in]icetsmindex number of cells with mass source terms
[in]itypsmtype of mass source term for each variable
[in]ckupdchead loss coefficient
[in]smacelvalue associated to each variable in the mass source terms or mass rate
[out]crvexpexplicit part of the source term
[out]crvimpimplicit part of the source term
◆ ustsnv()
subroutine ustsnv ( integer  nvar,
integer  nscal,
integer  ncepdp,
integer  ncesmp,
integer  ivar,
double precision, dimension(ncelet)  dt,
double precision, dimension(3,ncelet)  crvexp,
double precision, dimension(3,3,ncelet)  crvimp
Deprecated:
Usage
The additional source term is decomposed into an explicit part (crvexp) and an implicit part (crvimp) that must be provided here. The resulting equation solved by the code for a velocity is:
\[ \rho \norm{\vol{\celli}} \DP{\vect{u}} + .... = \tens{crvimp} \cdot \vect{u} + \vect{crvexp} \]
Note that crvexp and crvimp are defined after the Finite Volume integration over the cells, so they include the "volume" term. More precisely:
  • crvexp is expressed in kg.m/s2
The crvexp and crvimp arrays are already initialized to 0 before entering the the routine. It is not needed to do it in the routine (waste of CPU time).
Remarks
The additional force on $ x_i $ direction is given by crvexp(i, iel) + vel(j, iel)* crvimp(j, i, iel).
  • crvexp at time n
[in]ivarindex number of the current variable
[in]dttime step (per cell)
◆ ustssc()
subroutine ustssc ( integer  nvar,
integer  nscal,
integer  ncepdp,
integer  ncesmp,
integer  iscal,
double precision, dimension(ncelet)  crvexp,
double precision, dimension(ncelet)  crvimp
User subroutine.
Additional right-hand side source terms for scalar equations (user scalars and specific physics scalars).
Deprecated:
The routine is called for each scalar, user or specific physisc. It is therefore necessary to test the value of the scalar number iscal to separate the treatments of the different scalars (if (iscal.eq.p) then ....).
The additional source term is decomposed into an explicit part (crvexp) and an implicit part (crvimp) that must be provided here. The resulting equation solved by the code for a scalar f is:
\[ \rho*volume*\frac{df}{dt} + .... = crvimp*f + crvexp \]
  • crvexp is expressed in kg.[scal]/s, where [scal] is the unit of the scalar
  • crvexp at time n
The selection of cells where to apply the source terms is based on a getcel command. For more info on the syntax of the getcel command, refer to the user manual or to the comments on the similar command getfbr in the routine cs_user_boundary_conditions. WARNING: If scalar is the temperature, the resulting equation solved by the code is:
rho*Cp*volume*dT/dt + .... = crvimp*T + crvexp
  • crvexp is expressed in W
  • crvimp is expressed in W/K
STEP SOURCE TERMS
In case of a complex, non-linear source term, say F(f), for scalar f, the easiest method is to implement the source term explicitely.
df/dt = .... + F(f(n)) where f(n) is the value of f at time tn, the beginning of the time step.
This yields : crvexp = volume*F(f(n)) crvimp = 0
However, if the source term is potentially steep, this fully explicit method will probably generate instabilities. It is therefore wiser to partially implicit the term by writing:
df/dt = .... + dF/df*f(n+1) - dF/df*f(n) + F(f(n))
This yields: crvexp = volume*( F(f(n)) - dF/df*f(n) ) crvimp = volume*dF/df
[in]iscalindex number of the current scalar
[in]sourceterms or mass rate
◆ ustsvv()
subroutine ustsvv ( integer  nvar,
integer  nscal,
integer  ncepdp,
integer  ncesmp,
integer  iscal,
Deprecated:
The routine is called for each vector, user or specific physisc. It is therefore necessary to test the value of the vector number iscal to separate the treatments of the different vectors (if (iscal.eq.p) then ....).
The additional source term is decomposed into an explicit part (crvexp) and an implicit part (crvimp) that must be provided here. The resulting equation solved by the code for a vector f is:
\[ \rho*volume*\frac{d\vect{f}}{dt} + .... = \tens{crvimp}*\vect{f} + \vect{crvexp} \]
  • crvexp is expressed in kg.[scal]/s, where [scal] is vector unit
  • crvexp at time n
STEEP SOURCE TERMS
