7.1
cs_sles_petsc.h
1 #ifndef __CS_SLES_PETSC_H__
2 #define __CS_SLES_PETSC_H__
5  * Sparse Linear Equation Solvers using PETSc
31  * PETSc headers
34 #include <petscversion.h>
35 #include <petscconf.h>
36 #include <petscviewer.h>
37 #include <petscksp.h>
38
39 /*----------------------------------------------------------------------------
40  * Local headers
41  *----------------------------------------------------------------------------*/
43 #include "cs_base.h"
44 #include "cs_matrix.h"
45 #include "cs_sles.h"
46
47 /*----------------------------------------------------------------------------*/
48
50
52  * Macro definitions
54
55 /*============================================================================
56  * Type definitions
58
59 /*----------------------------------------------------------------------------
60  * Function pointer for user settings of a PETSc KSP solver setup.
61  *
62  * This function is called at the end of the setup stage for a KSP solver.
63  *
64  * Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions,
65  * this also allows setting further function pointers for pre and post-solve
66  * operations (see the PETSc documentation).
67  *
68  * Note: if the context pointer is non-NULL, it must point to valid data
69  * when the selection function is called so that value or structure should
70  * not be temporary (i.e. local);
71  *
72  * parameters:
73  * context <-> pointer to optional (untyped) value or structure
74  * ksp <-> pointer to PETSc KSP context
75  *----------------------------------------------------------------------------*/
76
77 typedef void
78 (cs_sles_petsc_setup_hook_t) (void *context,
79  KSP ksp);
80
81 /* Iterative linear solver context (opaque) */
82
83 typedef struct _cs_sles_petsc_t cs_sles_petsc_t;
84
85 /*============================================================================
86  * Global variables
87  *============================================================================*/
88
89 /*=============================================================================
90  * User function prototypes
91  *============================================================================*/
92
93 /*----------------------------------------------------------------------------
94  * Function pointer for user settings of a PETSc KSP solver setup.
95  *
96  * This function is called at the end of the setup stage for a KSP solver.
97  *
98  * Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions,
99  * this also allows setting further function pointers for pre and post-solve
100  * operations (see the PETSc documentation).
101  *
102  * Note: if the context pointer is non-NULL, it must point to valid data
103  * when the selection function is called so that value or structure should
104  * not be temporary (i.e. local);
105  *
106  * parameters:
107  * context <-> pointer to optional (untyped) value or structure
108  * ksp <-> pointer to PETSc KSP context
109  *----------------------------------------------------------------------------*/
110
111 void
112 cs_user_sles_petsc_hook(void *context,
113  KSP ksp);
114
115 /*=============================================================================
116  * Static inline public function prototypes
117  *============================================================================*/
118
119 /*----------------------------------------------------------------------------
120  * Initialize PETSc if needed
121  *----------------------------------------------------------------------------*/
122
123 void
124 cs_sles_petsc_init(void);
125
126 /*----------------------------------------------------------------------------
127  * \brief Output the settings of a KSP structure
128  *
129  * \param[in] ksp Krylov SubSpace structure
130  *----------------------------------------------------------------------------*/
131
132 static inline void
133 cs_sles_petsc_log_setup(KSP ksp)
134 {
135  PetscViewer v;
136
137  PetscViewerCreate(PETSC_COMM_WORLD, &v);
138  PetscViewerSetType(v, PETSCVIEWERASCII);
139  PetscViewerFileSetMode(v, FILE_MODE_APPEND);
140  PetscViewerFileSetName(v, "petsc_setup.log");
141
142  KSPView(ksp, v);
143  PetscViewerDestroy(&v);
144 }
145
146 /*=============================================================================
147  * Public function prototypes
148  *============================================================================*/
149
150 /*----------------------------------------------------------------------------
151  * Define and associate a PETSc linear system solver
152  * for a given field or equation name.
153  *
154  * If this system did not previously exist, it is added to the list of
155  * "known" systems. Otherwise, its definition is replaced by the one
156  * defined here.
157  *
158  * This is a utility function: if finer control is needed, see
159  * cs_sles_define() and cs_sles_petsc_create().
160  *
161  * In case of rotational periodicity for a block (non-scalar) matrix,
162  * the matrix type will be forced to MATSHELL ("shell") regardless
163  * of the option used.
164  *
165  * Note that this function returns a pointer directly to the iterative solver
166  * management structure. This may be used to set further options.
167  * If needed, cs_sles_find() may be used to obtain a pointer to the matching
168  * cs_sles_t container.
169  *
170  * parameters:
171  * f_id <-- associated field id, or < 0
172  * name <-- associated name if f_id < 0, or NULL
173  * matrix_type <-- PETSc matrix type
174  * setup_hook <-- pointer to optional setup epilogue function
175  * context <-> pointer to optional (untyped) value or structure
176  * for setup_hook, or NULL
177  *
178  * returns:
179  * pointer to newly created iterative solver info object.
180  *----------------------------------------------------------------------------*/
181
183 cs_sles_petsc_define(int f_id,
184  const char *name,
185  MatType matrix_type,
186  cs_sles_petsc_setup_hook_t *setup_hook,
187  void *context);
188
189 /*----------------------------------------------------------------------------
190  * Create PETSc linear system solver info and context.
191  *
192  * In case of rotational periodicity for a block (non-scalar) matrix,
193  * the matrix type will be forced to MATSHELL ("shell") regardless
194  * of the option used.
195  *
196  * parameters:
197  * matrix_type <-- PETSc matrix type
198  * setup_hook <-- pointer to optional setup epilogue function
199  * context <-> pointer to optional (untyped) value or structure
200  * for setup_hook, or NULL
201  *
202  * returns:
203  * pointer to newly created solver info object.
204  *----------------------------------------------------------------------------*/
205
207 cs_sles_petsc_create(MatType matrix_type,
208  cs_sles_petsc_setup_hook_t *setup_hook,
209  void *context);
210
211 /*----------------------------------------------------------------------------
212  * Create PETSc linear system solver info and context
213  * based on existing info and context.
214  *
215  * parameters:
216  * context <-- pointer to reference info and context
217  * (actual type: cs_sles_petsc_t *)
218  *
219  * returns:
220  * pointer to newly created solver info object
221  * (actual type: cs_sles_petsc_t *)
222  *----------------------------------------------------------------------------*/
223
224 void *
225 cs_sles_petsc_copy(const void *context);
226
227 /*----------------------------------------------------------------------------
228  * Destroy PETSc linear system solver info and context.
229  *
230  * parameters:
231  * context <-> pointer to PETSc linear solver info
232  * (actual type: cs_sles_petsc_t **)
233  *----------------------------------------------------------------------------*/
234
235 void
236 cs_sles_petsc_destroy(void **context);
237
238 /*----------------------------------------------------------------------------
239  * Setup PETSc linear equation solver.
240  *
241  * parameters:
242  * context <-> pointer to PETSc linear solver info
243  * (actual type: cs_sles_petsc_t *)
244  * name <-- pointer to system name
245  * a <-- associated matrix
246  * verbosity <-- verbosity level
247  *----------------------------------------------------------------------------*/
248
249 void
250 cs_sles_petsc_setup(void *context,
251  const char *name,
252  const cs_matrix_t *a,
253  int verbosity);
254
255 /*----------------------------------------------------------------------------
256  * Call PETSc linear equation solver.
257  *
258  * parameters:
259  * context <-> pointer to PETSc linear solver info
260  * (actual type: cs_sles_petsc_t *)
261  * name <-- pointer to system name
262  * a <-- matrix
263  * verbosity <-- verbosity level
264  * precision <-- solver precision
265  * r_norm <-- residue normalization
266  * n_iter --> number of iterations
267  * residue --> residue
268  * rhs <-- right hand side
269  * vx <-> system solution
270  * aux_size <-- number of elements in aux_vectors (in bytes)
271  * aux_vectors --- optional working area (internal allocation if NULL)
272  *
273  * returns:
274  * convergence state
275  *----------------------------------------------------------------------------*/
276
278 cs_sles_petsc_solve(void *context,
279  const char *name,
280  const cs_matrix_t *a,
281  int verbosity,
282  double precision,
283  double r_norm,
284  int *n_iter,
285  double *residue,
286  const cs_real_t *rhs,
287  cs_real_t *vx,
288  size_t aux_size,
289  void *aux_vectors);
290
291 /*----------------------------------------------------------------------------
292  * Free PETSc linear equation solver setup context.
293  *
294  * This function frees resolution-related data, such as
295  * buffers and preconditioning but does not free the whole context,
296  * as info used for logging (especially performance data) is maintained.
297
298  * parameters:
299  * context <-> pointer to PETSc linear solver info
300  * (actual type: cs_sles_petsc_t *)
301  *----------------------------------------------------------------------------*/
302
303 void
304 cs_sles_petsc_free(void *context);
305
306 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
324 bool
327  const cs_matrix_t *a,
328  const cs_real_t *rhs,
329  cs_real_t *vx);
330
331 /*----------------------------------------------------------------------------
332  * Log sparse linear equation solver info.
333  *
334  * parameters:
335  * context <-> pointer to PETSc linear solver info
336  * (actual type: cs_sles_petsc_t *)
337  * log_type <-- log type
338  *----------------------------------------------------------------------------*/
339
340 void
341 cs_sles_petsc_log(const void *context,
342  cs_log_t log_type);
343
344 /*----------------------------------------------------------------------------*/
350 /*----------------------------------------------------------------------------*/
351
352 void
354
355 /*----------------------------------------------------------------------------*/
356
358
359 #endif /* __CS_SLES_PETSC_H__ */
cs_sles_convergence_state_t cs_sles_petsc_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Definition: cs_sles_petsc.c:1319
Definition: cs_sles_petsc.h:83
void cs_sles_petsc_init(void)
Definition: cs_sles_petsc.c:505
void cs_user_sles_petsc_hook(void *context, KSP ksp)
Definition: cs_sles_petsc.c:489
bool cs_sles_petsc_error_post_and_abort(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Error handler for PETSc solver.
Definition: cs_sles_petsc.c:1531
void() cs_sles_petsc_setup_hook_t(void *context, KSP ksp)
Definition: cs_sles_petsc.h:78
void cs_sles_petsc_library_info(cs_log_t log_type)
Print information on PETSc library.
Definition: cs_sles_petsc.c:1651
cs_sles_petsc_t * cs_sles_petsc_create(MatType matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Definition: cs_sles_petsc.c:601
Definition: cs_defs.h:322
Definition: cs_matrix.h:93
void cs_sles_petsc_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Definition: cs_sles_petsc.c:748
void * cs_sles_petsc_copy(const void *context)
Create PETSc linear system solver info and context based on existing info and context.
Definition: cs_sles_petsc.c:678
Convergence status indicator.
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
double precision, save a
void cs_sles_petsc_free(void *context)
Definition: cs_sles_petsc.c:1485
cs_sles_petsc_t * cs_sles_petsc_define(int f_id, const char *name, MatType matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Define and associate a PETSc linear system solver for a given field or equation name.
Definition: cs_sles_petsc.c:555
cs_log_t
Definition: cs_log.h:48
void cs_sles_petsc_destroy(void **context)
Definition: cs_sles_petsc.c:702
void cs_sles_petsc_log(const void *context, cs_log_t log_type)
Definition: cs_sles_petsc.c:1571
