| void | cs_rad_transfer_wall_flux (int nvar, int ivart, int isothp[], cs_real_t tmin, cs_real_t tmax, cs_real_t tx, cs_real_t *rcodcl, cs_real_t tparop[], cs_real_t qincip[], cs_real_t textp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t hfconp[], cs_real_t flconp[], cs_real_t tempkp[]) |
| | Wall temperature computation with flux balance. More...
◆ cs_rad_transfer_wall_flux()
| void cs_rad_transfer_wall_flux |
int |
nvar, |
int |
ivart, |
int |
isothp[], |
cs_real_t |
tmin, |
cs_real_t |
tmax, |
cs_real_t |
tx, |
cs_real_t * |
rcodcl, |
cs_real_t |
tparop[], |
cs_real_t |
qincip[], |
cs_real_t |
textp[], |
cs_real_t |
xlamp[], |
cs_real_t |
epap[], |
cs_real_t |
epsp[], |
cs_real_t |
hfconp[], |
cs_real_t |
flconp[], |
cs_real_t |
tempkp[] |
- Parameters
| [in] | nvar | number of variable BC's |
| [in] | ivart | variable id of thermal variable |
| [in] | isothp | list of isothermal boundaries |
| [in] | tmin | minimum allowed temperature (clip to this value) |
| [in] | tmax | maximum allowed temperature (clip to this value) |
| [in] | tx | temperature relaxtion parameter |
| [in] | rcodcl | boundary condition values rcodcl[0] = Dirichlet value rcodcl[1] = exchange coefficient value. (infinite if no exchange) rcodcl[2] = flux density value (negative if gain) in w/m2 or rugosity height (m) if icodcl=6,
- for velocities, (vistl+visct)*gradu
- for pressure, dt*gradp,
- for scalars, cp*(viscls+visct/turb_schmidt)*gradt
| [out] | tparop | wall temperature in Kelvin |
| [in] | qincip | radiative flux density at boundaries |
| [in] | textp | exterior boundary temperature in degrees C |
| [in] | xlamp | thermal conductivity coefficient of wall faces (w/m/k) |
| [in] | epap | wall thickness (m) |
| [in] | epsp | wall emissivity |
| [in] | hfconp | boundary fluid exchange coefficient |
| [in] | flconp | boundary convective flux density |
| [in] | tempkp | temperature in Kelvin |
