7.1
cs_opts.h
1
#ifndef __CS_OPTS_H__
2
#define __CS_OPTS_H__
4
5
* Parsing of program arguments and associated initializations
6
8
9
This file is part of Code_Saturne, a general-purpose CFD tool.
11
Copyright (C) 1998-2021 EDF S.A.
13
14
15
16
version.
18
19
20
21
details.
23
24
25
26
28
30
* Local headers
32
34
#include "
cs_base.h
36
38
BEGIN_C_DECLS
* Macro definitions
45
* Type definitions
46
48
49
* Code_Saturne base options structure
50
51
52
typedef
struct
53
54
char
app_name
/* Application name */
55
56
/* Redirection of standard output */
57
58
bool
trace
/* Trace progress to stdout */
59
bool
logrp
/* Redirection for ranks > 0
60
(false: to "/dev/null", suppressed)
61
true: to "run_solver_n*.log" file) */
62
63
/* Signal handling */
64
65
bool
sig_defaults
/* use default signal handlers */
66
67
/* Other options */
68
69
bool
preprocess
/* Mesh preprocessing mode */
70
bool
verif
/* Mesh quality verification mode */
71
int
benchmark
/* Benchmark mode:
72
0: not used;
73
1: timing (CPU + Walltime) mode
74
2: MPI trace-friendly mode */
75
76
cs_opts_t
77
78
79
* Public function prototypes
80
81
82
83
* Define options and call some associated initializations
84
* based on command line arguments
85
86
* parameters:
87
* argc --> number of command line arguments
88
* argv --> array of command line arguments
89
* opts <-- options structure
90
91
92
void
93
cs_opts_define
int
argc,
94
char
*argv[],
95
cs_opts_t
*opts);
96
97
98
99
END_C_DECLS
100
101
#endif
/* __CS_OPTS_H__ */
cs_base.h
cs_opts_define
void cs_opts_define(int argc, char *argv[], cs_opts_t *opts)
Definition:
cs_opts.c:188
cs_opts_t::preprocess
bool preprocess
Definition:
cs_opts.h:69
cs_opts_t::benchmark
int benchmark
Definition:
cs_opts.h:71
BEGIN_C_DECLS
Definition:
cs_defs.h:510
cs_opts_t::trace
bool trace
Definition:
cs_opts.h:58
cs_opts_t::sig_defaults
bool sig_defaults
Definition:
cs_opts.h:65
cs_opts_t::verif
bool verif
Definition:
cs_opts.h:70
cs_opts_t::logrp
bool logrp
Definition:
cs_opts.h:59
cs_opts_t
Definition:
cs_opts.h:52
END_C_DECLS
Definition:
cs_defs.h:511
cs_opts_t::app_name
char * app_name
Definition:
cs_opts.h:54
src
base
cs_opts.h
Generated on Tue Dec 21 2021 18:01:58 for code_saturne by
