7.1
cs_gui_radiative_transfer.h
1 #ifndef __CS_GUI_RADIATIVE_TRANSFER_H__
2 #define __CS_GUI_RADIATIVE_TRANSFER_H__
5  * Management of the GUI parameters file: radiative transfer
31  * Local headers
34 #include "cs_base.h"
41  * Public function definitions
44 /*-----------------------------------------------------------------------------
45  * Free GUI-defined radiative transfer parameters
46  *----------------------------------------------------------------------------*/
48 void
50
51 /*----------------------------------------------------------------------------
52  * Read GUI-defined radiative transfer parameters
53  *----------------------------------------------------------------------------*/
54
55 void
57
58 /*----------------------------------------------------------------------------
59  * Set the radiative transfer absorption coefficient
60  *
61  * parameters:
62  * ck --> absorption coefficient at cells
63  *----------------------------------------------------------------------------*/
64
65 void
67
68 /*----------------------------------------------------------------------------
69  * Postprocessing settings for radiative transfer
70  *----------------------------------------------------------------------------*/
71
72 void
74
75 /*----------------------------------------------------------------------------
76  * Radiative transfer boundary conditions
77  *----------------------------------------------------------------------------*/
78
79 void
81  int nvar,
82  int ivart,
83  int *isothp,
84  double *epsp,
85  double *epap,
86  double *textp,
87  double *xlamp,
88  double *rcodcl);
89
91
93
94 #endif /* __CS_GUI_RADIATIVE_TRANSFER_H__ */
void cs_gui_radiative_transfers_finalize(void)
Definition: cs_gui_radiative_transfer.c:230
void cs_gui_radiative_transfer_bcs(const int itypfb[], int nvar, int ivart, int *isothp, double *epsp, double *epap, double *textp, double *xlamp, double *rcodcl)
Definition: cs_gui_radiative_transfer.c:435
void cs_gui_radiative_transfer_postprocess(void)
Definition: cs_gui_radiative_transfer.c:358
Definition: cs_defs.h:322
integer, dimension(:), pointer, save itypfb
Definition: pointe.f90:100
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
void cs_gui_rad_transfer_absorption(cs_real_t ck[])
Definition: cs_gui_radiative_transfer.c:329
void cs_gui_radiative_transfer_parameters(void)
Definition: cs_gui_radiative_transfer.c:256
