7.1
cs_eos.hxx
1 #ifndef __CS_EOS_HXX__
2 #define __CS_EOS_HXX__
5  * Equation of state
35  * Local headers
38 #include "cs_physical_properties.h"
40 #include "cs_base.h"
45  * Local Macro Definitions
49  * Structure definition
51
53  * Global variables definition
55
56 /*============================================================================
57  * Public function prototypes
59
60 /*----------------------------------------------------------------------------
61  * Define new EOS instances
62  *
63  * parameters:
64  * EOSMethod <-- table for EOS thermo properties (CATHARE, THETIS, ...)
65  * EOSRef <-- reference table for EOS thermo properties
66  *----------------------------------------------------------------------------*/
67
68 #ifdef __cplusplus
69 extern "C"
70 #endif
71 void
72 cs_eos_create(const char *EOSMethod,
73  char *EOSRef);
74
75 /*----------------------------------------------------------------------------
76  * Delete EOS instances
77  *----------------------------------------------------------------------------*/
78
79 #ifdef __cplusplus
80 extern "C"
81 #endif
82 void
83 cs_eos_destroy(void);
84
98
99 #ifdef __cplusplus
100 extern "C"
101 #endif
102 void
104  cs_phys_prop_type_t property,
105  const cs_lnum_t n_vals,
106  double var1[],
107  double var2[],
108  cs_real_t val[]);
109
110 /*----------------------------------------------------------------------------*/
111
112 #endif /* __CS_EOS_HXX__ */
void cs_eos_destroy(void)
Definition: cs_eos.cxx:152
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
Definition: cs_defs.h:322
cs_phys_prop_thermo_plane_type_t
Definition: cs_physical_properties.h:40
Definition: cs_defs.h:316
void cs_phys_prop_eos(cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, double var1[], double var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_eos.cxx:175
void cs_eos_create(const char *EOSMethod, char *EOSRef)
Definition: cs_eos.cxx:138
