7.1
cs_enforcement.h
1 #ifndef __CS_ENFORCEMENT_H__
2 #define __CS_ENFORCEMENT_H__
5  * Manage the list of solid cells and associated helper functions
29  * Local headers
32 #include "cs_defs.h"
33 #include "cs_cdo_connect.h"
34 #include "cs_cdo_local.h"
41  * Macro definitions
45  * Structure and type definitions
63 typedef enum {
64
71
72
77 typedef enum {
78
83
84
89 typedef struct {
90
93
96  int stride;
100
101 /*============================================================================
102  * Public function prototypes
103  *============================================================================*/
104
105 /*----------------------------------------------------------------------------*/
118 /*----------------------------------------------------------------------------*/
119
123  int stride,
124  cs_lnum_t n_elts,
125  const cs_lnum_t *elt_ids,
126  const cs_real_t *values);
127
136 /*----------------------------------------------------------------------------*/
137
140
141 /*----------------------------------------------------------------------------*/
147 /*----------------------------------------------------------------------------*/
148
149 void
151
152 /*----------------------------------------------------------------------------*/
159 /*----------------------------------------------------------------------------*/
160
161 void
162 cs_enforcement_param_log(const char *eqname,
163  const cs_enforcement_param_t *efp);
164
175 /*----------------------------------------------------------------------------*/
176
177 cs_real_t *
179  int n_params,
180  cs_enforcement_param_t **efp_array);
181
182 /*----------------------------------------------------------------------------*/
192 /*----------------------------------------------------------------------------*/
193
194 cs_real_t *
196  int n_params,
197  cs_enforcement_param_t **efp_array);
198
199 /*----------------------------------------------------------------------------*/
209 /*----------------------------------------------------------------------------*/
210
211 cs_real_t *
213  int n_params,
214  cs_enforcement_param_t **efp_array);
215
216 /*----------------------------------------------------------------------------*/
226 /*----------------------------------------------------------------------------*/
227
228 bool
229 cs_enforcement_dofs_cw(const cs_real_t *forced_values,
230  cs_cell_sys_t *csys,
231  cs_real_t *cw_forced_values);
232
233 /*----------------------------------------------------------------------------*/
234
236
237 #endif /* __CS_ENFORCEMENT_H__ */
Definition: cs_enforcement.h:79
cs_real_t * cs_enforcement_define_at_vertices(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for vertex-based scheme.
cs_enforcement_param_t * cs_enforcement_param_copy(const cs_enforcement_param_t *ref)
Copy a cs_enforcement_param_t structure.
cs_lnum_t n_elts
Definition: cs_enforcement.h:94
Definition: cs_defs.h:322
Definition: cs_cdo_local.h:146
Definition: cs_enforcement.h:80
cs_enforcement_type_t
Describe the way the values to enforce are defined.
Definition: cs_enforcement.h:77
bool cs_enforcement_dofs_cw(const cs_real_t *forced_values, cs_cell_sys_t *csys, cs_real_t *cw_forced_values)
Build the cell-wise value to enforce.
int stride
Definition: cs_enforcement.h:96
Definition: cs_enforcement.h:67
cs_lnum_t * elt_ids
Definition: cs_enforcement.h:95
cs_real_t * values
Definition: cs_enforcement.h:97
void cs_enforcement_param_log(const char *eqname, const cs_enforcement_param_t *efp)
Log a cs_enforcement_param_t structure.
Definition: cs_defs.h:316
Definition: cs_enforcement.h:65
cs_enforcement_selection_t
Type of entities used to define the selection where the enforcement takes place.
Definition: cs_enforcement.h:63
cs_enforcement_selection_t selection_type
Definition: cs_enforcement.h:91
cs_enforcement_param_t * cs_enforcement_param_create(cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Create and define a cs_enforcement_param_t structure.
Definition: cs_enforcement.h:66
cs_real_t * cs_enforcement_define_at_faces(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for face-based scheme.
Definition: cs_enforcement.h:92
void cs_enforcement_param_free(cs_enforcement_param_t **p_efp)
Free a cs_enforcement_param_t structure.
Definition: cs_enforcement.h:68
Set of data defining an enforcement.
Definition: cs_enforcement.h:89
cs_real_t * cs_enforcement_define_at_edges(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for edge-based scheme.
