Routines for atmospheric chemical scheme 3. More...
Functions/Subroutines | |
subroutine | kinetic_3 (nr, rk, temp, xlw, press, azi, att, option_photolysis) |
kinetic_3 More... | |
subroutine | fexchem_3 (ns, nr, y, rk, zcsourc, convers_factor, chem) |
fexchem_3 More... | |
subroutine | jacdchemdc_3 (ns, nr, y, convers_factor, convers_factor_jac, rk, jacc) |
jacdchemdc_3 More... | |
subroutine | rates_3 (ns, nr, rk, y, w) |
rates_3 More... | |
subroutine | dratedc_3 (ns, nr, rk, y, dw) |
dratedc_3 More... | |
subroutine | lu_decompose_3 (ns, m) |
lu_decompose_3 More... | |
subroutine | lu_solve_3 (ns, m, x) |
lu_solve_3 More... | |
subroutine dratedc_3 | ( | integer | ns, |
integer | nr, | ||
double precision, dimension(nr) | rk, | ||
double precision, dimension(ns) | y, | ||
double precision, dimension(nr,ns) | dw | ||
dratedc_3
Computation of derivatives of reaction rates
[in] | ns | total number of chemical species |
[in] | nr | total number of chemical reactions |
[in] | rk | kinetic rates |
[in] | y | concentrations vector |
[out] | dw | derivatives of reaction rates |
subroutine fexchem_3 | ( | integer | ns, |
integer | nr, | ||
double precision, dimension(ns) | zcsourc, | ||
double precision, dimension(ns) | convers_factor, | ||
double precision, dimension(ns) | chem | ||
fexchem_3
Computation of the chemical production terms
[in] | zcsourc | source term |
[in] | convers_factor | conversion factors |
[out] | chem | chemical production terms for every species |
subroutine jacdchemdc_3 | ( | integer | ns, |
integer | nr, | ||
double precision, dimension(ns,ns) | convers_factor_jac, | ||
double precision, dimension(ns,ns) | jacc | ||
jacdchemdc_3
Computation of the Jacobian matrix for atmospheric chemistry
[in] | convers_factor | conversion factors of mug/m3 to molecules/cm3 |
[in] | convers_factor_jac | conversion factors for the Jacobian matrix (Wmol(i)/Wmol(j)) |
[out] | jacc | Jacobian matrix |
subroutine kinetic_3 | ( | integer | nr, |
double precision | temp, | ||
double precision | xlw, | ||
double precision | press, | ||
double precision | azi, | ||
double precision | att, | ||
integer | option_photolysis | ||
kinetic_3
Computation of kinetic rates for atmospheric chemistry
[in] | option_photolysis | flag to activate or not photolysis reactions |
[in] | azi | solar zenith angle |
[in] | att | atmospheric attenuation variable |
[in] | temp | temperature |
[in] | press | pressure |
[in] | xlw | water massic fraction |
[out] | rk(nr) | kinetic rates |
subroutine lu_decompose_3 | ( | integer | ns, |
double precision, dimension(ns,ns) | m | ||
lu_decompose_3
Computation of LU factorization of matrix m
[in] | ns | matrix row number from the chemical species number |
[in,out] | m | on entry, an invertible matrix. On exit, an LU factorization of m |
subroutine lu_solve_3 | ( | integer | ns, |
double precision, dimension(ns,ns) | m, | ||
double precision, dimension(ns) | x | ||
lu_solve_3
Resolution of MY=X where M is an LU factorization computed by lu_decompose_3
[in] | m | an LU factorization computed by lu_decompose_3 |
[in,out] | x | on entry, the right-hand side of the equation. On exit, the solution of the equation |
subroutine rates_3 | ( | integer | ns, |
integer | nr, | ||
double precision, dimension(nr) | w | ||
rates_3
Computation of reaction rates
[out] | w | reaction rates |
