usatch.f90 File Reference
Routines for user defined atmospheric chemical scheme. More...
Functions/Subroutines
subroutine kinetic_4 (nr, rk, temp, xlw, press, azi, att, option_photolysis)
 kinetic_4 More...
subroutine fexchem_4 (ns, nr, y, rk, zcsourc, convers_factor, chem)
 fexchem_4 More...
subroutine ssh_jacdchemdc (ns, nr, y, convers_factor, convers_factor_jac, rk, jacc)
 ssh_jacdchemdc More...
subroutine ssh_lu_decompose (ns, m)
 ssh_lu_decompose More...
subroutine ssh_lu_solve (ns, m, x)
 ssh_lu_solve More...
subroutine ssh_dimensions (Ns, Nr, Nr_photolysis)
 ssh_dimensions More...
subroutine ssh_kinetic (Ns, Nbin_aer, nr, IHETER, ICLD, rk, temp, xlw, Press, azi, att, lwctmp, granulo, WetDiam, dsf_aero, ispeclost, Wmol, LWCmin, option_photolysis)
 ssh_kinetic More...
subroutine ssh_fexchem (NS, Nr, nemis, y, rk, ZCsourc, convers_factor, chem)
 ssh_fexchem More...
subroutine hetrxn (Ns, Nbin_aer, temp, press, ICLD, lwctmp, WetDiam, granulo, rk156, rk157, rk158, rk159, dsf_aero, ispeclost, Wmol, LWCmin)
 hetrxn More...
Remarks
These routines should be generated by SPACK
See CEREA: http://cerea.enpc.fr/polyphemus https://sshaerosol.wordpress.com/ https://github.com/sshaerosol/ssh-aerosol/
◆ fexchem_4()
subroutine fexchem_4 ( integer  ns,
integer  nr,
double precision, dimension(ns)  y,
double precision, dimension(nr)  rk,
double precision, dimension(ns)  zcsourc,
double precision, dimension(ns)  convers_factor,
double precision, dimension(ns)  chem
fexchem_4
Computes the chemical production terms
[in]nrtotal number of chemical reactions
[in]nstotal number of chemical species
[in]yconcentrations vector
[in]rkkinetic rates
[in]zcsourcsource term
[in]convers_factorconversion factors
[out]chemchemical production terms for every species
◆ hetrxn()
subroutine hetrxn ( integer  Ns,
integer  Nbin_aer,
double precision  temp,
double precision  press,
integer  ICLD,
double precision  lwctmp,
double precision, dimension(nbin_aer)  WetDiam,
double precision, dimension(nbin_aer)  granulo,
double precision  rk156,
double precision  rk157,
double precision  rk158,
double precision  rk159,
double precision, dimension(nbin_aer)  dsf_aero,
integer, dimension(4)  ispeclost,
double precision, dimension(ns)  Wmol,
double precision  LWCmin
hetrxn
Dummy function for compatibility with SPACK
◆ kinetic_4()
subroutine kinetic_4 ( integer  nr,
double precision  xlw,
double precision  azi,
double precision  att,
integer  option_photolysis
kinetic_4
Computation of kinetic rates for atmospheric chemistry
[in]option_photolysisflag to activate or not photolysis reactions
[in]azisolar zenith angle
[in]attatmospheric attenuation variable
[in]temptemperature
[in]presspressure
[in]xlwwater massic fraction
[out]rk(nr)kinetic rates
◆ ssh_dimensions()
subroutine ssh_dimensions ( integer  Ns,
integer  Nr,
integer  Nr_photolysis
ssh_dimensions
Rountine provided by SPACK. Return number of species / reactions
◆ ssh_fexchem()
subroutine ssh_fexchem ( integer  NS,
integer  Nr,
integer  nemis,
double precision, dimension(ns)  ZCsourc,
ssh_fexchem
Routine provided by SPACK. Computes the chemical production terms
[in]nemisflag to activate source terms
[in]rkkinetic rates
◆ ssh_jacdchemdc()
subroutine ssh_jacdchemdc ( integer  ns,
integer  nr,
double precision, dimension(ns,ns)  convers_factor_jac,
double precision, dimension(ns,ns)  jacc
ssh_jacdchemdc
Routine provided by SPACK. Computes the Jacobian matrix for chemistry
[in]convers_factorconversion factors of mug/m3 to molecules/cm3
[in]convers_factor_jacconversion factors for the Jacobian matrix (Wmol(i)/Wmol(j))
[in]rkkinetic rates
[out]jaccJacobian matrix
◆ ssh_kinetic()
subroutine ssh_kinetic ( integer  Ns,
integer  Nbin_aer,
integer  nr,
integer  IHETER,
integer  ICLD,
double precision  Press,
double precision  LWCmin,
ssh_kinetic
Routine provided by SPACK. Computes kinetic rates for the gas-phase.
◆ ssh_lu_decompose()
subroutine ssh_lu_decompose ( integer  ns,
double precision, dimension(ns,ns)  m
ssh_lu_decompose
Routine provided by SPACK. Computes LU factorization of matrix m
[in]nsmatrix row number from the chemical species number
[in,out]mon entry, an invertible matrix. On exit, an LU factorization of m
◆ ssh_lu_solve()
subroutine ssh_lu_solve ( integer  ns,
double precision, dimension(ns,ns)  m,
double precision, dimension(ns)  x
ssh_lu_solve
Resolution of MY=X where M is an LU factorization computed by lu_decompose. Routine provided by SPACK.
[in]man LU factorization computed by lu_decompose
[in,out]xon entry, the right-hand side of the equation
