cs_lagr_injection_set_t Struct Reference
#include <cs_lagr.h>
+ Collaboration diagram for cs_lagr_injection_set_t:
Data Fields
int zone_id
int set_id
int location_id
cs_gnum_t n_inject
int injection_frequency
cs_lagr_injection_profile_compute_tinjection_profile_func
void * injection_profile_input
int velocity_profile
int temperature_profile
int coal_number
int cluster
int aggregat_class_id
cs_real_t aggregat_fractal_dim
cs_real_t velocity_magnitude
cs_real_t velocity [3]
cs_real_t temperature
cs_real_t diameter
cs_real_t diameter_variance
cs_real_t shape
cs_real_t orientation [3]
cs_real_t radii [3]
cs_real_t angular_vel [3]
cs_real_t euler [4]
cs_real_t shape_param [4]
cs_real_t density
cs_real_t fouling_index
cs_real_t cp
cs_real_t stat_weight
cs_real_t flow_rate
cs_real_t emissivity
Particle injection parameters for a given zone and particle set
Field Documentation
◆ aggregat_class_id
aggregate class id
◆ aggregat_fractal_dim
aggregate fractal dimension
◆ angular_vel
cs_real_t angular_vel[3]
particle angular velocity (if shape model is activated
◆ cluster
int cluster
statistical cluster id
◆ coal_number
int coal_number
particle coal number (if physical_model =2)
◆ cp
particle specific heat
◆ density
cs_real_t density
particle density
◆ diameter
cs_real_t diameter
particle diameter
◆ diameter_variance
particle diameter variance
◆ emissivity
particle emissivity
◆ euler
cs_real_t euler[4]
particle four Euler parameters (if shape model is activated
◆ flow_rate
cs_real_t flow_rate
flow rate
◆ fouling_index
fouling index
◆ injection_frequency
injection frequency (if =< 0, only at first iteration)
◆ injection_profile_func
cs_lagr_injection_profile_compute_t* injection_profile_func
optional injection profile computation function, or NULL
◆ injection_profile_input
void* injection_profile_input
optional injection profile input data, or NULL
◆ location_id
int location_id
associated mesh location id
◆ n_inject
cs_gnum_t n_inject
number of particles injected at a time for this class and zone
◆ orientation
cs_real_t orientation[3]
particle orintation for spheroids
◆ radii
cs_real_t radii[3]
particle radii for ellispoids
◆ set_id
int set_id
associated set id
◆ shape
cs_real_t shape
particle shape for spheroids (if shape model is activated
◆ shape_param
cs_real_t shape_param[4]
particle shape parameters for ellispoids (alpha_0, beta_0, gamma_0, chi _0) in Brenner 1964 (if shape model is activated
◆ stat_weight
particle statitistical weight
◆ temperature
particle temperature
◆ temperature_profile
temperature condition type:
  • 0 fluid temperature
  • 1 imposed temperature
◆ velocity
cs_real_t velocity[3]
particle velocity components
◆ velocity_magnitude
particle velocity magnitude
◆ velocity_profile
velocity condition type:
  • -1 imposed fluid velocity (from cell velocity)
  • 0 imposed velocity along the normal of the boundary face
  • 1 imposed velocity: velocity must be set.
◆ zone_id
int zone_id
associated zone id
