cs_atmo_option_t Struct Reference
#include <cs_atmo.h>
+ Collaboration diagram for cs_atmo_option_t:
Data Fields
int syear
int squant
int shour
int smin
cs_real_t ssec
cs_real_t longitude
cs_real_t latitude
cs_real_t x_l93
cs_real_t y_l93
int nbmetd
int nbmett
int nbmetm
int nbmaxt
cs_real_t domain_orientation
bool compute_z_ground
int open_bcs_treatment
int sedimentation_model
int deposition_model
int nucleation_model
int subgrid_model
int distribution_model
int meteo_profile
char * meteo_file_name
cs_real_t meteo_dlmo
cs_real_t meteo_z0
cs_real_t meteo_zref
cs_real_t meteo_zi
cs_real_t meteo_zu1
cs_real_t meteo_zu2
cs_real_t meteo_zt1
cs_real_t meteo_zt2
cs_real_t meteo_uref
cs_real_t meteo_u1
cs_real_t meteo_u2
cs_real_t meteo_ustar0
cs_real_t meteo_wstar0
cs_real_t meteo_angle
cs_real_t meteo_t0
cs_real_t meteo_t1
cs_real_t meteo_t2
cs_real_t meteo_tstar
cs_real_t meteo_psea
cs_real_tz_temp_met
cs_real_ttime_met
cs_real_thyd_p_met
Field Documentation
◆ compute_z_ground
Option to compute ground elevation in the domain
◆ deposition_model
Deposition flag
◆ distribution_model
Option for liquid water content distribution models 1: all or nothing 2: Gaussian distribution
◆ domain_orientation
Domain orientation (angle in degree between y direction and north), 0 by default
◆ hyd_p_met
cs_real_t* hyd_p_met
◆ latitude
cs_real_t latitude
latitude of the domain origin
◆ longitude
cs_real_t longitude
longitude of the domain origin
◆ meteo_angle
Meteo wind direction
◆ meteo_dlmo
Meteo Monin obukhov inverse length
◆ meteo_file_name
char* meteo_file_name
Meteo file
◆ meteo_profile
int meteo_profile
Use meteo profile:
  • 0: not use
  • 1: use a meteo file
  • 2: directly enter values large scale values
  • 3: fill directly meteo_* fields
◆ meteo_psea
Meteo pressure at sea level
◆ meteo_t0
cs_real_t meteo_t0
Meteo reference temperature at 2m
◆ meteo_t1
cs_real_t meteo_t1
Meteo reference temperature 1
◆ meteo_t2
cs_real_t meteo_t2
Meteo reference temperature 2
◆ meteo_tstar
Meteo reference ground friction temperature
◆ meteo_u1
cs_real_t meteo_u1
Meteo reference velocity 1
◆ meteo_u2
cs_real_t meteo_u2
Meteo reference velocity 2
◆ meteo_uref
◆ meteo_ustar0
Meteo reference ground friction velocity
◆ meteo_wstar0
Meteo reference convective velocity
◆ meteo_z0
cs_real_t meteo_z0
Meteo reference roughness
◆ meteo_zi
cs_real_t meteo_zi
Meteo Boundary layer elevation
◆ meteo_zref
Meteo reference elevation for reference velocity
◆ meteo_zt1
cs_real_t meteo_zt1
Meteo reference elevation for reference temperature 1
◆ meteo_zt2
cs_real_t meteo_zt2
Meteo reference elevation for reference temperature 2
◆ meteo_zu1
cs_real_t meteo_zu1
Meteo reference elevation for reference velocity 1
◆ meteo_zu2
cs_real_t meteo_zu2
Meteo reference elevation for reference velocity 2
◆ nbmaxt
int nbmaxt
◆ nbmetd
int nbmetd
numbers of altitudes for the dynamics
◆ nbmetm
int nbmetm
numbers of time steps for the meteo profiles
Number of vertical levels
◆ nbmett
int nbmett
numbers of altitudes for the temperature and specific humidity
◆ nucleation_model
Option for nucleation 0: without nucleation 1: Pruppacher and Klett 1997 2: Cohard et al. 1998,1999 3: Abdul-Razzak et al. 1998,2000 logaritmic standard deviation of the log-normal law of the droplet spectrum
◆ open_bcs_treatment
◆ sedimentation_model
Sedimentation flag
◆ shour
int shour
Starting hour
◆ smin
int smin
Starting minute
◆ squant
int squant
Starting quantile
◆ ssec
cs_real_t ssec
Starting second
◆ subgrid_model
int subgrid_model
Option for subgrid models 0: the simplest parameterization (for numerical verifications) 1: Bechtold et al. 1995 (Luc Musson-Genon) 2: Bouzereau et al. 2004 3: Cuijpers and Duynkerke 1993, Deardorff 1976, Sommeria and Deardorff 1977
◆ syear
int syear
Starting year
◆ time_met
cs_real_t* time_met
◆ x_l93
cs_real_t x_l93
x coordinate of the domain origin in Lambert-93
◆ y_l93
cs_real_t y_l93
y coordinate of the domain origin in Lambert-93
◆ z_temp_met
cs_real_t* z_temp_met
