This subroutine performs the solving of the Reynolds stress components in
RANS (LRR) turbulence model.
More...
| subroutine | resrij (nvar, nscal, ncesmp, ivar, isou, icetsm, itypsm, dt, produc, gradro, smacel, viscf, viscb, tslagi, smbr, rovsdt) |
◆ resrij()
| subroutine resrij |
integer |
nvar, |
integer |
nscal, |
integer |
ncesmp, |
integer |
ivar, |
integer |
isou, |
integer, dimension(ncesmp) |
icetsm, |
integer, dimension(ncesmp,nvar) |
itypsm, |
double precision, dimension(ncelet) |
dt, |
double precision, dimension(6,ncelet) |
produc, |
double precision, dimension(3,ncelet) |
gradro, |
double precision, dimension(ncesmp,nvar) |
smacel, |
double precision, dimension(nfac) |
viscf, |
double precision, dimension(nfabor) |
viscb, |
tslagi, |
smbr, |
rovsdt |
- Parameters
| [in] | nscal | total number of scalars |
| [in] | ivar | variable number |
| [in] | isou | local variable number (7 here) |
| [in] | itypsm | type of mass source term for each variable (see cs_user_mass_source_terms) |
| [in] | produc | work array for production |
| [in] | gradro | work array for grad rom (without rho volume) only for iturb=30 |
| [in] | smacel | value associated to each variable in the mass source terms or mass rate (see cs_user_mass_source_terms) |
| [in] | viscf | visc*surface/dist at internal faces |
| [in] | viscb | visc*surface/dist at edge faces |
| [in] | tslagi | implicit source terms for the Lagrangian module |
| [in] | smbr | working array |
| [in] | rovsdt | working array |
