This subroutine performs the pressure correction step of the Navier Stokes equations for incompressible or slightly compressible flows for the coupled velocity components solver. More...
Functions/Subroutines | |
subroutine | resopv (nvar, iterns, ncesmp, nfbpcd, ncmast, icetsm, ifbpcd, ltmast, isostd, dt, vel, da_uu, coefav, coefbv, coefa_dp, coefb_dp, smacel, spcond, svcond, frcxt, dfrcxt, tpucou, viscf, viscb, tslagr) |
The mass flux is then updated as follows:
Remarks:
Please refer to the resopv section of the theory guide for more informations.
subroutine resopv | ( | integer | nvar, |
integer | iterns, | ||
integer | ncesmp, | ||
integer | nfbpcd, | ||
integer | ncmast, | ||
integer, dimension(ncesmp) | icetsm, | ||
integer, dimension(nfbpcd) | ifbpcd, | ||
integer, dimension(ncelet) | ltmast, | ||
integer, dimension(nfabor+1) | isostd, | ||
double precision, dimension (1:ncelet), target | dt, | ||
double precision, dimension (3 ,ncelet) | vel, | ||
double precision, dimension (6 ,ncelet) | da_uu, | ||
double precision, dimension(3 ,nfabor) | coefav, | ||
double precision, dimension(3,3,nfabor) | coefbv, | ||
double precision, dimension(nfabor) | coefa_dp, | ||
double precision, dimension(nfabor) | coefb_dp, | ||
double precision, dimension(ncesmp,nvar) | smacel, | ||
double precision, dimension(nfbpcd,nvar) | spcond, | ||
double precision, dimension(ncelet,nvar) | svcond, | ||
double precision, dimension(3,ncelet) | frcxt, | ||
double precision, dimension(3,ncelet) | dfrcxt, | ||
double precision, dimension (1:6,1:ncelet), target | tpucou, | ||
double precision, dimension(nfac) | viscf, | ||
double precision, dimension(nfabor) | viscb, | ||
double precision, dimension(ncelet,*) | tslagr | ||
[in] | nvar | total number of variables |
[in] | iterns | Navier-Stokes iteration number |
[in] | ncesmp | number of cells with mass source term |
[in] | nfbpcd | number of faces with condensation source term |
[in] | ncmast | number of cells with condensation source terms |
[in] | icetsm | index of cells with mass source term |
[in] | ifbpcd | index of faces with condensation source term |
[in] | ltmast | index of cells with condensation source terms |
[in] | isostd | indicator of standard outlet and index of the reference outlet face |
[in] | dt | time step (per cell) |
[in] | vel | velocity |
[in,out] | da_uu | velocity matrix |
[in] | coefav | boundary condition array for the variable (explicit part) |
[in] | coefbv | boundary condition array for the variable (implicit part) |
[in] | coefa_dp | boundary conditions for the pressure increment |
[in] | coefb_dp | boundary conditions for the pressure increment |
[in] | smacel | variable value associated to the mass source term (for ivar=ipr, smacel is the mass flux ![]() |
[in] | spcond | variable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate ![]() |
[in] | svcond | variable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate ![]() |
[in] | frcxt | external forces making hydrostatic pressure |
[in] | dfrcxt | variation of the external forces composing the hydrostatic pressure |
[in] | tpucou | non scalar time step in case of velocity pressure coupling |
[in] | viscf | visc*surface/dist aux faces internes |
[in] | viscb | visc*surface/dist aux faces de bord |
[in] | tslagr | coupling term for the Lagrangian module |
