+ Collaboration diagram for Mixture properties:
Data Types
struct  cs_vof_parameters_t
 VOF model parameters. Void fraction variable tracks fluid 2. More...
real(c_double), pointer, save rho1
 reference density of fluid 1 (kg/m3). By convention, liquid phase for cavitation model. More...
real(c_double), pointer, save rho2
 reference density of fluid 2 (kg/m3). By convention, gas phase for cavitation model. More...
real(c_double), pointer, save mu1
 reference molecular viscosity of fluid 1 (kg/(m s)) More...
real(c_double), pointer, save mu2
 reference molecular viscosity of fluid 2 (kg/(m s)) More...
real(c_double), pointer, save cdrift
 Drift flux factor. More...
real(c_double), pointer, save kdrift
 volume fraction gradient factor in drift velocity More...
unsigned vof_model
double rho1
double rho2
double mu1
double mu2
int idrift
double cdrift
double kdrift
◆ cdrift [1/2]
Drift flux factor.
◆ cdrift [2/2]
cdrift
Flux factor parameter. In case of drift flux, factor of the local flux compared to the global max flux.
◆ idrift
idrift
drift velocity model
  • 0: drift model disable
  • 1: field inner_drift_velocity_flux is used Deshpande's model
  • 2: field drift_velocity is used User-defined drift velocity field
◆ kdrift [1/2]
◆ kdrift [2/2]
kdrift
Turbulent like diffusion effect (m2/s). In case of drift velocity, factor of a volume fraction gradient
◆ mu1 [1/2]
◆ mu1 [2/2]
mu1
◆ mu2 [1/2]
◆ mu2 [2/2]
mu2
◆ rho1 [1/2]
◆ rho1 [2/2]
rho1
◆ rho2 [1/2]
◆ rho2 [2/2]
rho2
◆ vof_model
vof_model
Volume of Fluid model - sum of masks defining VoF model and submodels. See defined masks in Masks used to specify Volume of Fluid models.
