Source terms
integer(c_int), pointer, save ltsdyn
 activation (=1) or not (=0) of the two-way coupling on the dynamics of the continuous phase. Useful if iilagr = 2 and iccvfg = 0 More...
integer(c_int), pointer, save ltsmas
 activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = 2, cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::impvar = 1 More...
integer(c_int), pointer, save ltsthe
 if cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::itpvar = 1, ltsthe !> activates (=1) or not (=0) the two-way coupling on temperature. if cs_lagr_model_t::physical_model = 2, ltsthe activates (=1) or not (=0) the two-way coupling on the eulerian variables related to pulverized coal combustion. Useful if iilagr = 2 More...
integer(c_int), pointer, save itsli
 implicit source term for the continuous phase velocity and for the turbulent energy if the $k-\varepsilon$ model is used More...
integer(c_int), pointer, save itske
 explicit source term for the turbulent dissipation and the turbulent energy if the $k-\varepsilon$ turbulence model is used for the continuous phase More...
integer(c_int), pointer, save itste
 explicit thermal source term for the thermal scalar of the continuous phase More...
integer(c_int), pointer, save itsti
 implicit thermal source term for the thermal scalar of the continuous phase More...
integer(c_int), pointer, save itsmas
 mass source term More...
integer(c_int), dimension(:), pointer, save itsmv1
 source term for the light volatile matters More...
integer(c_int), dimension(:), pointer, save itsmv2
 source term for the heavy volatile matters More...
integer(c_int), pointer, save itsco
 source term for the carbon released during heterogeneous combustion More...
◆ itsco
◆ itske
◆ itsli
◆ itsmas
mass source term
◆ itsmv1
◆ itsmv2
◆ itste
◆ itsti
◆ ltsdyn
◆ ltsmas
◆ ltsthe
