Physical properties are using the field API. See cs_user_boundary_conditions for some examples. More...
+ Collaboration diagram for Physical properties:
integer, save irom
 Density at the current time step (equal to icrom, kept for compatibility) More...
integer, save iviscl
 dynamic molecular viscosity (in kg/(m.s)) More...
integer, save ivisct
 dynamic turbulent viscosity More...
integer, dimension(nestmx), save iestim
 error estimator for Navier-Stokes More...
integer, save kimasf
 interior and boundary convective mass flux key ids of the variables More...
integer, save kbmasf
integer, save kvisl0
 constant diffusivity field id key for scalars More...
integer, save kivisl
 variable diffusivity field id key for scalars More...
integer, save kscacp
 do scalars behave as a temperature (regarding multiplication by Cp) ? More...
integer, save kromsl
 variable density field id key for scalars More...
integer, save kstprv
 source terms at previous time step for 2nd order More...
integer, save kst
 source terms at the current time step (used for limiters) More...
integer, save ksigmas
 turbulent schmidt key for scalars More...
integer, dimension(nvarmx), save ifluaa
 convective mass flux of the variables at the previous time-step More...
integer, save icrom
 cell density field ids of the variables More...
integer, save ibrom
 boundary density field ids of the variables More...
integer, save ipori
 field ids of the cell porosity More...
integer, save iporf
integer, save ismago
 dynamic constant of Smagorinsky More...
integer, save ivsten
 field ids of the anisotropic viscosity More...
integer, save ivstes
integer, save icour
 Courant number. More...
integer, save ifour
 Fourier number. More...
integer, save iprtot
 Total pressure at cell centers $ P_{tot} = P^\star +\rho \vect{g} \cdot (\vect{x}-\vect{x}_0) $. More...
integer, save ivisma
 Mesh velocity viscosity for the ALE module. More...
integer, dimension(nscamx), save iustdy
 pointer for dilatation source terms More...
integer, save itsrho
 pointer for global dilatation source terms More...
integer, save ibeta
 pointer for thermal expansion coefficient More...
integer, save iddgas
 pointer for deduced mass fraction in case of gas mix More...
integer, save igmxml
 pointer for gas mix molar mass More...
integer, save iforbr
 field id of the stresses at boundary (if post-processed) More...
integer, save iyplbr
 field id of $y^+$ at boundary (if post-processed) More...
integer, save itempb
 field id of temperature at boundary More...
integer, save is2kw
 field id of the square of the norm of the deviatoric part of the deformation rate tensor ( $S^2=2S_{ij}^D S_{ij}^D$). Field defined only with the $k-\omega$ (SST) turbulence model More...
integer, save idivukw
 field id of the divergence of the velocity. More precisely, it is the trace of the velocity gradient (and not a finite volume divergence term). In the cell iel, $div(\vect{u})$ is given by divukw(iel1). This array is defined only with the $k-\omega$ SST turbulence model (because in this case it may be calculated at the same time as $S^2$) More...
integer, save istraio
 field id of the strain rate tensor at the previous time step More...
◆ ibeta
integer, save ibeta
◆ ibrom
integer, save ibrom
◆ icour
integer, save icour
Courant number.
◆ icrom
integer, save icrom
◆ iddgas
◆ idivukw
◆ iestim
◆ ifluaa
◆ iforbr
◆ ifour
integer, save ifour
Fourier number.
◆ igmxml
◆ iporf
integer, save iporf
◆ ipori
integer, save ipori
◆ iprtot
◆ irom
integer, save irom
◆ is2kw
integer, save is2kw
◆ ismago
◆ istraio
◆ itempb
◆ itsrho
◆ iustdy
◆ iviscl
◆ ivisct
◆ ivisma
Remarks
might be orthotropic
◆ ivsten
Remarks
turbulent or Darcy module anisotropic diffusion
◆ ivstes
◆ iyplbr
◆ kbmasf
◆ kimasf
◆ kivisl
◆ kromsl
◆ kscacp
◆ ksigmas
◆ kst
integer, save kst
◆ kstprv
◆ kvisl0
