Mesh Fortran structure, pointers to the C structure
Functions/Subroutines
elemental pure integer function ifacel (iside, ifac)
elemental pure integer function ifabor (ifac)
elemental pure integer function ipnfac (ifac)
elemental pure integer function nodfac (ipn)
elemental pure integer function ipnfbr (ifac)
elemental pure integer function nodfbr (ipn)
elemental pure integer function isolid (iporos, iel)
integer ndim
integer, save ncelet
integer, save ncel
integer, save nfac
integer, save nfabor
integer, save nnod
integer, save lndfac
integer, save lndfbr
integer, dimension(:,:), pointer ifacel_0
integer, dimension(:), pointer ifabor_0
integer, dimension(:), pointer ipnfac_0
integer, dimension(:), pointer nodfac_0
integer, dimension(:), pointer ipnfbr_0
integer, dimension(:), pointer nodfbr_0
integer, dimension(:), pointer ifmfbr
integer, dimension(:), pointer ifmcel
integer, dimension(:), pointer isympa
double precision, dimension(:,:), pointer xyzcen
double precision, dimension(:,:), pointer surfac
double precision, dimension(:,:), pointer surfbo
double precision, dimension(:,:), pointer suffac
double precision, dimension(:,:), pointer suffbo
integer, dimension(:), pointer isolid_0
double precision, dimension(:,:), pointer cdgfac
double precision, dimension(:,:), pointer cdgfbo
double precision, dimension(:,:), pointer xyznod
double precision, dimension(:), pointer volume
double precision, dimension(:), pointer cell_f_vol
double precision, dimension(:), pointer surfan
double precision, dimension(:), pointer surfbn
double precision, dimension(:), pointer suffan
double precision, dimension(:), pointer suffbn
double precision, dimension(:), pointer dist
double precision, dimension(:), pointer distb
double precision, dimension(:), pointer pond
double precision, dimension(:,:), pointer dijpf
double precision, dimension(:,:), pointer diipb
double precision, dimension(:,:), pointer dofij
◆ ifabor()
elemental pure integer function mesh::ifabor ( integer, intent(in)  ifac)
index-number of the (unique) neighboring cell for each boundary face
◆ ifacel()
elemental pure integer function mesh::ifacel ( integer, intent(in)  iside,
Index-numbers of the two (only) neighboring cells for each internal face
◆ ipnfac()
elemental pure integer function mesh::ipnfac ( integer, intent(in)  ifac)
position of the first node of the each internal face in the array returned by nodfac (see Note 3: faces-vertices connectivity)
◆ ipnfbr()
elemental pure integer function mesh::ipnfbr ( integer, intent(in)  ifac)
position of the first node of the each boundary face in the array returned by nodfbr (see Note 3: faces-vertices connectivity)
◆ isolid()
elemental pure integer function mesh::isolid ( integer, intent(in)  iporos,
integer, intent(in)  iel
integer to mark out the "solid" cells (where the fluid volume is 0). Only available when iposros > 0. When iporos = 0, this array has a unique value (isolid_0(1:1)=0).
◆ nodfac()
elemental pure integer function mesh::nodfac ( integer, intent(in)  ipn)
indexed-numbers of the nodes of each internal face (see Note 3: faces-vertices connectivity)
◆ nodfbr()
elemental pure integer function mesh::nodfbr ( integer, intent(in)  ipn)
indexed-numbers of the nodes of each boundary face (see Note 3: faces-vertices connectivity)
◆ cdgfac
coordinates of the centers of the internal faces
◆ cdgfbo
coordinates of the centers of the boundary faces
◆ cell_f_vol
fluid volume of each cell
◆ diipb
vector II' for interior faces for every boundary face, the three components of the vector $\vect{II'}$. I' is the orthogonal projection of I, center of the neighboring cell, on the straight line perpendicular to the face and passing through its center
◆ dijpf
vector I'J' for interior faces for every internal face, the three components of the vector $\vect{I'J'}$, where I' and J' are respectively the orthogonal projections of the neighboring cell centers I and J on a straight line orthogonal to the face and passing through its center
◆ dist
for every internal face, dot product of the vectors $ \vect{IJ}$ and $\vect{n}$. I and J are respectively the centers of the first and the second neighboring cell. The vector $\vect{n}$ is the unit vector normal to the face and oriented from the first to the second cell
◆ distb
For every boundary face, dot product between the vectors $\vect{IF}$ and $\vect{n}$. I is the center of the neighboring cell. F is the face center. The vector $\vect{n}$ is the unit vector normal to the face and oriented to the exterior of the domain
◆ dofij
vector OF for interior faces for every internal face, the three components of the vector $\vect{OF}$. O is the intersection point between the face and the straight line joining the centers of the two neighboring cells. F is the face center
◆ ifabor_0
◆ ifacel_0
◆ ifmcel
family number of the elements. See Note 1: ghost cells - (halos)
◆ ifmfbr
family number of the boundary faces. See Note 1: ghost cells - (halos)
◆ ipnfac_0
◆ ipnfbr_0
◆ isolid_0
◆ isympa
integer to mark out the "symmetry" (itypfb=isymet) boundary faces where the mass flow has to be canceled when the ALE module is switched off (these faces are impermeable). For instance, if the face ifac is symmetry face, isympa(ifac)=0, otherwise isympa(ifac)=1.
◆ lndfac
size of the array nodfac of internal faces - nodes connectivity (see Note 3: faces-vertices connectivity)
◆ lndfbr
size of the array nodfbr of boundary faces - nodes connectivity (see Note 3: faces-vertices connectivity)
◆ ncel
integer, save ncel
number of real cells in the mesh
◆ ncelet
number of extended (real + ghost of the 'halo') cells. See Note 1: ghost cells - (halos)
◆ ndim
integer ndim
spatial dimension (3)
◆ nfabor
number of boundary faces (see Note 2: internal faces)
◆ nfac
integer, save nfac
number of internal faces (see Note 2: internal faces)
◆ nnod
integer, save nnod
number of vertices in the mesh
◆ nodfac_0
◆ nodfbr_0
◆ pond
weighting (Aij=pond Ai+(1-pond)Aj) for every internal face, $\displaystyle\frac{\vect{FJ}.\vect{n}}{\vect{IJ}.\vect{n}}$. With regard to the mesh quality, its ideal value is 0.5
◆ suffac
fluid surface vector of the internal faces. Its norm is the surface of the face and it is oriented from ifacel(1,.) to ifacel(2,.)
◆ suffan
norm of the fluid surface vector of the internal faces
◆ suffbn
norm of the fluid surface of the boundary faces
◆ suffbo
surface vector of the boundary faces. Its norm is the surface of the face and it is oriented outwards
◆ surfac
◆ surfan
norm of the surface vector of the internal faces
◆ surfbn
norm of the surface of the boundary faces
◆ surfbo
◆ volume
volume of each cell
◆ xyzcen
coordinate of the cell centers
◆ xyznod
coordinates of the mesh vertices
