Module for variable numbering
integer darcy_anisotropic_permeability
integer darcy_anisotropic_dispersion
integer darcy_unsteady
integer darcy_convergence_criterion
integer darcy_gravity
double precision darcy_gravity_x
double precision darcy_gravity_y
double precision darcy_gravity_z
integer darcy_unsaturated
◆ darcy_anisotropic_dispersion
Set dispersion to isotropic (0) or anisotropic (1) for all solutes
◆ darcy_anisotropic_permeability
Set permeability to isotropic (0) or anisotropic (1) for all soils
◆ darcy_convergence_criterion
Set convergence criteron of the Newton scheme
  • 0: over pressure (recommanded)
  • 1: over velocity
◆ darcy_gravity
Set gravity to compute the pressure head $ h $ from the hydraulic head $ H $ and the elevation ( $ z $ is the elevation by default). Only used in the Van Genuchten model. If enabled the pressure head is stored in field of index iprtot. The reference elevation is always the elevation of point (0,0,0).
◆ darcy_gravity_x
Darcy gravity direction x component. Gravity direction must be a unit vector.
◆ darcy_gravity_y
Darcy gravity direction y component. Gravity direction must be a unit vector.
◆ darcy_gravity_z
Darcy gravity direction z component. Gravity direction must be a unit vector.
◆ darcy_unsaturated
Take into account unsaturated zone (1) or not (0).
◆ darcy_unsteady
Set if the transport part is based on a steady (0) or unsteady (1) flow field
