integer, save | ncepdc |
integer, dimension(:), allocatable | icepdc |
double precision, dimension(:,:), allocatable | ckupdc |
double precision, dimension(:), allocatable | b_head_loss |
Head loss factor of the fluid outside the domain, between infinity and the entrance (for ifrent boundary type). The default value is 0, dimensionless factor. The user may give a value in cs_user_boundary_conditions in the array rcodcl (ifac, ipr, 2). More... | |
integer, save | ncetsm |
integer, dimension(:), allocatable, target | icetsm |
integer, dimension(:), allocatable | izctsm |
zone where a mass source term is imposed. More... | |
integer, dimension(:,:), allocatable, target | itypsm |
double precision, dimension(:,:), allocatable, target | smacel |
double precision, dimension(:), allocatable | gamcav |
liquid-vapor mass transfer term for cavitating flows and its derivative with respect to pressure More... | |
double precision, dimension(:), allocatable | dgdpca |
integer, save | nfbpcd |
number of the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_boundary_mass_source_terms More... | |
integer, dimension(:), allocatable | ifbpcd |
list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_boundary_mass_source_terms More... | |
integer, dimension(:), allocatable | izftcd |
zone where a condensation source terms is imposed. More... | |
integer, dimension(:,:), allocatable | itypcd |
type of condensation source terms for each variable More... | |
double precision, dimension(:,:), allocatable | spcond |
value of the condensation source terms for pressure. For the other variables, eventual imposed specific value. See the user subroutine cs_user_boundary_mass_source_terms More... | |
double precision, dimension(:), allocatable | thermal_condensation_flux |
value of the thermal flux for the condensation model. See the user subroutine cs_user_boundary_mass_source_terms More... | |
double precision, dimension(:), allocatable | hpcond |
value of the thermal exchange coefficient associated to the condensation model used. See the user subroutine cs_user_boundary_mass_source_terms More... | |
double precision, dimension(:), allocatable | flthr |
Specific 1D thermal model with implicit time scheme (only used with condensation modelling to the cold wall) flthr ! external heat flux used as flux conditions ! of the 1d thermal model (in unit ![]() | |
double precision, dimension(:), allocatable | dflthr |
dflthr ! external heat flux derivative used as flux conditions ! of the 1d thermal model (in unit ![]() | |
integer, save | ncmast |
number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the subroutine cs_user_metal_structures_source_terms More... | |
integer, dimension(:), allocatable | ltmast |
list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_user_metal_structures_source_terms. More... | |
integer, dimension(:), allocatable | izmast |
zone type where a condensation source terms is imposed to model the metal structures condensation on a volumic zone. More... | |
integer, dimension(:,:), allocatable | itypst |
double precision, dimension(:,:), allocatable | svcond |
value of the condensation source terms for pressure associated to the metal structures modelling. For the other variables, eventual imposed specific value. See the user subroutine cs_user_metal_structures_source_terms. More... | |
double precision, dimension(:), allocatable | flxmst |
value of the thermal flux for the condensation model associated to the metal structures modelling. See the user subroutine cs_user_metal_structures_source_terms. More... | |
double precision, dimension(:), allocatable b_head_loss |
(ifac, ipr, 2).
double precision, dimension(:,:), allocatable ckupdc |
double precision, dimension(:), allocatable dflthr |
dflthr ! external heat flux derivative used as flux conditions ! of the 1d thermal model (in unit ).
double precision, dimension(:), allocatable dgdpca |
double precision, dimension(:), allocatable flthr |
Specific 1D thermal model with implicit time scheme (only used with condensation modelling to the cold wall) flthr ! external heat flux used as flux conditions ! of the 1d thermal model (in unit ).
double precision, dimension(:), allocatable flxmst |
double precision, dimension(:), allocatable gamcav |
double precision, dimension(:), allocatable hpcond |
integer, dimension(:), allocatable icepdc |
integer, dimension(:), allocatable, target icetsm |
number of the ncetsm
cells in which a mass source term is imposed. See iicesm
and the user subroutine cs_user_mass_source_terms}}
integer, dimension(:), allocatable ifbpcd |
integer, dimension(:,:), allocatable itypcd |
integer, dimension(:,:), allocatable, target itypsm |
type of mass source term for each variable
integer, dimension(:,:), allocatable itypst |
integer, dimension(:), allocatable izctsm |
integer, dimension(:), allocatable izftcd |
integer, dimension(:), allocatable izmast |
integer, dimension(:), allocatable ltmast |
integer, save ncetsm |
integer, save ncmast |
integer, save nfbpcd |
double precision, dimension(:,:), allocatable, target smacel |
value of the mass source term for pressure. For the other variables, eventual imposed injection value. See the user subroutine cs_user_mass_source_terms
double precision, dimension(:,:), allocatable spcond |
double precision, dimension(:,:), allocatable svcond |
double precision, dimension(:), allocatable thermal_condensation_flux |
