Module for rotation zones (rotors)
Data Types
interface  rotation_define
 Define a global rotation. More...
interface  rotation_update_coords
 Update coordinates based on a global rotation and time. More...
interface  angular_velocity
 Return angular velocity associated with a rotation. More...
interface  rotation_velocity
 Compute rotation velocity at given point coordinates
\[ \vect{v}=\vect{\Omega}\wedge\vect{x},\quad \text{with }\vect{\Omega}\textnormal{ the rotation vector and } \vect{x}\text{ the point location.} \]
. More...
interface  add_coriolis_v
 Add a Coriolis term to a local vector
\[ \vect{w}=\vect{w}+C\vect{\Omega}\wedge\vect{u},\quad \text{with }C\text{ a multiplicative coefficient, } \vect{\Omega}\text{ the rotation vector and } \vect{u}\text{ the velocity.} \]
. More...
interface  coriolis_v
 Compute a Coriolis term for a vector
\[ \vect{w}=C\vect{\Omega}\wedge\vect{u},\quad \text{with }C\text{ a multiplicative coefficient, } \vect{\Omega}\text{ the rotation vector and } \vect{u}\text{ the velocity.} \]
. More...
interface  add_coriolis_t
 Add the dual tensor of a rotation vector to a tensor
\[ T_{ij}=T_{ij}+\epsilon_{imj}\Omega_m,\quad \text{for }\Omega_m\text{ the rotation vector components and } \epsilon_{imj}\text{ the permutation tensor components.} \]
. More...
interface  coriolis_t
 Compute the dual tensor of a rotation vector
\[ T_{ij}=\epsilon_{imj}\Omega_m,\quad \text{for }\Omega_m\text{ the rotation vector components and } \epsilon_{imj}\text{ the permutation tensor components.} \]
. More...
Functions/Subroutines
subroutine rotation_define (omega_x, omega_y, omega_z, invariant_x, invariant_y, invariant_z)
subroutine rotation_update_coords (n_coords, t_rot, coords)
subroutine angular_velocity (r_num, omega)
subroutine rotation_velocity (r_num, coords, vr)
subroutine add_coriolis_v (r_num, c, v, vr)
subroutine coriolis_v (r_num, c, v, vr)
subroutine add_coriolis_t (r_num, c, tr)
subroutine coriolis_t (r_num, c, tr)
integer nrotmx
 Maximum number of rotors. More...
double precision, dimension(3, nrotmx), save rotax
 Rotation axis. More...
double precision, dimension(3, nrotmx), save rotcen
 Rotation origin coordinates. More...
◆ add_coriolis_t()
subroutine add_coriolis_t ( integer(c_int), value  r_num,
real(c_double), value  c,
real(c_double), dimension(3,3), intent(inout)  tr
◆ add_coriolis_v()
subroutine add_coriolis_v ( integer(c_int), value  r_num,
real(c_double), dimension(3), intent(in)  v,
real(c_double), dimension(3), intent(inout)  vr
◆ angular_velocity()
subroutine angular_velocity ( integer(c_int), value  r_num,
real(c_double), intent(out)  omega
◆ coriolis_t()
subroutine coriolis_t ( integer(c_int), value  r_num,
◆ coriolis_v()
subroutine coriolis_v ( integer(c_int), value  r_num,
real(c_double), dimension(3), intent(out)  vr
◆ rotation_define()
subroutine rotation_define ( real(c_double), value  omega_x,
real(c_double), value  omega_y,
real(c_double), value  omega_z,
real(c_double), value  invariant_x,
real(c_double), value  invariant_y,
real(c_double), value  invariant_z
◆ rotation_update_coords()
subroutine rotation_update_coords ( integer(c_int), value  n_coords,
real(c_double), value  t_rot,
real(c_double), dimension(3,*), intent(inout)  coords
◆ rotation_velocity()
subroutine rotation_velocity ( integer(c_int), value  r_num,
real(c_double), dimension(3), intent(in)  coords,
◆ nrotmx
integer nrotmx
◆ rotax
Rotation axis.
◆ rotcen
