struct | cs_vof_parameters_t |
VOF model parameters. Void fraction variable tracks fluid 2. More... | |
struct | cs_cavitation_parameters_t |
Cavitation model parameters. More... | |
Macros | |
#define | CS_VOF_ENABLED (1 << 0) |
#define | CS_VOF_FREE_SURFACE (1 << 1) |
#define | CS_VOF_MERKLE_MASS_TRANSFER (1 << 2) |
cs_vof_parameters_t * | cs_get_glob_vof_parameters (void) |
void | cs_vof_compute_linear_rho_mu (const cs_domain_t *domain) |
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference density and dynamic viscosity (liquid), (gas). More... | |
void | cs_vof_update_phys_prop (const cs_domain_t *domain) |
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flux, the volume fraction and the reference density and dynamic viscosity (liquid), (gas). More... | |
void | cs_vof_log_mass_budget (const cs_domain_t *domain) |
Write in main log the global mixture mass budget:
. More... | |
void | cs_vof_deshpande_drift_flux (const cs_domain_t *domain) |
Compute the flux of the drift velocity , by using the flux of the standard velocity following the approach described by Suraj S Deshpande et al 2012 Comput. Sci. Disc. 5 014016. It is activated with the option idrift = 1. More... | |
void | cs_vof_drift_term (int imrgra, int nswrgp, int imligp, int iwarnp, cs_real_t epsrgp, cs_real_t climgp, cs_real_t *restrict pvar, const cs_real_t *restrict pvara, cs_real_t *restrict rhs) |
Add the explicit part of the convection/diffusion terms of a standard transport equation of a scalar field . More... | |
cs_cavitation_parameters_t * | cs_get_glob_cavitation_parameters (void) |
const cs_vof_parameters_t * | cs_glob_vof_parameters |
cs_cavitation_parameters_t* cs_get_glob_cavitation_parameters | ( | void | ) |
cs_vof_parameters_t* cs_get_glob_vof_parameters | ( | void | ) |
void cs_vof_compute_linear_rho_mu | ( | const cs_domain_t * | domain | ) |
Computation is done as follows on cells:
A similar linear formula is followed on boundary using fluid volume fraction value on the boundary.
void cs_vof_deshpande_drift_flux | ( | const cs_domain_t * | domain | ) |
Using the notation:
The drift flux is computed as:
Where is the drift flux factor defined with the variable cdrift, the normal vector to the interface. The gradient is computed using a centered scheme:
Using the notation:
void cs_vof_drift_term | ( | int | imrgra, |
int | nswrgp, | ||
int | imligp, | ||
int | iwarnp, | ||
cs_real_t | epsrgp, | ||
cs_real_t | climgp, | ||
cs_real_t *restrict | pvar, | ||
const cs_real_t *restrict | pvara, | ||
cs_real_t *restrict | rhs | ||
More precisely, the right hand side is updated as follows:
[in] | imrgra | indicator
[in] | nswrgp | number of reconstruction sweeps for the gradients |
[in] | imligp | clipping gradient method
[in] | iwarnp | verbosity |
[in] | epsrgp | relative precision for the gradient reconstruction |
[in] | climgp | clipping coefficient for the computation of the gradient |
[in] | pvar | solved variable (current time step) |
[in] | pvara | solved variable (previous time step) |
[in,out] | rhs | right hand side |
void cs_vof_log_mass_budget | ( | const cs_domain_t * | domain | ) |
void cs_vof_update_phys_prop | ( | const cs_domain_t * | domain | ) |
For the computation of mixture density, mixture dynamic viscosity, see cs_vof_compute_linear_rho_mu.
Computation of mass flux is as follows:
const cs_vof_parameters_t* cs_glob_vof_parameters |
