User subroutines dedicated to Fluid-Structure interaction modeling.
More...
| subroutine | usstr1 (idfstr, aexxst, bexxst, cfopre, xstr0, vstr0, xstreq) |
| | Definition of internal structures and corresponding initial conditions (initial displacement and velocity ). More...
| subroutine | usstr2 (nbstru, idfstr, dtcel, xmstru, xcstru, xkstru, xstreq, xstr, vstr, forstr, dtstr) |
| | Definition of structural parameters in case of Fluid Structure internal coupling : Mass, Friction, Stiffness anf Fluid Stresses. More...
| subroutine | usaste (idfstr) |
| | User subroutine dedicated the Fluid-Structure external coupling with code_aster : Here one defines the boundary faces coupled with code_aster and the fluid forces components which are given to structural calculations. More...
- Management of internal Fluid-Structure coupled calculations:
- a simplified solid model is used (linear "mass, friction and spring" modeling). Here are 2 differents subroutines that need to be filled :
- usstr1 : Called at the beginning of the calculation. It enables one to define internal structures and corresponding initial conditions (initial displacement and velocity).
- usstr2 : Called at each time step of the calculation. Here one structural parameters (considered to be potentially time dependent), i.e. Mass, Friction, Stiffness and Fluid Stresses.
- Fluid-Structure coupling with code_aster:
- the user subroutine usaste has to be used.
- Examples of data settings for fluid-structure interaction (FSI):
- Several examples are available here.
◆ usaste()
| subroutine usaste |
integer, dimension(nfabor) |
idfstr | ) |
- Parameters
| [in] | idfstr | boundary faces -> structure definition |
◆ usstr1()
| subroutine usstr1 |
idfstr, |
double precision |
aexxst, |
double precision |
bexxst, |
double precision |
cfopre, |
double precision, dimension(3,nstrmx) |
xstr0, |
vstr0, |
xstreq |
- Parameters
| [in] | aexxst,bexxst | prediction coefficients of structural data |
| [in] | cfopre | prediction coefficients of fluid forces |
| [in] | xstr0 | initial displacement of internal structures |
| [in] | vstr0 | initial velocity of internal structures |
| [in] | xstreq | displacement of initial mesh compared to structures position at equilibrium |
◆ usstr2()
| subroutine usstr2 |
integer |
nbstru, |
idfstr, |
double precision, dimension(ncelet) |
dtcel, |
double precision, dimension(3,3,nstrmx) |
xmstru, |
xcstru, |
xkstru, |
xstreq, |
xstr, |
vstr, |
forstr, |
double precision, dimension(nstrmx) |
dtstr |
- Parameters
| [in] | nbstru | nombre de structures definies |
| [in] | idfstr | definition des structures |
| [in] | dtcel | time step (per cell |
| [in] | xmstru | matrix of structural mass |
| [out] | xcstru | matrix of structural friction |
| [out] | xkstru | matrix of structural stiffness |
| [in] | xstreq | displacement of initial mesh compared to |
| [in] | xstr | structural displacement |
| [in] | vstr | structural velocity |
| [in] | forstr | forces acting on structures (take forces) |
| [out] | dtstr | structural time step |
