cs_sdm.c File Reference
#include <float.h>
#include <limits.h>
#include <bft_mem.h>
#include "cs_blas.h"
#include "cs_math.h"
#include "cs_sort.h"
#include "cs_sdm.h"
+ Include dependency graph for cs_sdm.c:
cs_sdm_t * cs_sdm_create (cs_flag_t flag, int n_max_rows, int n_max_cols)
 Allocate and initialize a cs_sdm_t structure Most generic function to create a cs_sdm_t structure without block description. More...
cs_sdm_t * cs_sdm_square_create (int n_max_rows)
 Allocate and initialize a cs_sdm_t structure Case of a square matrix. More...
cs_sdm_t * cs_sdm_create_copy (const cs_sdm_t *m)
 Allocate a cs_sdm_t structure and initialized it with the copy of the matrix m in input. More...
cs_sdm_t * cs_sdm_create_transpose (cs_sdm_t *mat)
 Define a new matrix which is its transpose. More...
cs_sdm_t * cs_sdm_block_create (int n_max_blocks_by_row, int n_max_blocks_by_col, const int max_row_block_sizes[], const int max_col_block_sizes[])
 Allocate and initialize a cs_sdm_t structure. More...
cs_sdm_t * cs_sdm_block33_create (int n_max_blocks_by_row, int n_max_blocks_by_col)
 Allocate and initialize a cs_sdm_t structure by block when the block size is constant and equal to 3. More...
cs_sdm_t * cs_sdm_free (cs_sdm_t *mat)
 Free a cs_sdm_t structure. More...
void cs_sdm_block_init (cs_sdm_t *m, int n_row_blocks, int n_col_blocks, const int row_block_sizes[], const int col_block_sizes[])
 Initialize the pattern of cs_sdm_t structure defined by block The matrix should have been allocated before calling this function. More...
void cs_sdm_block33_init (cs_sdm_t *m, int n_row_blocks, int n_col_blocks)
 Initialize the pattern of cs_sdm_t structure defined by 3x3 block The matrix should have been allocated before calling this function. More...
void cs_sdm_block_33_to_xyz (const cs_sdm_t *mb33, cs_sdm_t *mbxyz)
 Convert a matrix with each entry is a 3x3 block into a matrix with a block for each component x,y,z. More...
cs_sdm_t * cs_sdm_block_create_copy (const cs_sdm_t *mref)
 Allocate and initialize a cs_sdm_t structure w.r.t. to a given matrix. More...
void cs_sdm_multiply (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a local dense matrix-product c = a*b c has been previously allocated. More...
void cs_sdm_multiply_rowrow (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Generic version: all compatible sizes. More...
void cs_sdm_multiply_rowrow_sym (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Generic version: all compatible sizes Result is known to be symmetric. More...
void cs_sdm_block_multiply_rowrow (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Case of matrices defined by block. More...
void cs_sdm_block_multiply_rowrow_sym (const cs_sdm_t *a, const cs_sdm_t *b, cs_sdm_t *c)
 Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Case of matrices defined by block. Results is known to be symmetric. More...
void cs_sdm_square_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a small square matrix mv has been previously allocated. More...
void cs_sdm_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix mv has been previously allocated. More...
void cs_sdm_update_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix mv has been previously allocated and initialized Thus mv is updated inside this function. More...
void cs_sdm_matvec_transposed (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix which is transposed. mv has been previously allocated. mv is updated inside this function. Don't forget to initialize mv if needed. More...
void cs_sdm_block_add (cs_sdm_t *mat, const cs_sdm_t *add)
 Add two matrices defined by block: loc += add. More...
void cs_sdm_block_add_mult (cs_sdm_t *mat, cs_real_t mult_coef, const cs_sdm_t *add)
 Add two matrices defined by block: loc += mult_coef * add. More...
void cs_sdm_block_matvec (const cs_sdm_t *mat, const cs_real_t *vec, cs_real_t *mv)
 Compute a dense matrix-vector product for a rectangular matrix defined by block mv has been previously allocated. More...
void cs_sdm_add (cs_sdm_t *mat, const cs_sdm_t *add)
 Add two small dense matrices: loc += add. More...
void cs_sdm_add_mult (cs_sdm_t *mat, cs_real_t alpha, const cs_sdm_t *add)
 Add two small dense matrices: loc += alpha*add. More...
void cs_sdm_square_add_transpose (cs_sdm_t *mat, cs_sdm_t *tr)
 Define a new matrix by adding the given matrix with its transpose. Keep the transposed matrix for a future use. More...
void cs_sdm_square_2symm (cs_sdm_t *mat)
 Set the given matrix to two times its symmetric part mat –> mat + mat_tr = 2*symm(mat) More...
void cs_sdm_square_asymm (cs_sdm_t *mat)
 Set the given matrix into its anti-symmetric part. More...
void cs_sdm_block_square_asymm (cs_sdm_t *mat)
 Set the given block matrix into its anti-symmetric part. More...
void cs_sdm_33_sym_qr_compute (const cs_real_t m[9], cs_real_t Qt[9], cs_real_t R[6])
 Decompose a matrix into the matrix product Q.R Case of a 3x3 symmetric matrix. More...
void cs_sdm_33_lu_compute (const cs_sdm_t *m, cs_real_t facto[9])
 LU factorization of a small dense 3x3 matrix. More...
void cs_sdm_lu_compute (const cs_sdm_t *m, cs_real_t facto[])
 LU factorization of a small dense matrix. Small means that the number m->n_rows is less than 100 for instance. More...
void cs_sdm_33_lu_solve (const cs_real_t facto[9], const cs_real_t rhs[3], cs_real_t sol[3])
 Solve a system A.sol = rhs using a LU factorization of A (a small 3x3 dense matrix). More...
void cs_sdm_lu_solve (cs_lnum_t n_rows, const cs_real_t facto[], const cs_real_t *rhs, cs_real_t *sol)
 Solve a system A.sol = rhs using a LU factorization of A (a small dense matrix). More...
void cs_sdm_33_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[6])
 LDL^T: Modified Cholesky decomposition of a 3x3 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_44_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[10])
 LDL^T: Modified Cholesky decomposition of a 4x4 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_66_ldlt_compute (const cs_sdm_t *m, cs_real_t facto[21])
 LDL^T: Modified Cholesky decomposition of a 6x6 SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_ldlt_compute (const cs_sdm_t *m, cs_real_t *facto, cs_real_t *dkk)
 LDL^T: Modified Cholesky decomposition of a SPD matrix. For more reference, see for instance http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_33_ldlt_solve (const cs_real_t facto[6], const cs_real_t rhs[3], cs_real_t sol[3])
 Solve a 3x3 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_44_ldlt_solve (const cs_real_t facto[10], const cs_real_t rhs[4], cs_real_t x[4])
 Solve a 4x4 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_66_ldlt_solve (const cs_real_t f[21], const cs_real_t b[6], cs_real_t x[6])
 Solve a 6x6 matrix with a modified Cholesky decomposition (L.D.L^T) The solution should be already allocated Ref. http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
void cs_sdm_ldlt_solve (int n_rows, const cs_real_t *facto, const cs_real_t *rhs, cs_real_t *sol)
 Solve a SPD matrix with a L.D.L^T (Modified Cholesky decomposition) The solution should be already allocated Reference: http://mathforcollege.com/nm/mws/gen/04sle/mws_gen_sle_txt_cholesky.pdf. More...
double cs_sdm_test_symmetry (const cs_sdm_t *mat)
 Test if a matrix is symmetric. Return 0. if the extradiagonal differences are lower thann the machine precision. More...
void cs_sdm_simple_dump (const cs_sdm_t *mat)
 Dump a small dense matrix. More...
void cs_sdm_dump (cs_lnum_t parent_id, const cs_lnum_t *row_ids, const cs_lnum_t *col_ids, const cs_sdm_t *mat)
void cs_sdm_fprintf (FILE *fp, const char *fname, cs_real_t thd, const cs_sdm_t *m)
 Print a cs_sdm_t structure not defined by block Print into the file f if given otherwise open a new file named fname if given otherwise print into the standard output The usage of threshold allows one to compare more easier matrices without taking into account numerical roundoff. More...
void cs_sdm_block_dump (cs_lnum_t parent_id, const cs_sdm_t *mat)
 Dump a small dense matrix defined by blocks. More...
void cs_sdm_block_fprintf (FILE *fp, const char *fname, cs_real_t thd, const cs_sdm_t *m)
 Print a cs_sdm_t structure which is defined by block Print into the file f if given otherwise open a new file named fname if given otherwise print into the standard output The usage of threshold allows one to compare more easier matrices without taking into account numerical roundoff. More...
◆ cs_sdm_33_ldlt_compute()
void cs_sdm_33_ldlt_compute ( const cs_sdm_t *  m,
cs_real_t  facto[6]
[in]mpointer to a cs_sdm_t structure
[in,out]factovector of the coefficient of the decomposition
Note
: facto is a lower triangular matrix. The first value of the j-th (zero-based) row is easily accessed: its index is j*(j+1)/2 (cf sum of the first j natural numbers). Instead of 1 on the diagonal we store the inverse of D mat in the L.D.L^T decomposition
◆ cs_sdm_33_ldlt_solve()
void cs_sdm_33_ldlt_solve ( const cs_real_t  facto[6],
cs_real_t  sol[3]
[in]factovector of the coefficients of the decomposition
[in]rhsright-hand side
[in,out]solsolution
◆ cs_sdm_33_lu_compute()
void cs_sdm_33_lu_compute ( const cs_sdm_t *  m,
cs_real_t  facto[9]
[in,out]factocompact storage of coefficients for the LU factorization
Note
: facto stores L the lower triangular matrix (without its diagonal entries assumed to be equal to 1) and U the upper triangular matrix.
◆ cs_sdm_33_lu_solve()
void cs_sdm_33_lu_solve ( const cs_real_t  facto[9],
cs_real_t  sol[3]
[in]factocompact storage of coefficients for the LU factorization (should be allocated to the right size, i.e. n_rows*n_rows)
[in,out]solsolution
Note
◆ cs_sdm_33_sym_qr_compute()
void cs_sdm_33_sym_qr_compute ( const cs_real_t  m[9],
cs_real_t  Qt[9],
cs_real_t  R[6]
[in]mmatrix values
[in,out]Qttransposed of matrix Q
[in,out]Rvector of the coefficient of the decomposition
Note
: R is an upper triangular matrix. Stored in a compact way.
j= 0, 1, 2 i=0| 0| 1| 2| i=1 | 4| 5| i=2 6|
◆ cs_sdm_44_ldlt_compute()
void cs_sdm_44_ldlt_compute ( const cs_sdm_t *  m,
cs_real_t  facto[10]
Note
◆ cs_sdm_44_ldlt_solve()
void cs_sdm_44_ldlt_solve ( const cs_real_t  facto[10],
cs_real_t  x[4]
[in,out]xsolution
◆ cs_sdm_66_ldlt_compute()
void cs_sdm_66_ldlt_compute ( const cs_sdm_t *  m,
cs_real_t  facto[21]
Note
◆ cs_sdm_66_ldlt_solve()
void cs_sdm_66_ldlt_solve ( const cs_real_t  f[21],
cs_real_t  x[6]
[in]fvector of the coefficients of the decomposition
[in]bright-hand side
[in,out]xsolution
◆ cs_sdm_add()
void cs_sdm_add ( cs_sdm_t *  mat,
const cs_sdm_t *  add
[in,out]matlocal matrix storing the result
[in]addvalues to add to mat
◆ cs_sdm_add_mult()
void cs_sdm_add_mult ( cs_sdm_t *  mat,
cs_real_t  alpha,
[in]alphamultiplicative coefficient
◆ cs_sdm_block33_create()
cs_sdm_t* cs_sdm_block33_create ( int  n_max_blocks_by_row,
[in]n_max_blocks_by_rowmax number of blocks in a row
[in]n_max_blocks_by_colmax number of blocks in a column
a new allocated cs_sdm_t structure
◆ cs_sdm_block33_init()
void cs_sdm_block33_init ( cs_sdm_t *  m,
int  n_row_blocks,
int  n_col_blocks
[in,out]m
[in]n_row_blocksnumber of blocks in a row
[in]n_col_blocksnumber of blocks in a column
◆ cs_sdm_block_33_to_xyz()
void cs_sdm_block_33_to_xyz ( const cs_sdm_t *  mb33,
cs_sdm_t *  mbxyz
[in]mb33pointer to a matrix
[in,out]mbxyzpointer to a matrix to build (but allocated)
◆ cs_sdm_block_add()
void cs_sdm_block_add ( cs_sdm_t *  mat,
◆ cs_sdm_block_add_mult()
void cs_sdm_block_add_mult ( cs_sdm_t *  mat,
[in]mult_coefmultiplicative coefficient
◆ cs_sdm_block_create()
cs_sdm_t* cs_sdm_block_create ( int  n_max_blocks_by_row,
[in]max_row_block_sizesmax number of rows by block in a column
[in]max_col_block_sizesmax number of columns by block in a row
◆ cs_sdm_block_create_copy()
cs_sdm_t* cs_sdm_block_create_copy ( const cs_sdm_t *  mref)
[in]mrefpointer to a matrix to copy
a new allocated cs_sdm_t structure which is a copy of mref
◆ cs_sdm_block_dump()
void cs_sdm_block_dump ( cs_lnum_t  parent_id,
const cs_sdm_t *  mat
[in]parent_idid of the related parent entity
[in]matpointer to the cs_sdm_t structure
◆ cs_sdm_block_fprintf()
void cs_sdm_block_fprintf ( FILE *  fp,
const char *  fname,
cs_real_t  thd,
const cs_sdm_t *  m
[in]fppointer to a file structure or NULL
[in]fnamefilename or NULL
[in]thdthreshold (below this value –> set 0)
[in]mpointer to the cs_sdm_t structure
◆ cs_sdm_block_init()
void cs_sdm_block_init ( cs_sdm_t *  m,
int  n_row_blocks,
int  n_col_blocks,
[in,out]m
[in]row_block_sizesnumber of rows by block in a column
[in]col_block_sizesnumber of columns by block in a row
◆ cs_sdm_block_matvec()
void cs_sdm_block_matvec ( const cs_sdm_t *  mat,
const cs_real_t vec,
cs_real_t mv
[in]matlocal matrix to use
[in]veclocal vector to use (size = mat->n_cols)
[in,out]mvresult of the operation (size = mat->n_rows)
◆ cs_sdm_block_multiply_rowrow()
void cs_sdm_block_multiply_rowrow ( const cs_sdm_t *  a,
const cs_sdm_t *  b,
cs_sdm_t *  c
Compute a row-row matrix product of a and b. It is basically equal to the classical a*b^T. It is a fast (matrices are row-major) way of computing a*b if b is symmetric or if b^T is given. Case of a matrix defined by block.
[in]alocal matrix to use
[in]blocal matrix to use
[in,out]cresult of the local matrix-product (already allocated) is updated
◆ cs_sdm_block_multiply_rowrow_sym()
void cs_sdm_block_multiply_rowrow_sym ( const cs_sdm_t *  a,
const cs_sdm_t *  b,
cs_sdm_t *  c
◆ cs_sdm_block_square_asymm()
void cs_sdm_block_square_asymm ( cs_sdm_t *  mat)
[in,out]matsmall dense matrix defined by block to transform
◆ cs_sdm_create()
cs_sdm_t* cs_sdm_create ( cs_flag_t  flag,
int  n_max_rows,
int  n_max_cols
Allocate and initialize a cs_sdm_t structure Most generic function to create a cs_sdm_t structure.
[in]flagmetadata related to a cs_sdm_t structure
[in]n_max_rowsmax number of rows
[in]n_max_colsmax number of columns
◆ cs_sdm_create_copy()
cs_sdm_t* cs_sdm_create_copy ( const cs_sdm_t *  m)
[in]mpointer to a cs_sdm_t structure to copy
a pointer to a new allocated cs_sdm_t structure
◆ cs_sdm_create_transpose()
cs_sdm_t* cs_sdm_create_transpose ( cs_sdm_t *  mat)
[in]matlocal matrix to transpose
a pointer to the new allocated transposed matrix
◆ cs_sdm_dump()
void cs_sdm_dump ( cs_lnum_t  parent_id,
const cs_lnum_t row_ids,
const cs_lnum_t col_ids,
[in]row_idslist of ids related to associated entities (or NULL)
[in]col_idslist of ids related to associated entities (or NULL)
◆ cs_sdm_fprintf()
void cs_sdm_fprintf ( FILE *  fp,
const char *  fname,
cs_real_t  thd,
const cs_sdm_t *  m
◆ cs_sdm_free()
cs_sdm_t* cs_sdm_free ( cs_sdm_t *  mat)
[in]matpointer to a cs_sdm_t struct. to free
a NULL pointer
◆ cs_sdm_ldlt_compute()
void cs_sdm_ldlt_compute ( const cs_sdm_t *  m,
cs_real_t facto,
cs_real_t dkk
[in,out]dkkstore temporary the diagonal (size = n_rows)
Note
◆ cs_sdm_ldlt_solve()
void cs_sdm_ldlt_solve ( int  n_rows,
const cs_real_t facto,
const cs_real_t rhs,
cs_real_t sol
[in]n_rowsdimension of the system to solve
[in,out]solsolution
◆ cs_sdm_lu_compute()
void cs_sdm_lu_compute ( const cs_sdm_t *  m,
cs_real_t  facto[]
[in,out]factocompact storage of coefficients for the LU factorization (should be allocated to the right size, i.e. m->n_rows*m->n_rows)
Note
◆ cs_sdm_lu_solve()
void cs_sdm_lu_solve ( cs_lnum_t  n_rows,
cs_real_t sol
[in,out]solsolution
Note
◆ cs_sdm_matvec()
void cs_sdm_matvec ( const cs_sdm_t *  mat,
cs_real_t mv
◆ cs_sdm_matvec_transposed()
void cs_sdm_matvec_transposed ( const cs_sdm_t *  mat,
cs_real_t mv
◆ cs_sdm_multiply()
void cs_sdm_multiply ( const cs_sdm_t *  a,
const cs_sdm_t *  b,
cs_sdm_t *  c
[in]alocal dense matrix to use
[in]blocal dense matrix to use
[in,out]cresult of the local matrix-product is updated
◆ cs_sdm_multiply_rowrow()
void cs_sdm_multiply_rowrow ( const cs_sdm_t *  a,
const cs_sdm_t *  b,
cs_sdm_t *  c
[in,out]cresult of the local matrix-product (already allocated) is updated.
◆ cs_sdm_multiply_rowrow_sym()
void cs_sdm_multiply_rowrow_sym ( const cs_sdm_t *  a,
const cs_sdm_t *  b,
cs_sdm_t *  c
◆ cs_sdm_simple_dump()
void cs_sdm_simple_dump ( const cs_sdm_t *  mat)
◆ cs_sdm_square_2symm()
void cs_sdm_square_2symm ( cs_sdm_t *  mat)
[in,out]matsmall dense matrix to transform
◆ cs_sdm_square_add_transpose()
void cs_sdm_square_add_transpose ( cs_sdm_t *  mat,
cs_sdm_t *  tr
[in,out]matlocal matrix to transpose and add
[in,out]trtransposed of the local matrix
◆ cs_sdm_square_asymm()
void cs_sdm_square_asymm ( cs_sdm_t *  mat)
◆ cs_sdm_square_create()
cs_sdm_t* cs_sdm_square_create ( int  n_max_rows)
◆ cs_sdm_square_matvec()
void cs_sdm_square_matvec ( const cs_sdm_t *  mat,
cs_real_t mv
[in,out]mvresult of the local matrix-vector product
◆ cs_sdm_test_symmetry()
double cs_sdm_test_symmetry ( const cs_sdm_t *  mat)
[in]matpointer to the cs_sdm_t structure to test
0 if the matrix is symmetric at the machine tolerance otherwise the absolute max. value between two transposed terms
◆ cs_sdm_update_matvec()
void cs_sdm_update_matvec ( const cs_sdm_t *  mat,
cs_real_t mv
