int | cs_runaway_check (void) |
Check that defined field bounds are not exceeded. More... | |
void | cs_runaway_check_define_field_max (int f_id, cs_real_t max_allowed) |
Define maximum value for a field, beyon which computation is aborted. More... | |
void | cs_runaway_check_finalize (void) |
int cs_runaway_check | ( | void | ) |
void cs_runaway_check_define_field_max | ( | int | f_id, |
cs_real_t | max_allowed | ||
Currently, only one field is handled, so calling this multiple times replaced the previous setting. Using a negative field id removes this check.
void cs_runaway_check_finalize | ( | void | ) |
