| struct | cs_iter_algo_info_t |
| | Set of information related to the convergence of the iterative algorithm (Picard or Uzawa for instance) More...
◆ cs_iter_algo_define()
| cs_iter_algo_info_t* cs_iter_algo_define |
int |
verbosity, |
int |
n_max_iter, |
double |
atol, |
double |
rtol, |
double |
dtol |
Create and initialize a new cs_iter_algo_info_t structure.
- Parameters
| [in] | verbosity | set the level of information printed |
| [in] | n_max_iter | maximal number of iteration |
| [in] | atol | absolute tolerance |
| [in] | rtol | relative tolerance |
| [in] | dtol | divergence tolerance |
- Returns
- a pointer to the new allocated structure
◆ cs_iter_algo_navsto_fb_picard_cvg()
Test if one has to do one more Picard iteration. Test if performed on the relative norm on the increment between two iterations but also on the divergence.
- Parameters
| [in] | connect | set of additional connectivities for CDO |
| [in] | quant | set of additional geometrical quantities |
| [in] | pre_iterate | previous state of the mass flux iterate |
| [in] | cur_iterate | current state of the mass flux iterate |
| [in] | div_l2_norm | L2 norm of the velocity divergence |
| [in,out] | a_info | pointer to a cs_iter_algo_info_t struct. |
