cs_gui.h File Reference
#include "cs_volume_zone.h"
+ Include dependency graph for cs_gui.h:
void csther (void)
void cs_gui_turb_model (void)
void cs_gui_turb_ref_values (void)
void cscpva (void)
void csvvva (int *iviscv)
void csivis (void)
void csidtv (void)
void csiphy (void)
void cscfgp (int *icfgrp)
void csisui (int *ntsuit, int *iccvfg)
void cstime (void)
void uinum1 (double *cdtvar)
void csnum2 (double *relaxp, int *imrgra)
void cssca2 (void)
void cssca3 (void)
void cstini (void)
void uiporo (void)
void uitsnv (const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
void uitssc (const int *idarcy, const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
void uitsth (const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
void uiiniv (const int *isuite, const int *idarcy, int *iccfth)
void uiphyv (const int *iviscv)
void uiexop (void)
void uidapp (const int *permeability, const int *diffusion, const int *gravity, const cs_real_t *gravity_x, const cs_real_t *gravity_y, const cs_real_t *gravity_z, const int *unsaturated)
void uifans (void)
void uieres (int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
void cs_gui_finalize (void)
void cs_gui_head_losses (const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
 Compute GUI-defined head losses for a given volume zone. More...
void cs_gui_linear_solvers (void)
void cs_gui_parallel_io (void)
void cs_gui_partition (void)
void cs_gui_mpi_algorithms (void)
void cs_gui_physical_properties (void)
void cs_gui_porous_model (void)
void cs_gui_properties_value (const char *property_name, double *value)
void cs_gui_properties_value_by_fluid_id (const int fluid_id, const char *property_name, double *value)
void cs_gui_fluid_properties_value (const char *param, double *value)
int cs_gui_thermal_model (void)
void cs_gui_time_moments (void)
void cs_gui_turbomachinery (void)
void cs_gui_turbomachinery_rotor (void)
void cs_gui_usage_log (void)
void cs_gui_user_variables (void)
void cs_gui_user_arrays (void)
void cs_gui_balance_by_zone (void)
void cs_gui_pressure_drop_by_zone (void)
void cs_gui_define_fans (void)
void cs_gui_error_estimator (int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
void cs_gui_zones (void)
void cs_gui_internal_coupling (void)
◆ cs_gui_balance_by_zone()
void cs_gui_balance_by_zone ( void  )
◆ cs_gui_define_fans()
void cs_gui_define_fans ( void  )
◆ cs_gui_error_estimator()
void cs_gui_error_estimator ( int *  iescal,
int *  iespre,
int *  iesder,
int *  iescor,
int *  iestot
◆ cs_gui_finalize()
void cs_gui_finalize ( void  )
◆ cs_gui_fluid_properties_value()
void cs_gui_fluid_properties_value ( const char *  param,
double *  value
◆ cs_gui_head_losses()
void cs_gui_head_losses ( const cs_zone_t zone,
const cs_real_3_t cvara_vel,
cs_real_t  cku[][6]
Head loss tensor coefficients for each cell are organized as follows: cku11, cku22, cku33, cku12, cku13, cku23.
[in]zonepointer to zone structure
[in]cvara_velpointer to the velocity values of the previous time step
[in,out]ckuhead loss coefficients
◆ cs_gui_internal_coupling()
void cs_gui_internal_coupling ( void  )
◆ cs_gui_linear_solvers()
void cs_gui_linear_solvers ( void  )
◆ cs_gui_mpi_algorithms()
void cs_gui_mpi_algorithms ( void  )
◆ cs_gui_parallel_io()
void cs_gui_parallel_io ( void  )
◆ cs_gui_partition()
void cs_gui_partition ( void  )
◆ cs_gui_physical_properties()
void cs_gui_physical_properties ( void  )
◆ cs_gui_porous_model()
void cs_gui_porous_model ( void  )
◆ cs_gui_pressure_drop_by_zone()
void cs_gui_pressure_drop_by_zone ( void  )
◆ cs_gui_properties_value()
void cs_gui_properties_value ( const char *  property_name,
double *  value
◆ cs_gui_properties_value_by_fluid_id()
void cs_gui_properties_value_by_fluid_id ( const int  fluid_id,
double *  value
◆ cs_gui_thermal_model()
int cs_gui_thermal_model ( void  )
◆ cs_gui_time_moments()
void cs_gui_time_moments ( void  )
◆ cs_gui_turb_model()
void cs_gui_turb_model ( void  )
◆ cs_gui_turb_ref_values()
void cs_gui_turb_ref_values ( void  )
◆ cs_gui_turbomachinery()
void cs_gui_turbomachinery ( void  )
◆ cs_gui_turbomachinery_rotor()
void cs_gui_turbomachinery_rotor ( void  )
◆ cs_gui_usage_log()
void cs_gui_usage_log ( void  )
◆ cs_gui_user_arrays()
void cs_gui_user_arrays ( void  )
◆ cs_gui_user_variables()
void cs_gui_user_variables ( void  )
◆ cs_gui_zones()
void cs_gui_zones ( void  )
◆ cscfgp()
void cscfgp ( int *  icfgrp)
◆ cscpva()
void cscpva ( void  )
◆ csidtv()
void csidtv ( void  )
◆ csiphy()
void csiphy ( void  )
◆ csisui()
void csisui ( int *  ntsuit,
int *  iccvfg
◆ csivis()
void csivis ( void  )
◆ csnum2()
void csnum2 ( double *  relaxp,
int *  imrgra
◆ cssca2()
void cssca2 ( void  )
◆ cssca3()
void cssca3 ( void  )
◆ csther()
void csther ( void  )
◆ cstime()
void cstime ( void  )
◆ cstini()
void cstini ( void  )
◆ csvvva()
void csvvva ( int *  iviscv)
◆ uidapp()
void uidapp ( const int *  permeability,
const int *  diffusion,
const int *  gravity,
const cs_real_t gravity_x,
const cs_real_t gravity_y,
const cs_real_t gravity_z,
const int *  unsaturated
◆ uieres()
void uieres ( int *  iescal,
int *  iespre,
int *  iesder,
int *  iescor,
int *  iestot
◆ uiexop()
void uiexop ( void  )
◆ uifans()
void uifans ( void  )
◆ uiiniv()
void uiiniv ( const int *  isuite,
const int *  idarcy,
int *  iccfth
◆ uinum1()
void uinum1 ( double *  cdtvar)
◆ uiphyv()
void uiphyv ( const int *  iviscv)
◆ uiporo()
void uiporo ( void  )
◆ uitsnv()
void uitsnv ( const cs_real_3_t *restrict  vel,
◆ uitssc()
void uitssc ( const int *  idarcy,
const int *  f_id,
◆ uitsth()
void uitsth ( const int *  f_id,
