1 #ifndef __CS_ELEC_MODEL_H__ 2 #define __CS_ELEC_MODEL_H__ cs_real_t * xkabel
Definition: cs_elec_model.h:67
const cs_real_t cs_elec_epszer
Definition: cs_elec_model.c:275
int * ibrsec
Definition: cs_elec_model.h:84
void cs_elec_physical_properties(cs_domain_t *domain)
Definition: cs_elec_model.c:1039
int irestrike
Definition: cs_elec_model.h:102
const cs_data_joule_effect_t * cs_glob_transformer
void cs_elec_fields_initialize(const cs_mesh_t *mesh, int isuite)
Definition: cs_elec_model.c:1959
int modrec
Definition: cs_elec_model.h:106
void elini1(cs_real_t *diftl0)
Definition: cs_elec_model.c:567
const cs_data_elec_t * cs_glob_elec_properties
cs_real_t * zi
Definition: cs_elec_model.h:88
integer, dimension(nscamx), save isca
Definition: numvar.f90:131
int ntdcla
Definition: cs_elec_model.h:101
void cs_elec_scaling_function(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
Definition: cs_elec_model.c:2006
int nbelec
Definition: cs_elec_model.h:77
cs_data_joule_effect_t * cs_get_glob_transformer(void)
Definition: cs_elec_model.c:665
Definition: cs_defs.h:495
int * ielecc
Definition: cs_elec_model.h:78
void elthht(int *mode, cs_real_t *ym, cs_real_t *enthal, cs_real_t *temp)
Definition: cs_elec_model.c:580
cs_real_t * visel
Definition: cs_elec_model.h:65
cs_real_t * zr
Definition: cs_elec_model.h:87
void cs_electrical_model_specific_initialization(cs_real_t *diftl0)
Definition: cs_elec_model.c:754
cs_real_t * uroff
Definition: cs_elec_model.h:89
int ngaz
Definition: cs_elec_model.h:58
void ellecd(void)
Definition: cs_elec_model.c:597
cs_real_t elcou
Definition: cs_elec_model.h:113
cs_real_t * rhoel
Definition: cs_elec_model.h:62
cs_real_t * xlabel
Definition: cs_elec_model.h:66
Definition: cs_defs.h:307
int * ibrpr
Definition: cs_elec_model.h:83
cs_real_t * cpel
Definition: cs_elec_model.h:63
integer, save isuite
Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; dep...
Definition: optcal.f90:272
cs_real_t * uioff
Definition: cs_elec_model.h:90
cs_real_t srrom
Definition: cs_elec_model.h:114
const cs_elec_option_t * cs_glob_elec_option
int * izreca
Definition: cs_elec_model.h:108
void cs_elec_source_terms(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_t *smbrs)
Definition: cs_elec_model.c:1647
cs_real_t coejou
Definition: cs_elec_model.h:112
cs_real_t puisim
Definition: cs_elec_model.h:111
int nbtrf
Definition: cs_elec_model.h:81
void cs_elec_convert_h_to_t_faces(const cs_real_t h[], cs_real_t t[])
Convert enthalpy to temperature at all boundary faces.
Definition: cs_elec_model.c:2191
void cs_elec_add_property_fields(void)
Definition: cs_elec_model.c:1840
void elreca(cs_real_t *dt)
Definition: cs_elec_model.c:641
double precision, save diftl0
Definition: ppthch.f90:162
void cs_electrical_model_initialize(void)
Definition: cs_elec_model.c:675
Definition: cs_domain.h:88
void cs_elec_convert_t_to_h_faces(const cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
Convert temperature to enthalpy at selected boundary faces.
Definition: cs_elec_model.c:2301
const cs_real_t cs_elec_permvi
Definition: cs_elec_model.c:269
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:320
int * ielecb
Definition: cs_elec_model.h:80
cs_real_t * sigel
Definition: cs_elec_model.h:64
void elphyv(void)
Definition: cs_elec_model.c:604
cs_real_t pot_diff
Definition: cs_elec_model.h:110
option for electric model
Definition: cs_elec_model.h:98
Definition: cs_defs.h:301
cs_real_t * rnbs
Definition: cs_elec_model.h:86
int npoint
Definition: cs_elec_model.h:59
Definition: cs_defs.h:496
int ntfref
Definition: cs_elec_model.h:82
void cs_elec_convert_t_to_h_cells(const cs_real_t t[], cs_real_t h[])
Convert temperature to enthalpy at all cells.
Definition: cs_elec_model.c:2247
int ielcor
Definition: cs_elec_model.h:105
void elflux(int *iappel)
Definition: cs_elec_model.c:573
#define CS_PROCF(x, y)
Definition: cs_defs.h:509
void eliniv(int *isuite)
Definition: cs_elec_model.c:635
void cs_electrical_model_finalize(void)
Definition: cs_elec_model.c:717
void eltsvv(const int *f_id, cs_real_t *smbrv)
Definition: cs_elec_model.c:625
cs_real_t * tenspr
Definition: cs_elec_model.h:85
cs_real_t couimp
Definition: cs_elec_model.h:109
physical properties for electric model descriptor.
Definition: cs_elec_model.h:56
void cs_electrical_properties_read(void)
Definition: cs_elec_model.c:847
cs_elec_option_t * cs_get_glob_elec_option(void)
Definition: cs_elec_model.c:655
void cs_elec_add_variable_fields(void)
Definition: cs_elec_model.c:1744
int idreca
Definition: cs_elec_model.h:107
void eltssc(const int *isca, cs_real_t *smbrs)
Definition: cs_elec_model.c:610
void cs_elec_compute_fields(const cs_mesh_t *mesh, int call_id)
Definition: cs_elec_model.c:1365
int ixkabe
Definition: cs_elec_model.h:100
cs_real_t * th
Definition: cs_elec_model.h:60
cs_real_t * ehgaz
Definition: cs_elec_model.h:61
Structure to read transformer parameters in dp_ELE.
Definition: cs_elec_model.h:75
void cs_elec_source_terms_v(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_3_t *smbrv)
Definition: cs_elec_model.c:1710
int * ielect
Definition: cs_elec_model.h:79
