cs_coolprop.hxx
1 #ifndef __CS_COOLPROP_HXX__
2 #define __CS_COOLPROP_HXX__
5  * Equation of state
35  * Local headers
38 #include "cs_physical_properties.h"
40 #include "cs_base.h"
45  * Local Macro Definitions
49  * Structure definition
51
53  * Global variables definition
55
56 /*============================================================================
57  * Public function prototypes
59
60 /*----------------------------------------------------------------------------*/
73 /*----------------------------------------------------------------------------*/
74
75 #ifdef __cplusplus
76 extern "C"
77 #endif
78 void
79 cs_phys_prop_coolprop(char *CoolPropMaterial,
81  cs_phys_prop_type_t property,
82  const cs_lnum_t n_vals,
83  const cs_real_t var1[],
84  const cs_real_t var2[],
85  cs_real_t val[]);
86
87 #endif /* __CS_COOLPROP_HXX__ */
88
void cs_phys_prop_coolprop(char *CoolPropMaterial, cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_coolprop.cxx:94
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
Definition: cs_defs.h:307
Definition: cs_physical_properties.h:40
Definition: cs_defs.h:301
