cs_block_to_part.h
1 #ifndef __CS_BLOCK_TO_PART_H__
2 #define __CS_BLOCK_TO_PART_H__
5  * Convert between block distribution and general domain partition.
30 #if defined(HAVE_MPI)
31 #include <mpi.h>
32 #endif
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_block_dist.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /*=============================================================================
54  * Public function prototypes
56
57 #if defined(HAVE_MPI)
58
59 /*----------------------------------------------------------------------------*/
98 /*----------------------------------------------------------------------------*/
99
102  cs_block_dist_info_t block,
103  cs_block_dist_info_t adjacent_block,
104  int stride,
105  const cs_gnum_t adjacency[],
106  const int adjacent_ent_rank[],
107  const int default_rank[],
108  cs_lnum_t *n_part_elts,
109  cs_gnum_t **part_gnum);
110
111 #endif /* defined(HAVE_MPI) */
112
113 /*----------------------------------------------------------------------------*/
138 /*----------------------------------------------------------------------------*/
139
140 void
142  cs_lnum_t base,
143  cs_lnum_t global_list_size,
144  bool global_list_is_sorted,
145  const cs_gnum_t global_list[],
146  const cs_gnum_t global_number[],
147  cs_lnum_t local_number[]);
148
149 /*----------------------------------------------------------------------------*/
150
152
153 #endif /* __CS_BLOCK_TO_PART_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
cs_all_to_all_t * cs_block_to_part_create_by_adj_s(MPI_Comm comm, cs_block_dist_info_t block, cs_block_dist_info_t adjacent_block, int stride, const cs_gnum_t adjacency[], const int adjacent_ent_rank[], const int default_rank[], cs_lnum_t *n_part_elts, cs_gnum_t **part_gnum)
Initialize block to partition distributor with block data using strided adjacency array...
Definition: cs_block_to_part.c:124
Definition: cs_defs.h:495
Definition: cs_defs.h:301
Definition: cs_defs.h:496
void cs_block_to_part_global_to_local(cs_lnum_t n_ents, cs_lnum_t base, cs_lnum_t global_list_size, bool global_list_is_sorted, const cs_gnum_t global_list[], const cs_gnum_t global_number[], cs_lnum_t local_number[])
Determine local references from references to global numbers.
Definition: cs_block_to_part.c:358
struct _cs_all_to_all_t cs_all_to_all_t
Definition: cs_all_to_all.h:78
