Setting porosity values: basic example
Local definitions and initialization
Mesh quantities
It may be useful to access some mesh adjacencies and quantities, in which case local pointers allow for more readable code:
cs_mesh_t *m = domain->mesh;
cs_mesh_quantities_t *mq = domain->mesh_quantities;
const cs_lnum_2_t *i_face_cells
= (const cs_lnum_2_t *)m->i_face_cells;
const cs_real_3_t *restrict i_face_cog
const cs_real_3_t *restrict b_face_cog
const cs_real_3_t *restrict cell_cen
= (const cs_real_3_t *restrict)mq->cell_cen;
const cs_real_3_t *restrict i_face_normal
cs_real_3_t *restrict i_f_face_normal
= (cs_real_3_t *restrict)mq->i_f_face_normal;
const cs_real_3_t *restrict b_face_normal
cs_real_3_t *restrict b_f_face_normal
= (cs_real_3_t *restrict)mq->b_f_face_normal;
const cs_real_t *i_f_face_surf = mq->i_f_face_surf;
const cs_real_t *i_face_surf = mq->i_face_surf;
Associated properties
Accessing cell porosity property values is required so values may be set:
cs_real_t *cpro_porosi = cs_field_by_name("porosity")->val;
Example: define porosity by geometric zones
Individual cell porosity values can be assigned to each cell, so they may be based on groups, geometric criteria, or any other time-independent functions:
for (cs_lnum_t cell_id = 0; cell_id < m->n_cells; cell_id++) {
cs_real_t x = cell_cen[cell_id][0];
if (x < 20.)
cpro_porosi[cell_id] = 1.;
else
cpro_porosi[cell_id] = 0.5;
/* synchronize for use in fluid face factor calculation below */
halo_type);
Matching face equivalent surfaces should also be assigned in a corresponding manner, for interior faces:
for (cs_lnum_t face_id = 0; face_id < m->n_i_faces; face_id++) {
cs_real_t x = i_face_cog[face_id][0];
cs_real_t face_porosity = 1.;
if (x > 19.9999)
face_porosity = 0.5;
for (int i = 0; i < 3; i++)
i_f_face_normal[face_id][i] = face_porosity * i_face_normal[face_id][i];
mq->i_f_face_surf[face_id] = cs_math_3_norm(i_f_face_normal[face_id]);
and for boundary faces:
for (cs_lnum_t face_id = 0; face_id < m->n_b_faces; face_id++) {
cs_real_t x = b_face_cog[face_id][0];
if (x > 19.9999)
b_f_face_normal[face_id][i] = face_porosity * b_face_normal[face_id][i];
mq->b_f_face_surf[face_id] = cs_math_3_norm(b_f_face_normal[face_id]);
