Unsteady inlet boundary condition for LES with the vortex method (usvort.f90)
The subroutine usvort allows generating an unsteady inlet boundary condition for LES with the vortex method. This method is based on the generation of vortices in the 2D inlet plane with help from pre-defined functions. The fluctuation normal to the inlet plane is generated by a Langevin equation. The subroutine usvort specifies the parameters of this method.
To allow the application of the vortex method, ivrtex must set to 1 in the usipsu subroutine in the cs_user_parameters.f90 file.
Vortex method parameters setting
Arguments of usvort
The function usvort has the following arguments :
! Arguments
integer nvar , nscal
integer iappel
double precision dt(ncelet)
Local variables declaration
Some local variables need to be declared as follows :
! Local variables
integer ifac, ient
integer ilelt, nlelt
integer, allocatable, dimension(:) :: lstelt
Allocation
The lstelt array is allocated.
! Allocate a temporary array for boundary faces selection
allocate(lstelt(nfabor))
Global parameters
The following part defines the number of inlets concerned by the vortex method (nnentt) and the number of vortices for each inlet (nvort).
! 1. PARAMETRES GLOBAUX
! --- Nombre d'entrees avec la methode des vortex
nnent = 2
! --- Nombre de vortex a mettre dans chaque entree
! NVORT min ~ Surface d'entree/(pi*SIGMA**2)
nvort(1) = 500
nvort(2) = 500
Inlets definition
Then, at the first call of usvort (iappel=1), one defines the boundary faces at which the vortex method is applicable. The irepvo array, which defines the number of inlets concerned with the vortex, is filled with ient .
if (iappel.eq.1) then
! 2. DEFINITION DES ZONES D'ENTREE (AU PREMIER PASSAGE)
do ifac = 1, nfabor
irepvo(ifac) = 0
enddo
! ENTREE 1
CALL getfbr('3',nlelt,lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
ient = 1
irepvo(ifac) = ient
enddo
! ENTREE 2
CALL getfbr('1',nlelt,lstelt)
do ilelt = 1, nlelt
ient = 2
irepvo(ifac) = ient
enddo
Boundary conditions
The following part defines the complexity of the geometry.
elseif (iappel.eq.2) then
! 3. PARAMETRES GEOMETRIQUES ET CONDITIONS LIMITES
! --- Cas traite
! ICAS = 1...Conduite rectangulaire
! 2...Conduite circulaire
! 3...Geometrie quelconque sans traitement specifique des conditions aux limites
! 4...Geometrie quelconque sans traitement specifique des conditions aux limites
! ni fichier de donnees (la vitesse moyenne, le niveau de k et de epsilon
! sont fournis par l'utilisateur)
ient = 1
icas(ient) = 1
ient = 2
icas(ient) = 2
! --- Repere definissant le plan d'entree
! Si ICAS = 4, le code se charge de ces donnees
! Sinon il faut preciser les vecteurs DIR1 et DIR2 definissant
! un repere directe tel que DIR3 soit un vecteur entrant normal
! a la face d'entree.
ient = 1
if(icas(ient).eq.1.or.icas(ient).eq.2.or.icas(ient).eq.3) then
dir1(1,ient) = 1.d0
dir1(2,ient) = 0.d0
dir1(3,ient) = 0.d0
dir2(1,ient) = 0.d0
dir2(2,ient) = 1.d0
dir2(3,ient) = 0.d0
endif
ient = 2
dir1(1,ient) = 0.d0
dir1(2,ient) = 1.d0
dir1(3,ient) = 0.d0
dir2(1,ient) = 0.d0
dir2(2,ient) = 0.d0
dir2(3,ient) = 1.d0
endif
! --- Centre du repere local dans le plan d'entree
! Si ICAS = 1 ou ICAS = 2, le centre du repere doit correspondre
! au centre de gravite de la zone d'entree (rectangle ou cercle)
ient = 1
cen(1,ient) = 0.d0
cen(2,ient) = 0.d0
cen(3,ient) = -6.05d-1
ient = 2
cen(1,ient) = -3.664d-1
cen(2,ient) = 0.d0
cen(3,ient) = 0.d0
! --- Condition aux limites
! -> Si ICAS = 1...Il faut specifier le type de condition aux limite ICLVOR
! dans les directions DIR1, DIR2, - DIR1, -DIR2
! Ces conditions peuvent etre de 3 types :
! ICLVOR = 1...Condition de paroi
! 2...Condition de symetrie
! 3...Condition de periodicite
! y = LLY/2
! (ICLVOR 1)
! | ^ DIR1 |
! z=- LLZ/2 | +----> DIR2 | z = LLZ/2
! (ICLVOR 4)| | (ICLVOR 2)
! y = -LLY/2
! (ICLVOR 3)
! -> Si ICAS = 2, les conditions sont necessairement de type paroi
! -> Si ICAS = 3 ou 4, pas de traitement particulier
ient = 1
if(icas(ient).eq.1) then
iclvor(1,ient) = 1
iclvor(2,ient) = 2
iclvor(3,ient) = 1
iclvor(4,ient) = 2
endif
! LLY et LLZ sont les dimensions de l'entree dans les directions DIR1 et DIR2
! LDD est le diametre de la conduite
ient = 1
lly(ient) = 0.2d0
llz(ient) = 0.1d0
ient = 2
lld(2) = 0.154d0
Physical and time parameters
Depending on the complexity of the geometry, the main parameters of the method are defined.
! 5. PARAMETRES PHYSIQUES ET MARCHE EN TEMPS
! --- " Temps de vie " limite du vortex
! ITLIVO = 1...Les vortex sont retire au bout du temps TLIMVO
! donne par l'utilisateur
! ( par exemple TLIMVO = 10*DTREF)
! 2...Chaque vortex a un temps d'exitence limite valant
! 5.Cmu.k^(3/2).U/epsilon
! ( ou U est la vitesse principale suivant DIR3)
ient = 1
itlivo(ient) = 1
if(itlivo(ient).eq.1) then
tlimvo(ient) = 10.d0*dtref
endif
ient = 2
itlivo(ient) = 2
! --- " Diametre " des vortex
! ISGMVO = 1...diametre constant XSGMVO donne par l'utilisateur
! 2...basee sur la formule sigma = Cmu^(3/4).k^(3/2)/epsilon
! 3...basee sur la formule sigma = max(Lt, Lk) avec
! Lt = (5 nu.k/epsilon)^(1/2)
! et Lk = 200.(nu^3/epsilon)^(1/4)
ient = 1
isgmvo(ient) = 1
if(isgmvo(ient).eq.1) then
xsgmvo(ient) = 0.01d0
endif
ient = 2
isgmvo(ient) = 2
! --- Mode de deplacement des vortex
! IDEPVO = 1...Deplacement en r*UD (r aleatoire dans [0,1])
! UD a fournir par l'utilisateur
! 2...Convection par les vortex
ient = 1
idepvo(ient) = 2
ient = 2
idepvo(ient) = 1
if(idepvo(ient).eq.1) then
ud(ient) = 0.7d0
endif
Input/Output parameters
As icas is equal to 1 or 2 (see Boundary conditions), a data file ficvor must be defined for each inlet.
! 6. PARAMETRES D'ENTREE / SORTIES ET DONNEES UTILISATEUR
! --- Fichier de donnees utilisateur
! NDAT ...Nombre de lignes du fichier de donnees contenant les donnees :
! x | y | z | U | V | W | Grad[u.DIR3].n | k | epsilon
! dans le plan d'entree du calcul
! Grad[u.DIR3].n est le gradient dans la direction normale
! a la paroi, de la vitesse principale dans le plan d'entree.
! Cette donnees n'est utilisee qu'avec ICAS=2
! FICVOR...Nom du fichier de donnees utilisateur
ient = 1
ndat(ient) = 2080
ient = 2
ndat(ient) = 2080
! Par les defaut les fichiers sont nommes "vordat" affecte de l'indice d'entree
ient = 1
ficvor(ient) = 'entree_1.dat'
ient = 2
ficvor(ient) = 'entree_2.dat'
! Pour ICAS = 4, on precise juste la valeur moyenne de U, k et de espilon
! a l'entree
if(icas(ient).eq.4) then
udebit(ient) = 10.d0
kdebit(ient) = 1.d0
edebit(ient) = 1.d0
endif
! --- Relecture d'un fichier suite eventuel
! ISUIVO = 0...Pas de relecture (reinitialisation des vortex)
! 1...Relecture du fichier suite de methode des vortex
isuivo = isuite
endif
Deallocation
The lstelt array needs to be deallocated.
! Deallocate the temporary array
deallocate(lstelt)
Definition of the phidat function (interpolation)
The phidat function allows to define the interpolation used in the vortex method. It is called by the subroutines vorlgv, vorvit, vordep, and vorini.
implicit none
integer nfecra, icas, ndat, iii
double precision zz, yy
double precision zdat(ndat), ydat(ndat)
double precision vardat(ndat)
integer ii
double precision phidat, dist1
! Initialize variables to avoid compiler warnings
phidat = 0.d0
! Dans l'exemple suivant, on se contente de retourne la valeur situee
! dans le fichier de donnee a l'abscisse la plus proche du point de
! coordonnee (Y,Z) ou l'on cherche a connaitre la valeur de la
! variable numero VARDAT.
if(icas.eq.1.or.icas.eq.2.or.icas.eq.3) then
if(iii.eq.0) then
dist1 = 1.d20
do ii = 1,ndat
if(sqrt((yy-ydat(ii))**2+(zz-zdat(ii))**2).lt.dist1) then
dist1 = sqrt((zz-zdat(ii))**2+(yy-ydat(ii))**2)
iii = ii
phidat = vardat(ii)
endif
enddo
elseif(iii.ne.0) then
phidat = vardat(iii)
endif
elseif(icas.eq.4) then
phidat = vardat(1)
endif
