#include <cs_1d_wall_thermal.h>
Data Fields | |
| int | nppt1d |
| int | iclt1d |
| cs_real_t | eppt1d |
| cs_real_t | rgpt1d |
| cs_real_t | tept1d |
| cs_real_t | hept1d |
| cs_real_t | fept1d |
| cs_real_t | xlmbt1 |
| cs_real_t | rcpt1d |
| cs_real_t | dtpt1d |
| cs_real_t * | z |
| cs_real_t * | t |
1D wall thermal module parameters and variables for each coupled face.
| dtpt1d |
Physical time step associated with the solved 1D equation of the pseudo wall (which can be different from the time step of the calculation).
| eppt1d |
Thickness of the 1D wall for the nfpt1d boundary faces which are coupled with a 1D wall thermal module.
| fept1d |
External heat flux in the pseudo wall under the flux conditions (in
, negative value for energy entering the wall).
| hept1d |
External coefficient of transfer in the pseudo wall under Dirichlet conditions, (in
| iclt1d |
Boundary condition type at the external (pseudo) wall:
| nppt1d |
Number of discretisation cells in the 1D wall for the nfpt1d boundary faces which are coupled with a 1D wall thermal module.
| rcpt1d |
Volumetric heat capacity rho C_p of the wall uniform in thickness (
| rgpt1d |
Geometry of the pseudo wall mesh (refined as a fluid if rgt1d is smaller than 1.
| t |
Temperature at each point of discretization.
| tept1d |
External temperature of the pseudo wall in the Dirichlet case.
| xlmbt1 |
Thermal diffusivity.
| z |
Discretization points coordinates.
