These subroutineS fill physical properties which are variable in time for the dedicated physics modules (BEFORE and AFTER the user surbroutines).
More...
- Warning
- it is forbidden to modify the turbulent viscosity here.
- icp must be set to 1 if one wants the specific heat to be variable in space
- it is necessary to call field_set_key_int(ivarfl(isca(iscal)), kivisl, 0) if one wants the specific heat to be variable in space
Here can be given:
- the cell density in kg/m3 (and eventually the boundary density)
- the dynamic molecular viscosity in kg/(m s)
- the specific heat Cp in J/(kg degres)
- scalars diffusivities in kg/(m s)
◆ cs_physical_properties1()
| subroutine cs_physical_properties1 |
integer |
mbrom | ) |
- Parameters
| [in] | mbrom | indicator of prescribed density at the boundary |
◆ cs_physical_properties2()
| subroutine cs_physical_properties2 |
