Set integer bits matching a mask to 1 for a given key for a field. More...
Public Member Functions | |
| subroutine | field_set_key_int_bits (f_id, k_id, k_value) |
If the key id is not valid, or the value type or field category is not compatible, a fatal error is provoked.
| [in] | f_id | field id |
| [in] | k_id | id of associated key |
| [in] | mask | associated mask |
| subroutine field_set_key_int_bits | ( | integer(c_int), value | f_id, |
| integer(c_int), value | k_id, | ||
| integer(c_int), value | k_value | ||
