| integer, save | ischtp |
| time order of time stepping More... | |
| integer, save | istmpf |
| time order of the mass flux scheme The chosen value for istmpf will automatically determine the value given to the variable thetfl. More... | |
| integer(c_int), pointer, save | nterup |
| number of interations on the pressure-velocity coupling on Navier-Stokes (for the PISO algorithm) More... | |
| integer, save | isno2t |
| isno2t specifies the time scheme activated for the source terms of the momentum equation, apart from convection and diffusion (for instance: head loss, transposed gradient, ...). More... | |
| integer, save | isto2t |
isto2t specifies the time scheme activated for the source terms of the turbulence equations i.e. related to , , , , , ), apart from convection and diffusion. More... | |
| integer, dimension(nscamx), save | isso2t |
| for each scalar, isso2t specifies the time scheme activated for the source terms of the equation for the scalar, apart from convection and diffusion (for instance: variance production, user-specified terms, ...). More... | |
| integer, save | initvi |
| initvi : =1 if total viscosity read from checkpoint file More... | |
| integer, save | initro |
| initro : =1 if density read from checkpoint file More... | |
| integer, save | initcp |
| initcp : =1 if specific heat read from checkpoint file More... | |
| integer, dimension(nscamx), save | initvs |
| initvs : =1 if scalar diffusivity read from checkpoint file More... | |
| double precision, save | thetsn |
-scheme for the source terms in the Navier-Stokes equations when the source term extrapolation has been activated (see isno2t), following the formula .The value of = thetsn is deduced from the value chosen for isno2t. Generally only the value 0.5 is used. More... | |
| double precision, save | thetst |
-scheme for the extrapolation of the nonlinear explicit source terms $S_e$ of the turbulence equations when the source term extrapolation has been activated (see isto2t), following the formula .The value of is deduced from the value chosen for isto2t. Generally, only the value 0.5 is used. More... | |
| double precision, dimension(nscamx), save | thetss |
-scheme for the extrapolation of the nonlinear explicit source term of the scalar transport equation when the source term extrapolation has been activated (see isso2t), following the formula .The value of = thetss is deduced from the value chosen for isso2t. Generally, only the value 0.5 is used. More... | |
| double precision, save | thetfl |
-scheme for the mass flux when a second-order time scheme has been activated for the mass flow (see istmpf). More... | |
| double precision, save | thetvi |
-scheme for the extrapolation of the physical property "total viscosity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula .The value of = thetvi is deduced from the value chosen for time_extrapolated key word for the viscosity. Generally, only the value 0.5 is used. More... | |
| double precision, save | thetcp |
-scheme for the extrapolation of the physical property "specific heat" when the extrapolation has been activated (see time_extrapolated field key int), according to the formula .The value of = thetcp is deduced from the value chosen for the specific heat. Generally, only the value 0.5 is used. More... | |
| double precision, dimension(nscamx), save | thetvs |
-scheme for the extrapolation of the physical property "diffusivity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula .The value of = thetvs is deduced from the value chosen for time_extrapolated key word. Generally, only the value 0.5 is used. More... | |
| real(c_double), pointer, save | epsup |
| relative precision for the convergence test of the iterative process on pressure-velocity coupling (PISO) More... | |
| real(c_double), pointer, save | xnrmu |
norm of the increment of the iterative process on pressure-velocity coupling (PISO) More... | |
| real(c_double), pointer, save | xnrmu0 |
norm of (used by PISO algorithm) More... | |
| real(c_double), pointer, save epsup |
| integer, save initcp |
| integer, save initro |
| integer, save initvi |
| integer, dimension(nscamx), save initvs |
| integer, save ischtp |
| integer, save isno2t |
which are linear functions of the solved variable
are expressed as second-order terms by interpolation (according to the formula
being given by the value of thetav associated with the variable
); the other terms
are expressed as second-order terms by extrapolation (according to the formula
being given by the value of thetsn = 0.5).
are treated in the same way as when isno2t = 1; the other terms
are extrapolated according to the same formula as when isno2t = 1, but with
= thetsn = 1. By default, isno2t is initialised to 1 (second-order) when the selected time scheme is second-order (ischtp = 2), otherwise to 0. | integer, dimension(nscamx), save isso2t |
); the other terms
being given by the value of thetss (iscal) = 0.5)
are treated in the same way as when isso2t = 1; the other terms
are extrapolated according to the same formula as when isso2t = 1, but with
= thetss (iscal) = 1.| integer, save istmpf |
time step.| integer, save isto2t |
); the other terms
being given by the value of thetst = 0.5)
are treated in the same way as when isto2t = 1; the other terms
are extrapolated according to the same formula as when isto2t = 1, but with
= thetst = 1.
models (iturb = 30 or 31); hence, it is always initialised to 0. | integer(c_int), pointer, save nterup |
| double precision, save thetcp |
The value of
| double precision, save thetfl |
| double precision, save thetsn |
The value of
| double precision, dimension(nscamx), save thetss |
The value of
| double precision, save thetst |
The value of
| double precision, save thetvi |
The value of
| double precision, dimension(nscamx), save thetvs |
The value of
| real(c_double), pointer, save xnrmu |
| real(c_double), pointer, save xnrmu0 |
norm of
