| integer, dimension(ncharm), save | if1m |
mean value of the tracer 1 representing the light volatiles released by the coal icha More... | |
| integer, dimension(ncharm), save | if2m |
mean value of the tracer 2 representing the heavy volatiles released by the coal icha More... | |
| integer, save | if3m |
| mean value of the tracer 3 representing the carbon released as CO during coke burnout More... | |
| integer, save | if4m |
| transported variable of countinuous phase (gas mixture) More... | |
| integer, save | if5m |
| integer, save | if6m |
| integer, save | if7m |
| integer, save | if8m |
| integer, save | if9m |
| integer, save | if4p2m |
| the variance associated with the tracer 4 representing the air (the mean value of this tracer is not transported, it can be deduced directly from the three others) More... | |
| integer, save | ifvp2m |
| f1f2 variance More... | |
| integer, dimension(nclcpm), save | ixck |
| coke mass fraction related to the class icla More... | |
| integer, dimension(nclcpm), save | ixch |
reactive coal mass fraction related to the class icla More... | |
| integer, dimension(nclcpm), save | inp |
number of particles of the class icla per kg of air-coal mixture More... | |
| integer, dimension(nclcpm), save | ih2 |
mass enthalpy of the coal of class icla, if we are in permeatic conditions More... | |
| integer, dimension(nclcpm), save | ixwt |
| transported variable of dispersed phase (particle class) More... | |
| integer, dimension(nclcpm), save | inagecp |
| Pointer to Np*age(particles) More... | |
| integer, save | iage |
| Pointer to age of bulk. More... | |
| integer, dimension(nclcpm), save | iv_p_x |
| integer, dimension(nclcpm), save | iv_p_y |
| integer, dimension(nclcpm), save | iv_p_z |
| integer, dimension(ngazem), save | iym1 |
| mass fractions: More... | |
| integer, save | itemp1 |
| temperature of the gas mixture More... | |
| integer, save | irom1 |
| State variables of continuous phase (gas mixture) More... | |
| integer, save | immel |
| molar mass of the gas mixture More... | |
| integer, dimension(nclcpm), save | itemp2 |
temperature of the particles of the class icla More... | |
| integer, dimension(nclcpm), save | irom2 |
density of the particles of the class icla More... | |
| integer, dimension(nclcpm), save | idiam2 |
diameter of the particles of the class icla More... | |
| integer, dimension(nclcpm), save | ix2 |
solid mass fraction of the class icla More... | |
| integer, dimension(nclcpm), save | igmdch |
disappearance rate of the reactive coal of the class icla More... | |
| integer, dimension(nclcpm), save | igmhet |
coke disappearance rate of the coke burnout of the class icla More... | |
| integer, dimension(nclcpm), save | igmtr |
| Implicite part of the exchanges to the gas by molecular distribution. More... | |
| integer, dimension(nclcpm), save | ighco2 |
| State variables of dispersed phase (particles class) More... | |
| integer, dimension(nclcpm), save | igmdv1 |
mass transfer caused by the release of light volatiles of the class icla More... | |
| integer, dimension(nclcpm), save | igmdv2 |
mass transfer caused by the release of heavy volatiles of the class icla More... | |
| integer, dimension(nclcpm), save | igmsec |
| integer, save | ibcarbone |
| Used for bulk balance of Carbon. More... | |
| integer, save | iboxygen |
| Used for bulk balance of Oxygen. More... | |
| integer, save | ibhydrogen |
| Used for bulk balance of Hydrogen. More... | |
| integer, save iage |
| integer, save ibcarbone |
| integer, save ibhydrogen |
| integer, save iboxygen |
| integer, dimension(nclcpm), save idiam2 |
| integer, dimension(ncharm), save if1m |
| integer, dimension(ncharm), save if2m |
| integer, save if3m |
| integer, save if4m |
| integer, save if4p2m |
| integer, save if5m |
| integer, save if6m |
| integer, save if7m |
| integer, save if8m |
| integer, save if9m |
| integer, save ifvp2m |
f1f2 variance
| integer, dimension(nclcpm), save ighco2 |
| integer, dimension(nclcpm), save igmdch |
| integer, dimension(nclcpm), save igmdv1 |
| integer, dimension(nclcpm), save igmdv2 |
| integer, dimension(nclcpm), save igmhet |
| integer, dimension(nclcpm), save igmsec |
| integer, dimension(nclcpm), save igmtr |
| integer, dimension(nclcpm), save ih2 |
| integer, save immel |
| integer, dimension(nclcpm), save inagecp |
| integer, dimension(nclcpm), save inp |
| integer, save irom1 |
| integer, dimension(nclcpm), save irom2 |
| integer, save itemp1 |
| integer, dimension(nclcpm), save itemp2 |
| integer, dimension(nclcpm), save iv_p_x |
| integer, dimension(nclcpm), save iv_p_y |
| integer, dimension(nclcpm), save iv_p_z |
| integer, dimension(nclcpm), save ix2 |
| integer, dimension(nclcpm), save ixch |
| integer, dimension(nclcpm), save ixck |
| integer, dimension(nclcpm), save ixwt |
| integer, dimension(ngazem), save iym1 |
mass fractions:
(light volatiles) in the gas mixture
(heavy volatiles) in the gas mixture
in the gas mixture
in the gas mixture
in the gas mixture
in the gas mixture
