Collaboration diagram for Boundary conditions:
integer, dimension(nozppm), save iqimp
 imposed flow zone indicator in a way which is similar to the process described in the framework of the EBU module, the user chooses for every inlet face to impose the mass flow or not (iqimp(izone)=1 or 0). If the mass flow is imposed, the user must set the air mass flow value qimpat(izone), its direction in rcodcl(ifac,iu), rcodcl(ifac,iv) and rcodcl(ifac,iw) and the incoming air temperature timpat(izone) in Kelvin. If the velocity is imposed, he has to set rcodcl(ifac,iu), rcodcl(ifac,iv), and rcodcl(ifac,iw). More...
integer, dimension(nozppm), save icalke
 condition type turbulence indicator More...
double precision, dimension(nozppm), save xintur
 turbulent intensity (k=1.5(uref*xintur)**2) More...
double precision, dimension(nozppm), save dh
 hydraulic diameter More...
integer, save nozapm
 index of maximum reached boundary zone More...
integer, save nzfppp
 number of boundary zones on current process More...
integer, dimension(nbzppm), save ilzppp
 list of boundary zones index More...
◆ dh
hydraulic diameter
◆ icalke
  • 0 : given by the user
  • 1 : automatic, from hydraulic diameter and input velocity performed.
  • 2 : automatic, from turbulent intensity and input velocity performed.
◆ ilzppp
◆ iqimp
◆ nozapm
◆ nzfppp
◆ xintur
