Module for ALE structure movement with internal coupling
integer, save nbstru
 number of structures, automatically computed More...
double precision, dimension(3, 3, nstrmx), save xmstru
double precision, dimension(3, 3, nstrmx), save xcstru
double precision, dimension(3, 3, nstrmx), save xkstru
double precision, dimension(3, nstrmx), save xstr
double precision, dimension(3, nstrmx), save xsta
double precision, dimension(3, nstrmx), save xstp
 predicted value of xstr (m) More...
double precision, dimension(3, nstrmx), save xstreq
double precision, dimension(3, nstrmx), save xpstr
double precision, dimension(3, nstrmx), save xpsta
 xpstr at previous time step (m/s) More...
double precision, dimension(3, nstrmx), save xppstr
double precision, dimension(3, nstrmx), save xppsta
 xppstr at previous time step (m/s2) More...
double precision, dimension(3, nstrmx), save forstr
double precision, dimension(3, nstrmx), save forsta
 forstr at previous time step (N) More...
double precision, dimension(3, nstrmx), save forstp
 predicted force vector acting on the structure (N) More...
double precision, dimension(nstrmx), save dtstr
 time step used to solved structure movement (can be different from th fluid time step) More...
double precision, save aexxst
 coefficient for the predicted displacement More...
double precision, save bexxst
double precision, save cfopre
 coefficient for the predicted force More...
double precision, save alpnmk
 alpha coefficient for the Newmark hht methode More...
double precision, save betnmk
 beta coefficient for the Newmark hht methode More...
double precision, save gamnmk
 gamma coefficient for the Newmark hht methode More...
◆ aexxst
◆ alpnmk
◆ betnmk
◆ bexxst
◆ cfopre
◆ dtstr
◆ forsta
double precision, dimension(3,nstrmx), save forsta
◆ forstp
double precision, dimension(3,nstrmx), save forstp
◆ forstr
double precision, dimension(3,nstrmx), save forstr
◆ gamnmk
◆ nbstru
◆ xcstru
double precision, dimension(3,3,nstrmx), save xcstru
damping matric coefficient of the structure (kg/s)
◆ xkstru
double precision, dimension(3,3,nstrmx), save xkstru
spring matrix constant of the structure (kg/s2 = N/m)
◆ xmstru
double precision, dimension(3,3,nstrmx), save xmstru
mass matrix of the structure (kg) (for xmstru(i,j,k), i and j are the array of mass structure and k is the index of the structure)
◆ xppsta
double precision, dimension(3,nstrmx), save xppsta
◆ xppstr
double precision, dimension(3,nstrmx), save xppstr
acceleration vector of the structure (m/s2)
◆ xpsta
double precision, dimension(3,nstrmx), save xpsta
◆ xpstr
double precision, dimension(3,nstrmx), save xpstr
velocity vector of the structure (m/s)
◆ xsta
double precision, dimension(3,nstrmx), save xsta
value of xstr at the previous time step (m)
◆ xstp
double precision, dimension(3,nstrmx), save xstp
◆ xstr
double precision, dimension(3,nstrmx), save xstr
displacement vector of the structure compared to its position in the initial mesh (m)
◆ xstreq
double precision, dimension(3,nstrmx), save xstreq
equilibrum position of a structure (m)
