1 #ifndef __FVM_NODAL_PRIV_H__ 2 #define __FVM_NODAL_PRIV_H__ 58 typedef struct _fvm_nodal_section_t {
274 bool copy_face_index,
276 bool copy_vertex_index,
277 bool copy_vertex_num);
318 int n_face_vertices[6],
319 int face_vertices[6][4]);
cs_lnum_t n_elements
Definition: fvm_nodal_priv.h:65
fvm_tesselation_t * tesselation
Definition: fvm_nodal_priv.h:119
const cs_lnum_t * vertex_num
Definition: fvm_nodal_priv.h:97
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
int n_doms
Definition: fvm_nodal_priv.h:163
Definition: fvm_nodal_priv.h:58
int n_sections
Definition: fvm_nodal_priv.h:164
fvm_nodal_section_t * fvm_nodal_section_create(const fvm_element_t type)
int num_dom
Definition: fvm_nodal_priv.h:162
void fvm_nodal_section_copy_on_write(fvm_nodal_section_t *this_section, bool copy_face_index, bool copy_face_num, bool copy_vertex_index, bool copy_vertex_num)
void fvm_nodal_cell_face_connect(fvm_element_t element_type, int *n_faces, int n_face_vertices[6], int face_vertices[6][4])
Definition: fvm_nodal_priv.h:154
cs_gnum_t fvm_nodal_n_g_vertices(const fvm_nodal_t *this_nodal)
Definition: cs_defs.h:467
cs_lnum_t * _vertex_index
Definition: fvm_nodal_priv.h:104
const cs_coord_t * vertex_coords
Definition: fvm_nodal_priv.h:178
cs_lnum_t n_cells
Definition: fvm_nodal_priv.h:170
fvm_element_t type
Definition: fvm_nodal_priv.h:67
char * name
Definition: fvm_nodal_priv.h:159
cs_lnum_t * _parent_element_num
Definition: fvm_nodal_priv.h:143
int stride
Definition: fvm_nodal_priv.h:80
int * gc_id
Definition: fvm_nodal_priv.h:109
fvm_nodal_section_t ** sections
Definition: fvm_nodal_priv.h:207
fvm_io_num_t * global_element_num
Definition: fvm_nodal_priv.h:146
cs_coord_t * _vertex_coords
Definition: fvm_nodal_priv.h:181
fvm_io_num_t * global_vertex_num
Definition: fvm_nodal_priv.h:202
double cs_coord_t
Definition: cs_defs.h:299
char ** global_vertex_labels
Definition: fvm_nodal_priv.h:222
fvm_element_t
Definition: fvm_defs.h:48
cs_lnum_t * _face_index
Definition: fvm_nodal_priv.h:102
const cs_lnum_t * parent_element_num
Definition: fvm_nodal_priv.h:124
cs_gnum_t fvm_nodal_section_n_g_elements(const fvm_nodal_section_t *this_section)
int entity_dim
Definition: fvm_nodal_priv.h:63
cs_lnum_t n_vertices
Definition: fvm_nodal_priv.h:173
struct _fvm_tesselation_t fvm_tesselation_t
Definition: fvm_tesselation.h:65
cs_lnum_t * _vertex_num
Definition: fvm_nodal_priv.h:105
const cs_lnum_t * face_num
Definition: fvm_nodal_priv.h:89
cs_lnum_t * _parent_vertex_num
Definition: fvm_nodal_priv.h:199
fvm_group_class_set_t * gc_set
Definition: fvm_nodal_priv.h:214
Definition: cs_defs.h:298
size_t connectivity_size
Definition: fvm_nodal_priv.h:72
fvm_nodal_section_t * fvm_nodal_section_destroy(fvm_nodal_section_t *this_section)
const cs_lnum_t * parent_vertex_num
Definition: fvm_nodal_priv.h:184
struct _fvm_io_num_t fvm_io_num_t
Definition: fvm_io_num.h:72
Definition: cs_defs.h:468
cs_lnum_t n_faces
Definition: fvm_nodal_priv.h:171
const cs_lnum_t * vertex_index
Definition: fvm_nodal_priv.h:94
Definition: fvm_group.h:60
const cs_lnum_t * face_index
Definition: fvm_nodal_priv.h:87
cs_lnum_t * _face_num
Definition: fvm_nodal_priv.h:103
const cs_mesh_t * parent
Definition: fvm_nodal_priv.h:226
int * tag
Definition: fvm_nodal_priv.h:113
cs_lnum_t n_faces
Definition: fvm_nodal_priv.h:83
int dim
Definition: fvm_nodal_priv.h:161
cs_lnum_t n_edges
Definition: fvm_nodal_priv.h:172
