Input of calculation parameters (Fortran subroutines in cs_user_parameters.f90)
Introduction
User subroutines for input of calculation parameters (Fortran modules). These subroutines are called in all cases.
If the Code_Saturne GUI is used, this file is not required (but may be used to override parameters entered through the GUI, and to set parameters not accessible through the GUI).
Several routines are present in the file, each destined to defined specific parameters.
To modify the default value of parameters which do not appear in the examples provided, code should be placed as follows:
As a convention, "specific physics" defers to the following modules only: pulverized coal, gas combustion, electric arcs.
In addition, specific routines are provided for the definition of some "specific physics" options. These routines are described at the end of this file and will be activated when the corresponding option is selected in the usppmo routine.
General options (usipsu)
All options
The following code block presents all the options available in the usipsu subroutine.
! Calculation options (optcal)
! In case of restart, read auxiliary restart file ileaux (= 1) or not (0).
! By default, this file is read, but it may be useful to deactivate
! its use when restarting after a preprocessing stage possibly leading
! to a different number of faces (such as simply joining meshes on
! a different architecture or optimization level or with different options).
! Writing of auxiliary restart files may also be deactivated using: iecaux = 0
ileaux = 0
! --- Algorithm to take into account the thermodynamical pressure variation in time
! (not used by default except if idilat = 3)
! by default:
! - the thermodynamic pressure (pther) is initialized with p0 = p_atmos
! - the maximum thermodynamic pressure (pthermax) is initialized with -1
! (no maximum by default, this term is used to model a venting effect when
! a positive value is given by the user)
! - a global leak can be set through a leakage surface sleak with a head
! loss kleak of 2.9 (Idelcick)
ipthrm = 0
pthermax= -1.d0
sleak = 0.d0
kleak = 2.9d0
! --- Temperature or enthalpy
! When used without specific physics, if we have chosen to solve in temperature
! (that is if itherm = 1), the fluid temperature is considered to be in
! degrees Kelvin by default (be careful for boundary conditions an expression
! of physical properties depending on temperature)t.
! If we wish for the fluid solver to work with a temperature in degrees Celsius,
! we must set itpscl = 2.
! This is recommended for Syrthes Coupling, but not recommended for the
! radiative model, as it is a source of user errors in this case:
! Indeed, the boundary conditions for the fluid temperature will then be
! in degrees Celsius, while the boundary conditions for radiation in
! cs_user_radiative_transfer_bcs must still be in Kelvin.
if (nmodpp.eq.0) then
itpscl = 2
endif
! If a USER scalar behaves like a temperature (relative to Cp):
! we set iscacp(isca) = 1.
! Otherwise, we do not modify iscacp(isca)
if (nscaus.gt.0) then
do ii = 1, nscaus
iscacp(isca(ii)) = 1
enddo
endif
! --- Calculation (restart) with frozen velocity field (1 yes, 0 no)
iccvfg = 1
! --- Vortex method for inlet conditions in L.E.S.
! (0: not activated, 1: activated)
! The vortex method only regards the L.E.S. models
! To use the vortex method, edit the 'usvort.f90' user file.
if (itytur.eq.4) then
ivrtex = 1
endif
! --- Convective scheme
! blencv = 0 for upwind (order 1 in space, "stable but diffusive")
! = 1 for centered/second order (order 2 in space)
! we may use intermediate real values.
! Here we choose:
! for the velocity and user scalars:
! an upwind-centered scheme with 100% centering (blencv=1)
! for other variables
! the default code value (upwind standard, centered in LES)
! Specifically, for user scalars
! if we suspect an excessive level of numerical diffusion on
! a variable ivar representing a user scalar
! iscal (with ivar=isca(iscal)), it may be useful to set
! blencv = 1.0d0 to use a second-order scheme in space for
! convection. For temperature or enthalpy in particular, we
! may thus choose in this case:
! call field_get_key_struct_var_cal_opt(ivarfl(isca(iscalt)), vcopt)
! vcopt%blencv = 1.0d0
! call field_set_key_struct_var_cal_opt(ivarfl(isca(iscalt)), vcopt)
! For non-user scalars relative to specific physics (coal, combustion,
! electric arcs: see usppmo) implicitly defined by the model,
! the corresponding information is set automatically elsewhere:
! we do not modify blencv here.
call field_get_key_struct_var_cal_opt(ivarfl(iu), vcopt)
call field_set_key_struct_var_cal_opt(ivarfl(iu), vcopt)
if (nscaus.ge.1) then
do ii = 1, nscaus
call field_get_key_struct_var_cal_opt(ivarfl(isca(ii)), vcopt)
call field_set_key_struct_var_cal_opt(ivarfl(isca(ii)), vcopt)
enddo
endif
! --- Linear solver parameters (for each unknown)
! epsilo: relative precision for the solution of the linear system.
do ii = 1, nscaus
vcopt%epsilo = 1.d-6
enddo
endif
! --- Dynamic reconstruction sweeps to handle non-orthogonlaities
! This parameter computes automatically a dynamic relax factor,
! and can be activated for any variable.
! - iswdyn = 1: means that the last increment is relaxed
! - iswdyn = 2: means that the last two increments are used to
! relax
! NB: when iswdyn is greater than 1, then the number of
! non-orthogonality sweeps is increased to 20.
call field_get_key_struct_var_cal_opt(ivarfl(ipr), vcopt)
vcopt%iswdyn = 1
call field_set_key_struct_var_cal_opt(ivarfl(ipr), vcopt)
! --- Rotation/curvature correction for eddy-viscosity turbulence models
! 0: deactivated
! 1: activated
irccor = 1
! --- Stabilization in turbulent regime
! For difficult cases, a stabilization may be obtained by not
! reconstructing the convective and diffusive flux for variables
! of the turbulence model, that is
! in k-epsilon: if (itytur.eq.2) then
! ircflu(ik) = 0 and ircflu(iep) = 0
! in Rij-epsilon: if (itytur.eq.3) then
! ircflu(ir11) = 0, ircflu(ir22) = 0,
! ircflu(ir33) = 0,
! ircflu(ir12) = 0, ircflu(ir23) = 0,
! ircflu(ir23) = 0,
! and ircflu(iep) = 0
! (note that variable itytur is equal to iturb/10)
call field_get_key_struct_var_cal_opt(ivarfl(ik), vcopt)
vcopt%ircflu = 0
call field_set_key_struct_var_cal_opt(ivarfl(ik), vcopt)
call field_get_key_struct_var_cal_opt(ivarfl(iep), vcopt)
vcopt%ircflu = 0
call field_set_key_struct_var_cal_opt(ivarfl(iep), vcopt)
endif
! --- Advanced re-initialization for EBRSM or k-omega models
! - 0: switch off (default)
! - 1: switch on
reinit_turb = 1
! --- Turbulent diffusion model for second moment closure (iturb = 3x)
! 0: scalar diffusivity (Shir model)
! 1: tensorial diffusivity (Daly and Harlow model, default model)
idirsm = 1
endif
! --- Advanced choice of Wall function
iwallf = 5
! Physical constants (cstphy)
! --- gravity (g in m/s2, with the sign in the calculation coordinate axes).
gx = 0.d0
gy = 0.d0
gz = 0.d0
! --- rotation of the reference frame (omega in rad/s)
! If the rotation is not nul, then
! icorio = 0: rotation is taken into account by rotating the mesh
! (simulation in the absolute frame)
! = 1: rotation is taken into account by Coriolis source terms
! (simulation in the relative frame)
icorio = 0
call rotation_define(0.d0, 0.d0, 0.d0, & ! rotation vector
0.d0, 0.d0, 0.d0) ! invariant point
! --- Reference fluid properties
! ro0 : density in kg/m3
! viscl0 : dynamic viscosity in kg/(m s)
! cp0 : specific heat in J/(Kelvin kg)
! t0 : reference temperature in Kelvin
! p0 : total reference pressure in Pascal
! the calculation is based on a
! reduced pressure P*=Ptot-ro0*g.(x-xref)
! (except in compressible case)
! xyzp0(3) : coordinates of the reference point for
! the total pressure (where it is equal to p0)
! In general, it is not necessary to furnish a reference point xyz0.
! If there are outlets, the code will take the center of the
! reference outlet face.
! On the other hand, if we plan to explicitly fix Dirichlet conditions
! for pressure, it is better to indicate to which reference the
! values relate (for a better resolution of reduced pressure).
! Other properties are given by default in all cases.
! Nonetheless, we may note that:
! In the standard case (no gas combustion, coal, electric arcs,
! compressibility):
! ro0, viscl0 and cp0
! are useful and represent either the fluid properties if they
! are constant, either simple mean values for the initialization
! if properties are variable and defined in cs_user_physical_properties.
! t0 is not useful
! p0 is useful but is not used in an equation of state. p0
! is a reference value for the incompressible solver
! which will serve to set the (possible) domain outlet pressure.
! We may also take it as 0 or as a physical value in Pascals.
! With the electric module:
! are useful but simply represent mean initial values;
! the density, molecular dynamic viscosity, and specific
! heat are necessarily defined as fields (whether they are
! physically variable or not): see cs_user_physical_properties
! for the Joule effect
! module and the electric arcs dp_ELE data file.
! t0 is useful an must be in Kelvin (> 0) but represents a simple
! initialization value.
! p0 is useful bu is not used in the equation of state. p0
! is a reference value for the incompressible solver which
! will be used to calibrate the (possible) outlet pressure
! of the domain. We may take it as zero or as a physical
! value in Pascals.
! With gas combustion:
! ro0 is not useful (it is automatically recalculated by the
! law of ideal gases from t0 and p0).
! viscl0 is indispensable: it is the molecular dynamic viscosity,
! assumed constant for the fluid.
! cp0 is indispensable: it is the heat capacity, assumed constant,
! (modelization of source terms involving a local Nusselt in
! the Lagrangian module, reference value allowing the
! calculation of a radiative
! (temperature, exchange coefficient) couple).
! t0 is indispensible and must be in Kelvin (> 0).
! p0 is indispensable and must be in Pascal (> 0).
! With pulverized coal:
! assumed constant for the fluid (its effect is expected to
! be small compared to turbulent effects).
! the coal or Lagrangian module, reference value allowing the
! t0 is indispensable and must be in Kelvin (> 0).
! With compressibility:
! ro0 is not useful, stricto sensu; nonetheless, as experience
! shows that users often use this variable, it is required
! to assign to it a strictly positive value (for example,
! an initial value).
! viscl0 is useful and represents the molecular dynamic viscosity,
! when it is constant, or a value which will be used during
! initializations (or in inlet turbulence conditions,
! depending on the user choice.
! in the thermodynamics available by default
! With the thermodynamic law available by default,
! t0 and p0 are used for the initialization of the density.
! xyzp0 is not useful because the pressure variable directly
! represents the total pressure.
ro0 = 1.17862d0
viscl0 = 1.83337d-5
cp0 = 1017.24d0
t0 = 20.d0 + 273.15d0
p0 = 1.01325d5
! --- irovar, ivivar, icp: constant or variable density,
! viscosity/diffusivity, and specific heat
! When a specific physics module is active
! (coal, combustion, electric arcs, compressible: see usppmo)
! we MUST NOT set variables 'irovar', 'ivivar', and 'icp' here, as
! they are defined automatically.
! Nonetheless, for the compressible case, ivivar may be modified
! in the uscfx2 user subroutine.
! When no specific physics module is active, we may specify if the
! density, specific heat, and the molecular viscosity
! are constant (irovar=0, ivivar=0, icp=-1), which is the default
! or variable (irovar=1, ivivar=1, icp=0)
! For those properties we choose as variable, the corresponding law
! must be defined in cs_user_physical_properties
! (incs_user_physical_properties.f90);
! if they are constant, they take values ro0, viscl0, and cp0.
irovar = 1
ivivar = 1
icp = -1
! We only specify XYZ0 if we explicitely fix Dirichlet conditions
! for the pressure.
xyzp0(1) = 0.d0
xyzp0(2) = 0.d0
xyzp0(3) = 0.d0
! --- Variable diffusivity field id (ifcvsl>=0) or constant
! diffusivity (ifcvsl=-1) for the thermal scalar and USER scalars.
! With ifcvsl = 0, the field will be added automatically, and later calls to
! field_get_key_int(ivarfl(isca(iscal)), kivisl, ifcvsl)
! will return its id.
! With ifcvsl > 0, the id of an existing, predifined field is given. This
! may allow sharing a diffusivity between multiple scalars.
! For user scalars iscal which represent the variance of another user
! scalar, the diffusivity of the variance of a scalar is assumed to
! have the same behavior as the diffusivity of this scalar,
! so values set here will be ignored.
! electric arcs: see usppmo) implicitly defined in the model,
! the diffusivity should not be modified here.
! Caution: complete cs_user_physical_properties with the law defining the diffusivity
! ======== if and only if ifcvsl = 0 has been set here.
! For thermal scalar
if (ippmod(icompf).ge.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(itempk)), kivisl, ifcvsl)
else if (iscalt.gt.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscalt)), kivisl, ifcvsl)
endif
do iscal = 1, nscaus
if (iscavr(iscal).le.0) then
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscal)), kivisl, ifcvsl)
endif
enddo
! --- Variable density field id (ifcvsl>=0) or bulk
! density (ifcvsl=-1) for USER scalars.
! field_get_key_int(ivarfl(isca(iscal)), kromsl, ifcvsl)
! may allow sharing a density between multiple scalars.
! scalar, the density of the variance of a scalar is assumed to
! have the same behavior as the density of this scalar,
! Caution: complete cs_user_physical_properties with the law defining the density
ifcvsl = -1
call field_set_key_int(ivarfl(isca(iscal)), kromsl, ifcvsl)
endif
enddo
! --- Turbulent flux model u'T' for the scalar T
! Algebraic Model
! 0 SGDH
! 10 GGDH
! 11 EB-GGDH (Elliptic Blending)
! 20 AFM
! 21 EB-AFM (Elliptic Blending)
! Model with transport equations
! 30 DFM
! 31 EB-DFM (Elliptic Blending)
! GGDH for thermal scalar:
if (iscalt.gt.0) iturt(iscalt) = 10
! GGDH for all the scalars:
do jj = 1, nscaus
iturt(jj) = 10
enddo
! --- Reference velocity for turbulence initialization (m2/s)
! (useful only with turbulence)
uref = 1.d0
! --- Reference length scale in meters for initialization
! of epsilon (and specific clipping of turbulence, but
! this is not the default option)
! Assign a value of the order of the largest dimension of the
! physical domain in which the flow may develop.
! If a negative value is set here, or no value set and the GUI not
! used, the cubic root of the domain will be used.
! (useful only for turbulence).
almax = 0.5
! Error estimators for Navier-Stokes (non-frozen velocity field)
! We recommend running a calculation restart on a few time steps
! with the activation of the most interesting of those.
! (=2 to activate, =0 to deactivate).
iescal(iescor) = 2 ! div(rho u) -Gamma
iescal(iestot) = 2 ! resolution precision for the momentum
! ALE (Arbitrary Lagrangian Eulerian) related options
! Number of iterations for fluid initialization. Contrary to ntmabs,
! nalinf is not an absolute iteration number, meaning that in case of
! restart calculation nalinf corresponds to the number of iterations
! for fuid initialization beginning from the first current iteration of
! the calculation restart. In general nalinf = 0 in that case.
nalinf = 75
! Maximum number of iterations in case of implicit Fluid Structure Coupling
! with structural calculations (internal and/or external
! (i.e. using code_aster)).
! nalimx = 1, in case of explicit FSI algorithm.
nalimx = 15
! Relative precision of sub-cycling Fluid Structure Coupling algorithm.
epalim = 1.d-5
Specific physic activation (usppmo)
The usppmo routine can be found in the cs_user_parameters.f90 file.
! 1. Choice for a specific physics
! --- cod3p: Diffusion flame with complete fast chemistry (3 points)
! if = -1 module not activated
! if = 0 adiabatic model
! if = 1 extended model with enthalpy source term
if (ixmlpu.eq.0) then
ippmod(icod3p) = -1
endif
! --- coebu: Eddy-Break Up pre-mixed flame
! if = 0 reference Spalding model
! (adiabatic, homogeneous mixture fraction)
! (homogeneous mixture fraction : perfect premix)
! if = 2 extended model with mixture fraction transport
! (adiabatic, no variance of mixture fraction)
! if = 3 extended model with enthalpy and mixture fraction transport
! (dilution, thermal losses, etc.)
ippmod(icoebu) = -1
endif
! --- colwc: Libby-Williams pre-mixed flame
! if = 0 reference two-peak model with adiabatic condition
! if = 1 extended two-peak model with enthapy source terms
! if = 2 extended three-peak model, adiabatic
! if = 3 extended three-peak model with enthalpy source terms
! if = 4 extended four-peak model, adiabatic
! if = 5 extended four-peak model with enthalpy source terms
ippmod(icolwc) = -1
endif
! --- Soot model
! if = 0 constant fraction of fuel Xsoot
! if = 1 2 equations model of Moss et al.
isoot = 0
xsoot = 0.1d0 ! ( if isoot = 0 )
rosoot = 2000.d0 ! kg/m3
! --- cfuel: Heavy fuel oil combustion
! Progressive evaporation (temperature gap)
! Char residue
! Sulphur tracking
! if = 0 module activated
ippmod(icfuel) = -1
endif
! --- coal :
! Pulverized coal combustion
! Description of granulometry
! Assumption of diffusion flame around particles
! (extension of 3-point fast chemistry "D3P")
! Between a mixture of gaseous fuels (volatiles matters, CO from char
! oxydation)
! and a mixture of oxidisers (air and water vapor)
! Enthalpy for both mix and solid phase are solved
! if = 1 with drying
ippmod(iccoal) = -1
endif
! Activate the drift: 0 (no activation),
! 1 (transported particle velocity)
! 2 (limit drop particle velocity)
i_comb_drift = 1
! --- cpl3c: Pulverized coal with Lagrangian reciprocal approach
! Not recently tested... at least outdated, may be obsolete
! if = 1 with drying (NOT functional)
ippmod(icpl3c) = -1
endif
! --- compf: Compressible flows
! if = 1 barotropic version
! if = 2 homogeneous two phase model
ippmod(icompf) = -1
endif
! --- eljou: Joule effect
! if = 1 Potentiel reel
! if = 2 Potentiel complexe
! if = 3 Potentiel reel + CDL Transfo
! if = 4 Potentiel complexe + CDL Transfo
ippmod(ieljou) = -1
endif
! --- elarc: Electric arcs
! if = 1 electric potential
! if = 2 electric potential and vector potential (hence 3D modelling)
ippmod(ielarc) = -1
endif
! --- atmos: Atmospheric flows
! if = 0 standard modelling
! if = 1 dry atmosphere
! if = 2 humid atmosphere (experimental)
ippmod(iatmos) = -1
endif
! --- aeros: Cooling towers
! if = 0 no model (NOT functional)
! if = 1 Poppe's model
! if = 2 Merkel's model
ippmod(iaeros) = -1
endif
! --- igmix: Gas mixtures modelling
! if =-1 module not activated
! if = 0 Air/Helium gas mixtures
! if = 1 Air/Hydrogen gas mixtures
! if = 2 Air/Steam gas mixtures
! if = 3 Air/Helium/Steam gas mixtures
! if = 4 Air/Hydrogen/Steam gas mixtures
ippmod(igmix) = 0
! Radiative transfer module (iirayo)
! if = 0: not activated (Default)
! if = 1: DOM
! if = 2: approximation P1 method
iirayo = 1
! --- richards model
! if = 1 module activated
ippmod(idarcy) = -1
! 2. Specific options related to herebefore modules
! These options are defined here at the moment, this might change in the future
! --- Enthalpy-Temperature conversion law (for gas combustion modelling)
! if = 0 user-specified
! if = 1 tabulated by JANAF (default)
indjon = 1
endif
! 2. Data file related to modules above
! Combustion
if ( ippmod(icod3p).ge.0 &
.or. ippmod(icoebu).ge.0 .or. ippmod(icolwc).ge.0) then
if (indjon.eq.1) then
ficfpp = 'dp_C3P'
else
ficfpp = 'dp_C3PSJ'
endif
endif
! Fuel combustion
if (ippmod(icfuel).ge.0) then
ficfpp = 'dp_FUE'
endif
! Atmospheric flows
if (ippmod(iatmos).ge.0) then
ficmet = 'meteo'
endif
if (ippmod(igmix).ge.0) then
! Specific condensation modelling
! wall condensation
! if = 0 condensation source terms activated
icondb = -1
! internal condensation
! if = 0 condensation source terms with metal
! structures activate
icondv = -1
endif
endif
Additional input of parameters (usipph)
The usipph routine can be found in the cs_user_parameters.f90 file.
Calculation options for the atmospheric module (usati1)
The usati1 routine can be found in the cs_user_parameters.f90 file.
! 1. Example of calculation options to modify
!!! Reading the meteo file
imeteo = 1
! Automatique open boundary conditions
iatmst = 1
!!! For radiative model or chemistry
! Time of the simulation
! syear --> starting year
! squant --> starting quantile
! shour --> starting hour (UTC)
! smin --> starting minute
! ssec --> starting second
syear = 1994
squant = 1
shour = 1
smin = 0
ssec = 0.d0
! Geographic position
! xlon --> longitude of the domain origin
! xlat --> latitude of the domain origin
xlon = 0.d0
xlat = 45.d0
! Atmospheric imbrication on large scale meteo (atimbr module)
! activation flag
imbrication_flag = .false.
imbrication_verbose = .false.
! flags for activating the cressman interpolation for the boundary conditions
cressman_u = .true.
cressman_v = .true.
cressman_tke = .true.
cressman_eps = .true.
cressman_theta = .true.
cressman_qw = .true.
cressman_nc = .true.
! numerical parameters for the cressman interpolation formulas
horizontal_influence_radius = 8500.d0
vertical_influence_radius = 100.d0
!!! Gaseous chemistry
! ichemistry: choice of chemistry resolution scheme
!0 --> no atmospheric chemistry
!1 --> quasi steady equilibrium NOx scheme with 4 species and 5 reactions
!2 --> scheme with 20 species and 34 reactions
!3 --> scheme CB05 with 52 species and 155 reactions
!4 --> user defined schema
ichemistry = 0
! ificchemistry: choice to read (=1,2,3,4, according to the scheme)
! or not (0) a concentration profile file
! if ichemistry>0 ifilechemistry is automaticaly set to ichemistry
ifilechemistry = 0
! isepchemistry: splitted (=1) or semi-coupled (=2, pu-sun)
! resolution of chemistry
isepchemistry = 1
! iphotolysis: inclusion (=1) or not (=2) of photolysis reactions
iphotolysis = 1
! dtchemmax: maximal time step (s) for chemistry resolution
dtchemmax = 10.0d0
!!! Aerosol chemistry
! iaerosol: flag to activate aerosol chemistry
! if iaerosol = 1, ichemistry is automatically set to 3 (scheme 3)
iaerosol = 1
! inogaseouschemistry: flag to prevent automatic resolution (=1)
! of gaseous chemistry (scheme 3)
inogaseouschemistry = 0
! ncycle_aer: number of iterations for time splitting
ncycle_aer = 1
! icoag_siream: flag to activate (=1) or not (=0) coagulation
icoag_siream = 1
! icond_siream: flag to activate (=1) or not (=0) condensation/evaporation
icond_siream = 1
! inucl_siream: flag to activate (=1) or not (=0) nucleation
inucl_siream = 1
! icut_siream: cutting bin between equilibrium (1 to icut_siream)
! and dynamic bins (icut_siream to nbin_aer)
icut_siream = nbin_aer
! computation / storage of downward and upward infrared radiative fluxes
irdu = 1
! computation / storage of downward and upward solar radiative fluxes
soldu = 1
Calculation options for the combustion module (cs_user_combustion)
The cs_user_combustion routine can be found in the cs_user_parameters.f90 file.
! 1. Additional Calculation Options
! --- Kinetic model for CO <=> CO2
! if = 0 unused (maximal conversion in turbulent model)
! if = 1 transport of CO2 mass fraction
! if = 2 transport of CO mass fraction (coal and fuel only)
ieqco2 = 0
! --- Density Relaxation
! RHO(n+1) = SRROM * RHO(n) + (1-SRROM) * RHO(n+1)
srrom = 0.8d0
! 2. Physical Constants
! diftl0: Dynamic Diffusion Coefficient (kg/(m s))
diftl0 = 4.25d-5
! 2.1 For 3 points combusution model ONLY
! Reference temperature for fuel and oxydant (K)
tinfue = 436.d0
tinoxy = 353.d0
! 2.2 For EBU-model ONLY
! cebu: EBU-model constant
cebu = 2.5d0
! 2.3 For Libby-Williams model ONLY
! Reference velocity
vref = 60.d0
! Reference length scale
lref = 0.1d0
! Activation Temperature
ta = 0.2d5
! Cross-over Temperature (combustion of propane)
tstar= 0.12d4
Non-standard options for the compressible module (uscfx1)
The uscfx1 routine can be found in the cs_user_parameters.f90 file.
! 1. Properties options
if (iihmpr.eq.0) then ! Remove test to set values here when also using GUI.
! --> Molecular thermal conductivity
! constant : ifcvsl = -1
! variable : ifcvsl = 0
ifcvsl = -1
! --> Volumetric molecular viscosity
! iviscv = -1 : uniform in space and constant in time
! = 0 : variable in space and time
iviscv = -1
endif
Non-standard options for the compressible module (uscfx2)
The uscfx2 routine can be found in the cs_user_parameters.f90 file.
! 1. Physical properties
! --> Molecular viscosity
! constant : ivivar = 0
! variable : ivivar = 1
ivivar = 0
! --> Reference molecular thermal conductivity
! visls0 = lambda0 (molecular thermal conductivity, W/(m K))
! WARNING: visls0 must be strictly positive
! (set a realistic value here even if conductivity is variable)
visls0(itempk) = 3.d-2
! If the molecular thermal conductivity is variable, its values
! must be provided in the user subroutine 'cs_user_physical_properties'
! Reference volumetric molecular viscosity
! viscv0 = kappa0 (volumetric molecular viscosity, kg/(m s))
viscv0 = 0.d0
! If the volumetric molecular viscosity is variable, its values
! --> Molar mass of the gas (kg/mol)
! For example with dry air, xmasml is around 28.8d-3 kg/mol
xmasmr = 0.028966
! --> Hydrostatic equilibrium
! Specify if the hydrostatic equilibrium must be accounted for
! (yes = 1 , no = 0)
icfgrp = 1
endif
Definition of cooling tower model and exchange zones (uscti1)
The uscti1 routine can be found in the cs_user_parameters.f90 file.
Calculation options for the Darcy module (user_darcy_ini1)
The user_darcy_ini1 routine can be found in the cs_user_parameters.f90 file.
darcy_anisotropic_permeability = 0 ! permeability : 0 isotrop, 1 anisotrop
darcy_anisotropic_dispersion = 0 ! dispersion : 0 isotrop, 1 anisotrop
darcy_unsteady = 0 ! 0 steady flow, 1 unsteady flow
darcy_convergence_criterion = 0 ! convergence criterion of Newton scheme : 0, over pressure, 1, over velocity
darcy_gravity = 0 ! gravity is taken into account : 0 no, 1 yes
